Question about Samsung T349 Cell Phone
CANT ADD A NEW NETWORK....................CLARO! I NEED TO FIND THE IP ADDRESS OPTIONS
I am unable to install hp laserjet M2727 nf MFP in the network. i don't know how to install it on the network? please suggest me the steps .
Hi
This is very easy setup to install the network printer. first to set the your desire network IP address in your printer.follow the mention option enter the Ip address.
  1. Press the Menu button.
  2. Press the Down Arrow to find Configure Device .
  3. Choose Configure Device .
  4. Press the check mark button.
  5. Choose I/O .
  6. Press the check mark button.
  7. Press the EIO (1 or 2) Jetdirect Menu .
  8. Press the check mark button.
  9. Choose TCP/IP .
  10. Press the check mark button.
  11. Choose Configuration Method .
  12. Press the check mark button.
  13. Choose Manual .
  14. Press the check mark button.
  15. Select Manual Settings .
  16. Choose IP address .
  17. Press the check mark button.
  18. Enter IP address with keypad.
  19. Press the check mark button.
  20. Choose Subnet Mask .
  21. Press the check mark button.
  22. Enter Subnet Mask with keypad.
After assign the IP addres in printer. connect to your printer with router or switch. and insert you HP Installation CD in Rom,
Go to the Control Panel and select Printer and Faxes click the "Add Printer"the new Add printer wizard open click next and remove the check mark in " Automatic detect and install the Plug and Play printer" click next, then you get "Select the printer port screen" Click create New port and choose Standard TCP/IP and click next.
You will get another New windows " Standard TCP/IP Add Printer Port" click next and put the Printer IP Address click next and next, Finish.
Now the windows will appear " Add Printer Wizard" click the Have Disk " and choose the .Inf file for your Installation CD, and Click Finish.
Your printer will install and the test will come.
If my solution solve you problem then give me four thumb
Cheer
Jul 12, 2011 | HP Laserjet M2727nf Multifunction Printer
Tip
How to change the IP address on a Ricoh Aficio C811 printer
With the use of a DHCP (Dynamic Host Configuration Protocol) server, you can automate the administration of IP addresses for printers. However, you may want your printer to have a static IP address. To set up a static IP address on a Ricoh Aficio C811 color printer, follow the steps below.
1. When the printer is powered on and ready, press the Menu button.
2. Using the up or down arrows, scroll down through the menu to Host Interface and press OK.
3. Scroll down to Network and press OK.
4. Machine IPv4 Address is the first option on the network menu; click OK when it is highlighted.
5. You will see two options -- Auto-Obtain (DHCP) and Specify, and below them are three tabs -- IP Add., Subnet M, and Gateway. Scroll down so that Specify is highlighted, and then press the arrow button below the left-most tab (IP Add.).
6. Using the up and down arrows to change the numeric value, enter the IP address you want to use for the printer. Use the side arrows to go to the next part of the address once you've entered the value for the current octet.
7. Once you've entered the complete IP address, press OK. (If you want to cancel out without saving the new address, press Escape instead.)
8. If you need to specify a subnet mask and gateway address, you can enter those values in the same way, by selecting each of the corresponding tabs on the IPv4 menu (Subnet M and Gateway, respectively).
9. After you've entered all of the information and saved each address, make sure Specify is highlighted and press OK. You should see "Programmed" displayed on the screen.
10. Turn the machine off and then back on to apply the changes and reset the network connection.
on Mar 17, 2011 | Ricoh Aficio SP C811DN Laser Printer
I had the printer working fine, and then it decided to give me an error message. My computer is on the network, but the printer is not on the network, and I cannot figure out how to add it. Yes, I have...
Go to the printer and print out the Configuration Page. Find the IP address of the printer and try to ping it from the computer. If you can ping the IP address then we need to setup your computer to print to the right IP address. If you cannot ping the IP address then there is an issue with the Printer. Go to the printer and try to find out if the IP address is set to manual or automatic, if manual then set the IP address, Sub-net mask and Gateway to your network settings. Reboot the router and try to ping again, this should allow you to ping the printer.
Now on the computer add the printer locally to the computer using the IP address as the port. You might need to add the port if it does not already exists.
Mar 08, 2011 | HP Color LaserJet 2600n Printer
How to make it a network printer
Hello Sir,
1. First, connect the printer to your network by connecting one end of a Cat 5 cable (which should have come with your printer) to your router
And the other end into the network port of your printer. Turn your printer on and wait for it to become ready.
