Question about Rockford Fosgate P3001 Car Audio Amplifier
I have an spl gorilla series 1250watt amp that blows fuses
I have an spl gorilla series amplifier 1250watt with 2 12 rocksferd fosgate p1's and everytime i put a fuse in the amp it blows...help
    Novelist:
  • 92 Answers
REMOVE THE RCA INPUTS AND DISCONNECT THE SPEAKERS, THEN POWER THE AMPLIFIER UP WITH THIS NO INPUT, NO SPEAKER LOAD CONDITION. IF IT STILL BLOWS THE FUSE, THEN IT WILL NEED TO BE SERVICED. IF IT BLOWS THE FUSE BEFORE TURNING IT ON, THEN YOUR PROBLEM IS IN THE POWER SUPPLY SECTION. IF IT BLOWS THE FUSE AFTER ATTEMPTING TO TURN IT ON, THEN YOUR PROBLEM IS PROBABLY IN THE OUTPUT SECTION. ALSO KEEP IN MIND THAT THE P1'S ARE REALLY NOT RATED FOR THAT MUCH POWER AND YOU MAY HAVE DAMAGED THE VOICECOILS. BEFORE REINSTALLING THE AMPLIFIER, MAKE SURE TO CHECK THE SPEAKERS FOR SHORTED VOICECOILS OR YOU WILL POSSIBLY DAMAGE THE AMPLIFIER AGAIN. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Posted on Jan 06, 2010
Why did speakers get really loud, then stop working?
Have you checked the fuse on the amp and/or make sure the amp did not burn out?
Aug 01, 2015 | Rockford Fosgate Car Audio & Video
My 2000w TNT amp blows fuses as sooooon as I put a fuse in. What is the problem with the amp. is it internal external? I also checked my wires and they all look good
Sounds like you're grounded out somewhere. I'd check your main power wire again, make sure there isn't any abrasions or cracks in the insulation. I had a Fosgate amp that would blow fuses everytime they were put in. turned out to be one of the screws to mount the amp to my floor board was grounding it out, pulled the screws and has worked fine ever since
May 04, 2012 | Alpine Earthquake T2000wd/1 Car Amplifier...
I have a rockford fosgate punch P325.1 subwoofer mono amp that blows a fuse every time i start the car. I have a second pioneer amp but that works with no problems. How can i fix this?
Is it the correct size fuse ? Is it the power fuse or remote ? Either way check your connections going into the amp . Try this hook your other amp to the set of wires for the rockford if that amp has a problem its a wireing problem if not chances are its an interal problem on the rockford . Hope this helps !
Aug 19, 2010 | Rockford Fosgate Punch P325.1 Subwoofer...
Rockford Fosgate Punch P325.1 Amp keeps blowing fuses every time I start the car. What is going on?
well if the amp works with the car off and when you start it the fuse blows then you may have alternator issues use a volt meter to check battery voltage is not above 14.5 volts
if the fuse blows when the amp turns on then most likely you have a shorted output section in the amp.
Mar 18, 2010 | Rockford Fosgate Punch P325.1 Subwoofer...
I have a rockford fosgate 550 that the fuse blows
Short inside one of the transistors. This requires very good soldring skills and electrical know-how, and some thermal paste to go between the heat-sink and the transistor. Unfortunatly this is not a cheap repair, probably cost around 100 dollars.
Cheers,
Kevin
Feb 09, 2010 | Rockford Fosgate Punch P550.2 2-Channel...
Why do the fuses in my amp keep blowing
You may not have they proper size wire to the amplifier. Most amps now recommend 4 ga. Also make sure your wiring to the speakers are at the proper Ohm load.
Dec 05, 2009 | SPL Dynamics XL2-820 SPL Car Audio...
Want my 10s to beat down the block
http://www.crutchfield.com/p_020DPX1155/Clarion-DPX11551.html?tp=115
http://www.crutchfield.com/p_675FRT1500/Rockford-Fosgate-T1500-1bd-Factory-Refurbished.html?cc=01&showAll=N&tp=115
http://www.crutchfield.com/p_136GMAX/JL-Audio-G-Series-G-MAX.html?showAll=N&tp=115
http://www.crutchfield.com/p_57515001BD/Rockford-Fosgate-T1500-1bd.html?showAll=N&tp=115
Here are a few amps at Crutchfield.com you can look at. Notice that the closer to a class D you get, the price more than doubles. I have 2 Kenwood 12's that are 800W Rms, and I have a cheap SPL 1500W amp pushing them. 148.5 Db in a 93 Eclipse, so don't worry too much about the class unless you have money to burn. Let me know if this helps :)
May 25, 2009 | Lanzar OPTI1200D 2000 Watt Class D...
Im having trouble i keep blowing fuses on my amp?
you have you gain and freq knobs turned up too far, try turning them down and turn down subb level from deck
Apr 13, 2009 | Rockford Fosgate P3001 Car Audio Amplifier
Cold weather blown fuse
You might want to try better quality fuses, or allow the amp to warm up a bit before you start bumping down the street make old ladies angry.
Jun 01, 2007 | Rockford Fosgate Punch 700S Car Audio...
Rockford Fosgate P3001 Car Audio Amplifier Logo
289 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
