Question about Samsung HP-T4254 42 in. Plasma Television
My Samsung plasma TV just developed 60 cycle hum. I checked all the connections, no luck. Any suggestions?
    President:
  • 1,284 Answers
If you have a cable box connected to the TV disconnect that from the TV and see if the issue goes away. If it does then I suspect there is A.C> leakage in the cable box or somewhere in their wiring. Please take a few moments to rate my answer. Thanks...
Posted on Nov 19, 2009
My Samsung Plasma TV just made a popping sound and then shut off. It will not come back on.
Popping sounds from plasma tv's are almost always caused by a blown sustain board ( Y,Z, or both). It could be a main power supply also. Have a technician check it out.
Feb 12, 2017 | Samsung Televison & Video
Samsung plasma tv white screen repair
You have a shorted main board in the TV, it is more expensive to repair this than to replace the TV at current TV flat screen prices. Also I suggest the brand Vizio, it has the bet reliability ratings of any brand hands down.
Aug 11, 2016 | Samsung 50 in. Plasma TV
Making a soft humming noise on start up and shut off
If you have a device connected to the tv.please disconnect them all.try connecting tv directly to a power outlet.can u elaborate the humming noise.
Dec 31, 2014 | Samsung HP-R5072 50 in. Plasma HDTV
Samsung plasma tv humming
apply slight pressure to various parts of the back cover and see if it stops. The HP-T5084 model has a humming problem as well. It comes from two cheesy ground clips that "ground" the metal back cover.
Feb 12, 2013 | Samsung HP-T5044 50 in. Plasma TV
My DLP HL-P5663W TVhas developed a hum similar to an AC 60-cycle hum. This is unrelated to any speaker, and seems to emante from the vicinity of the lamp. Have replaced the lamp, but hum persists. What is...
This may be an issue with the color wheel. My thoughts is that the motor that runs the color wheel is going out. May be time to get it in to a Good TV Repair Service Shop.
A/V Media Tech Guy
Nov 25, 2009 | Televison & Video
Scrolling line
Question. Are the scrolling lines horizontal?
If so that is called 60 cycle Hum Bar and is a result of the following:
1. Bad grounding of the cable system.
2.Bad cable box. This a common problem with cable boxes.
3.If you are using Component cables from the cable box to the tv then the Component cables might be bad. Try using another set of Component cables. If that does not work then you need to call the Cable co. to come out and check their system and make sure that the cable tech brings out another cable box to try out. There is no problem with the set.
Jul 15, 2009 | Samsung HP-S4273 42 in. Plasma HDTV
PN50A450 Samsung green screen problem
This is a problem in one or more boards in the TV.
If your TV is still under warranty please call Samsung to get if fix at not charge.
parts for your tv are not cheap and labor is not eider.
Jun 15, 2009 | Samsung PN50A450 50 in. Plasma HDTV
321System No sound just humming with TV connected to Video1 or 2
Hi...
Get new audio cables . It seems there's a broken Ground (shield ) wire somewhere in the cable. NO ground means HUM usually
Dec 30, 2008 | Bose (321GS) System
Samsung HP-T4254 42 in. Plasma Television Logo
295 people viewed this question
Henry  Thomas
Henry Thomas