2. Next you’ll need to get the IP address of your printer. The IP address is what will tell your computer
where to find your printer on the network. All network printers allow you to print a configuration sheet which will list basic information about the printer along with the current network configuration.
For most printers, this involves pressing the Menu button on the printer, going to the Information option and choosing Print Configuration. You will be looking for the TCP/IP section:
The IP Address is what you’ll need for the next steps.
3. The last step is to add the printer to your computer. Click on Start, then Printers and Faxes.
If you don’t see this in your Start Menu, you can go to Start, Control Panel and then click on Printers and Faxes there. Click Add Printer from the task pane on the left.
The Add Printer wizard will begin, so click Next to get started. On the next screen you’ll be asked whether your printer is a local printer or a network printer. These options are confusing because a network printer is actually referring either a printer connected to another computer or a printer on a print server
. Our printer is a stand-alone printer and so you must select Local printer attached to this computer and make sure that you uncheck the box for automatically detecting the printer.
Click Next and you’ll be asked to select the printer port. Since our printer is a network printer with a IP address, we need to select the Create a new port option and choose Standard TCP/IP Port.
Click Next and you’ll get another wizard to add a TCP/IP printer port. On the main wizard screen click Next. In the first text box, Printer Name or IP Address, enter the IP address from the printer configuration sheet you printer earlier.
Click Next and depending on the printer you have, you may get one more dialog before the end of the wizard. If the network card
for the printer cannot be identified, the wizard will ask you to choose the card type. You can leave the default of “Generic Network Card” and click Next.
Click Next and click Finish. You will then continue on with the Add Printer wizard and you’ll need to either choose the printer from the list of manufacturers or click Have Disk and insert your printer driver cd in the computer.
lick Next and enter a name for your printer and click the Yes radio button if you would like the printer to be your default printer.
Click Next and you’ll be asked whether you want to share the printer or not. Click No because anyone else who wants to connect will be able to do so following the same steps.
Click Next and click Yes to print a test page and make sure that the computer and printer can communicate!
Click Next and then click Finish! The new printer will appear in your Printers and Faxes screen and you’re ready to print!
[tags]network printing, install network printer, install network printer in Windows, network a printer[tags]
Jul 07, 2010 | HP OfficeJet 6210 All-In-One InkJet...
I CANT SEND MMS IN MY K770I
U need to activate mms service by calling ur service provider and these are the settings fo the same.
Press “Menu” and go to “Messages”
Select “Settings” and select “Multimedia messages”
Select “Network settings”
Select “Options” and select “Add new”
Enter the profile name as “service MMS”
Press “Ok” and select “Options”
Go to the “Settings”
Enter the details as follow:
1. Homepage: Define homepage here.
2. Bearer: GPRS
3. GPRS settings
APN: Define acess point name here.
User ID: <blank>
Password: <blank>
4. Proxy settings:
Proxy settings: On
IP address: Define Ip add. here.
Port: 9210
5. DNS settings: <Leave it as default>
Press “Ok” to save the settings and return to the main settings and select ‘Activate”
MMS configuration completed
Good luck
Jun 30, 2010 | Sony Ericsson K800i Cellular Phone
I cant connect my wireless laptop tp my comp.
Let me know the settings of your Router if needed IP address?
Yes - add your IP address into Network Connection.
No - obtained the setting in your Network Connection.
How to Add or Obtained the setting s of your IP address:
- goto Control Panel
- Double Click Network Connection
- Rigth Click then Properties the Local Area Connection
- Select Internet Protocol (TCP/IP) and select Properties
- Under General Tab they have choices to add or obtained settings.
Sep 20, 2008 | Linksys Wireless-G WRT54G Router
How to set a static IP address in Windows behind a Linksys Router
Sorry mate but you have kinda lost me here, if you need a static IP address for the internet you need to contact you isp and they will provide you one, if you want to set your machine to set IP Address just go into properties for local network connection and use somthing like 192.168.1.1 255.255.255.0 and leave the dns to obtain. but you wont be able to set a internet static ip address by doing this, only way is to contact your isp.. All the best John
Feb 16, 2006 | Linksys BEFSX41 Router (DHBEFSX41)
Samsung T349 Cell Phone Logo
57 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
