Question about Canon Office Equipment & Supplies
My caaon printer status says off line paper thicknes lever
  • 1 more comment
  • noelunderhil Nov 19, 2009
    the machine copies scans and sends fax OK but when I try toprint from the internet or my computer it shows that the printer is off line and in the status it sayspaper thickness lever position.
    I need information on where to find this paper thicknesslever and how to adjust it
    well I am waiting for a reply
    Brigadier General:
  • 4,090 Answers
Noel
This is all i see of your question
my caaon printer status says off line paper thicknes lever
this is insufficient information to diagnose your problem. what has the thickness lever have to do with it being offline?
Posted on Nov 19, 2009
  • dennis bullard Nov 20, 2009
    Noel
    check the paper thickness lever located at the left side of the
    printer, set this lever to the lowest possible setting that your paper
    can handle. This is the darkest that the printer can print. Other than
    this, it may be an application issue. Check for contrast settings in
    your program.
    As a final straw re run your startup disk again
    dennis
I have a Brother HL-5240, status light red, paper light flashing. Plenty of paper in the tray
Ether the paper sensing lever is broken or there is dust accumulation or paper fragments inside the optical sensor.
Sep 13, 2011 | Brother HL-5240 Laser Printer
Paper feed not move
If I recall the KXP series, it is a track feed printer as well as sheet feed, there should be a lever on the top that you can move to different positions, one position is for feeding paper without the rollers, when the lever is placed in a different position it releases the rollers so the printer can feed the paper. The open position is for installing paper or clearing paper jams. Also if I recall, the lever is on the right side near the roller on the end. When you move the lever, and turn the roller, you fill feel it grab the paper. There is also a switch on the front for line feed and page feed allowing you to tear off a page and then pressing it again will reverse the paper to print position.
Aug 30, 2009 | Panasonic KX-P3696 Matrix Printer
Photo paper jam
Replace paper feeder. Or add tape to add the thicknes of rubbers at paper feeder mechanics.
Feb 22, 2009 | Epson Stylus Photo R200 InkJet Printer
My printer refuses to acknowledge the existence of paper in the MP tray. HELP! FOR THE LOVE OF GOD, YOU HAVE TO HELP ME!
Normal 0 Driver could be corrupt.
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 07, 2009 | Brother HL 5250DN Laser Printer
When i am trying to print my work the paper goes to the one side and does not print, when loading the paper it happens to
YOU HAVE A JAM AND OR A BAD ROLLER.
LOOK IN THE AREA THAT(SAY PULLS TO THE RIGHT LOOK ON THE LEFT ECT.)
TRY THIS FIRST
YOU MIGHT NOT SEE IT AT FIRST SO TAKE A PIECE OF CARDBOARD THE THICKNES OF A MEMOPAD AND FLOSS THE THE PRINTER WITH IT.
Nov 30, 2008 | Lexmark Office Equipment & Supplies
Paper draw
Check if the rubber draw rollers are pressing the paper down properly.
If this is okay then see what is the default thickness of paper that has been configured .
Similar problem had happened when my friend had printed a whole stack on photo paper and set the thickness of paper to highest level to ensure paper is not stuck inside, later it would not draw in normal thicknes paper till we rest the paper settings.
Sep 26, 2008 | Samsung ML-2510 Laser Printer
Phaser 6110 - red light on, not printing
Just had user with same problem. Printer status = paper jam but no paper in feed path therefore suspect paper pick up problem. Asked user to take out paper tray and turn paper in tray over. This solved problem.
So possible fix = turn paper over or try different paper.
If printer is old try cleaning pickup roller. My users printer had only done 227 pages.
Sep 11, 2008 | Canon PIXMA® MP530 All-In-One Printer
Laser printer does not print
Hi there it may just be that the paper tray springs are not pushing the paper higher enough not making contact with the paper detect sensor arm. Or the sensor arm is broken and will need replacing. Check the tray springs also check the sensor arm you will see it if you remove the cassette and look inside there will be a black plastic lever hanging down when you put paper in this lever should go up as the paper acts as a barrier thus telling the machine that there is paper in it.
Thanks J
Jan 28, 2008 | Brother DCP-7020 All-In-One Laser Printer
Printer does'nt work
You printer is giving you an error code with its flashing coloyr lights. I would consult canons website and write down the exact colours it is flashing as this is a specific error code. Most likely it is a paper jam error or reading error. Before you contact them i would try resetting the printer by powering down, unplugging all cables and cord, replugging and turning on and retry print jobs. If no luck go to plan B, webesite, and find error code. I am sorry i have no deatils for this printer to give you the error code myself.
Aug 31, 2007 | Canon BubbleJet i560 InkJet Printer
Help please. can't print: paper light flashing even though there is paper in printer
To fix the NON EXISTANT paper jam:
Status light is on, paper light is on - you can hear the paper feed trying to "grab" the paper, but it can't,  and status light goes Red.
Take out paper tray
Reset the blue paper holders, move them tight against the paper so the paper is snug against all blue barriers. Cause: Somehow the blue paper holders got dislodged and the paper is not snug so the feeder is trying to grab paper that  is slightly out of reach.
Mar 15, 2007 | Brother HL 5140 Laser Printer
20 people viewed this question
old marine
old marine
