Question about Nokia 447Xi (White) 17" CRT Monitor
My monitor showing a white strip in the middle.
Hey i resize my monitor the resolution using the vertical setting, now its the smallest(white strip in the middle) i can't resize it now coz i can see a thing. So any kind souls out there that can tell me all the options when i press Select. Coz i need it be done ASAP thx in advance.
  • paulmhl Jan 11, 2008
    No dude. Well hmmm, lets just say i try adjusting the screen, horizontal and vertical to fit in my com nicely. The desktop looks small now thats it, i just need to resize back to original setting, hence i need someone to tell me how do i get to the right menu since i will be doing this without seeing the monitor for a respond. And the strip are not white just that my destop is a strip horizontally, i know this coz when i press the start button(window) on my key board, the left hand side will changed colour(hence the start button is highlighted). I also did some pressing there and there i can confirm nothing is wrong i just need some guidance for any one who has this monitor to tell me what exactly to press, and my vertical setting is 0 instead of 100. Thanks for helping megatronix.
    Scholar:
  • 57 Answers
I suspect that the white strip is horizontally across the screen? This is definitely an electronic fault and indicates that the vertical deflection circuit has failed. In TV and monitor jargon this is known as field collapse. Open-up the monitor (switch-off first!) and look for any obvious bad connections on the board known as dry joints, especially around large components. If all is fine, then replace the vertical field integrated circuit. If all this sounds like mumbo-jumbo then rather refer servicing to a qualified tech, and try to get him/her not to rip you off by citing all the above lingo. Good luck.
Posted on Jan 11, 2008
Get rid of "Out Of Range" message on e218c1 monitor.
The device driving the monitor is exceeding the horizontal and vertical frequencies that the monitor can display .....thus the "out of range". The specs for this state that the Horizontal Freq. is 80Khz and the Vertical Rate is 75hz. If you are driving this monitor from a computer running Windows, reboot the PC and use the F8 key to put it in SAFE mode. This will cause the video driver to default to a rate that the monitor can handle. Then go into the screen resolution settings and reset them. The native resolution of the monitor is 1680x1050 at 60 Hz. Exceed that and you'll get the "out of range"
Sep 10, 2014 | Envision Peripherals 22"" envision e218c1...
Inmy screen has a white strip about 3.5 inches/9 cm wide just to the right of midscreen. when logged on the normal icons show either side, but those that should be where the strip is do not show. It comes...
Hi , and thanx for using our site ..
My advice is that you have a resolution issue ...if the strip is present in both sites..it means that you are using a wrong resolution ...so get into the video properties and try a few configurations ...until you get the one fit for your screen ...(I deduced this cause it is not present in another monitor..so it's not an physical or system issue...but probably you have a wide screen and a wrong resolution in use..
have a nice day
Jun 26, 2011 | Computers & Internet
Pictures Too Large to Email ?
You've got several options here.
1. Set the resolution in the camera. Press the Fn button, then select Size. The smallest choice is 1024x768, which is less than one megapixel. But if you just happen to spot that UFO, you won't get very good pics of it. And if all you wanted was 1MP pictures, why did you bother go get an 8MP camera?
2. Resize the picture on the camera. Press the E(ffect) button, then select Resize.
3. Do the resizing on the PC. Both Windows Photo Gallery and iPhoto have this capability. In some ways this is the best option, since you get all the pics in high-res, just in case that UFO shows up in a corner. And when you send email, you're probably sitting at a computer anyway.
Feb 08, 2010 | Samsung S860 Digital Camera
Black colour displaying become greenish and narrow vertical lines
Most LCD monitors have a default refresh rate of 60 Hz. Older monitors also have limited resolution. Please check your display settings and ensure you're not using a refresh rate higher than 60, or a resolution higher than what it supports. If either one is the case, you're lucky the LCD still works.
Aug 12, 2009 | Computers & Internet
Acer AL 1912 (black) resolution issue
[u][b]LCD Monitor Shadow Effect[/b][/u]
This problem is best described as the LCD monitor "Shadow Effect".
The solution to this very simple. No software or hard ware changes required.
The cables that are connected to the LCD monitors are causing the problem. Its also called as electromagnetic noise or electrical noise.
[u][b]Solution: [/b][/u]Keep the two cables - (power cable and moitor display cable), that are connected to the LCD monitor as far away as possible with each other and also away from other electrical cables.
Thats it. Your shadow effect is fixed.
Thank you.
May 27, 2009 | Acer AL1912 19" LCD Monitor
My pictures are too big to load
You have two options:
First: use a picture management software to resize the pictures to a smaller resolution such as 640x480 pixels.
Second: reduce resolution on camera. The smallest resolution possible is 1024x768 on L200.
To do so in your Samsung L200, press Fn button. Then scrool up or down until you see SIZE on-screen. Press button to right until 1M appears, then press OK.
Oct 27, 2008 | Samsung L200 Digital Camera
Internet pages not in widescreen
display resolution incorrect go to display settings and resize the screen until it is wide as the monitor, 5 inches thats allot of blank space...
Apr 30, 2008 | Computers & Internet
A very thin vertical brun line in the middle
If it's a straight vertical or horizontal line always in the same place it's a panel issue which the average user even with repairing skills will not be able to reliably repair ,Sorry.
Samir
Feb 25, 2008 | Dell UltraSharp 1905FP LCD Monitor
Monitor displays only horizontal line
hey bro.
you try to re solder the vertical section and the color section.
Oct 16, 2007 | SAMTRON 55V 15" CRT Monitor
How to Adjust the sceen ratio from 16:9 to 4:3
Since it's a widescreen monitor, the streching is likely from using a 4:3 ratio resolution on a 16:9 ratio monitor. Try setting the operating systems display resolution to 1440x900, since that's your monitor's native resolution (LCD monitors only really have one resolution). In Windows, resolution settings are found by right-clicking on the desktop, click properties, and go to the Settings tab.
Aug 05, 2007 | Philips 190CW7CS27 Monitor
Nokia 447Xi (White) 17" CRT Monitor Logo
532 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
