Question about Ruud UBHC Air Conditioner
Can i plaese have pictures for servicing evaprative air con roof mounted
    President:
  • 3,433 Answers
No need for pics. The four panels with the matting come off by lifting/sliding the panel upand out towards you. The Matting rinses off with the garden hose removing accumulated dit. The pan can be washed out also. There should be no need to adjust the float, but make sure the pump is clean and submerged. The fan can be cleand, but is a messy job. Pt the matting panels in place ,bottom first and push in and dow. That's it, you are done.
Posted on Nov 19, 2009
Can I recharge a Duo Therm 600315.001 RV Roof mounted air conditioner? It uses R22 refrigerant. If not, where can I find a replacement or can it be serviced somewhere?
I would suggest that you visit an ac specialist shop as all air conditioners( car, truck , house and yours all use the same principle of operation
because it is roof mounted in an RV may be a caravan repair shop that has an ac specialist in the workshop or a truck service shop that installs ac units in truck cabins would be a good place to start
Mar 13, 2016 | Dometic Heating & Cooling
Does the inside control panel for a roof top bonaire evaprative cooler have fuses. if yes how do i open the cover?
At least one fuse should be in the house meter box, otherwise on the roof, you must lift the element side panels up (there should be tabs to grip along the edges), pull/swing the bottom of the element panel out and down to remove them, repeat for each side, fuse may be on an upright corner toward the top near the isolator switch.
Sep 29, 2014 | Cars & Trucks
How to remove roof rail mounts
Removing roof rail mount can cause roof damage. And i think you just be careful while removing rail mount. You just need the screw driver and obviously little bit of effort. And in case you make your roof damaged then you should quickly apply Liquid Roofing
Liquid Roof AND RV Roof Coatings
Mar 02, 2014 | Cars & Trucks
Wiring diagram needed for carrier air con unit
Here ya go:
http://www.xpedio.carrier.com/idc/groups/public/documents/techlit/38ckc-c2w.pdf
May 27, 2010 | Carrier 38CKC036 Air Conditioner
How do find the roof rafters in a pop top.
Hi; Try using a electronic stud finder and switch to metal detection. Or maybe call or google the company that built the popup. Sometimes they can tell You exactly where to make Your cuts...alpharome416
Feb 10, 2010 | Dometic Rooftop RV Air Conditioner
LOSS OF GAS IN AIRCONDITIONING SYSTEM
air con gas will evaprate form the system over about 3-4 years anyway, nost good garages will recharge it for a minimal fee and some will even refund you if they find a leak while filling. if it happend suddenly then you have a leak and again this can be fixed by most good garages. hope this helps
Dec 17, 2009 | Ford Laser Cars & Trucks
Mounting
rosen do a double stepped mounting bracket which fits in place off the rear air con controls, these controls fit into this new spacer and the screen then fits onto this spacer
Jun 04, 2008 | XO Vision 12.1 Flip-Down Monitor w IR"
Dometic roof top air-con trouble
1.check wiring of unit.
2.check drain tray.
3.check u band of drain pipe.
Feb 16, 2008 | Dometic Rooftop RV Air Conditioner
Ruud UBHC Air Conditioner Logo
24 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
