Question about Sharp AR-C160 Color Copier
Check Developer Unit Y and C - Sharp AR-C160 Color Copier
    President:
  • 3,085 Answers
You need a new Yellow and Cyan Developer Unit.
Posted on Nov 20, 2009
How do I fix error code 2422 for konica minolta c6500
Magenta drive motor, has the magenta developer been replaced? has a PM been done on the machine did the technician use a vacuum cleaner to remove the old developer from the magenta developer unit if so he or she could have destroyed the sensor at he bottom of the developing unit NEVER use the Vacuum cleaner to remove old developer the Static electricity fro the vacuum cleaner will destroy the sensor. Check electrical connections for the magenta in unit (One connection) reseat the Magenta developing unit ensure that both guides holing all four developing units are properly installed and that all eight springs behind the guide are correctly installed. Mite want a tech to check the magenta developer motor in 47 Mode. also check signal for the Magenta ATDC Also run the required tests after any one developer is replaced May have to redo the Magenta developer again.
Sep 03, 2014 | Konica Minolta bizhub Office Equipment &...
What is error code c/6 400 on koycera km2020
Developer unit
MCY
1. Check that the developer waste lock has
been released and, if not, release the
lock (see page 1-2-15).
2. Check that the gears and spiral screw of
the developer unit are not damaged.
3. Confirm that the developer roller can
rotate.
4. If it won't rotate, replace the developer
unit (see page 1-5-57).
Developer motor
MCY
1. To check the motor operation, execute
DLP(MCY) by U030 (see page 1-3-34).
2. Check the drive gear can rotate or they
are not unusually loaded and, if
necessary, replace.
3. Confirm that the wiring connector is
firmly connected and, if necessary,
connect the connector all the way in.
Developer motor MCY and Motor
control PWB (YC7)
Motor control PWB (YC3) and Engine
PWB (YC9)
4. If the wiring is disconnected, shorted or
grounded, replace the wiring.
5. Replace the Developer motor MCY.
Motor control PWB Replace the Motor control PWB
Engine PWB. 1. Check the engine software and upgrade
to the latest, if necessary.
2. Replace the engine PWB (see page 1-5-
80).
Aug 07, 2014 | Kyocera Office Equipment & Supplies
Error code 7410:0167274 on a Kyocera FS2000D, what does this mean?
The 7410 indicates a drum error (see below) the 0163053 is the number of prints made by the printer. The drum was most likely knocked loose when installing toner.
Drum unit non- installing error -
The drum unit is not installed or not installed properly.
Detaching and refitting the developer unit Procedure
1. Open the top cover.
2. Open the MP tray.
3. Remove the developer unit.
4. Check or replace the developer unit and refit all the removed parts.
Detaching and refitting the drum unit
1. Remove the developer unit.
2. Open the left side cover and then remove the waste toner box.
3. Unlock the drum unit lock and then remove the drum unit.
4. Check or replace the drum unit and refit all the removed parts.
I hope this is helpful,
Shawn
Jun 10, 2011 | Kyocera FS-2000D Laser Printer
Kyocera FS3900DN changed toner and got error 7410:0163053 to call for service
Shawn
Feb 25, 2011 | Kyocera FS-3900DN Laser Printer
HI there! Our Kyocera 180 does not photocopy documents. The paper that comes out is just blank. We recently replaced the tonner so we believe there's still enough ink. Should we checked if the photocopier...
if you are getting blank copies nothing on the page you need to check the drum main charge or the developer unit is locked into place correctly and if the developer unit is turning take out the developer unit and see if there is an even coating of dev and toner on the roller use a piece of paper rub of a small are on the developer roller put in the machine and do a copy after take out the developer unit and see if where you marked is visable if it is then the developer unit has a problem as it is not turning
Check the main charge roller it is connected to the side door
Feb 05, 2011 | Kyocera TASKalfa 180 Copier
My copier sharp5316 has error code of f2 pls help me on this.
That is normall a defective developer unit chip, you may have to replace the chip on the developer unit or the developer unit itself.
Aug 17, 2010 | Sharp AR-5316 Advanced Digital Imager...
Ar-5316 showing error ch
CH steady means cover is open. Close either front or right cover well.
CH blinking means developer unit or toner cartridge not installed. Remove and return well and firmly.
Nov 22, 2009 | Sharp AR-5316 Advanced Digital Imager...
Developer leakage while copying
after replace  developer you dont turn round the developer wheel left side. only right side.try this take out the developer and after re fill in to the developer unit. and u change the main charger unit also.
Feb 06, 2009 | Toshiba e-Studio 161 Copier Copier
Sharp SF-2014 developer
Hello Gus,
IF the Toner/developer is spilling out towards the rear of the machine then the developer unit is going bad. A common problem with this model was the rear bushings in the developer unit would wear out and start to leak. If you take the developer unit out of the machine, put down some newspaper, and tip the developer unit (OVER THE PAPER) about 15-20 degrees towards the back and see if the Developer/toner leaks out any. If it does then you found the problem.
If it doesn't then you might just have an over toning problem. To check to see if you have an over toning problem, please the developer unit ON THE PAPER, get a philips screw driver, and put it in the rear White gear. You will see a series of gears but there is only 1 that is the located on the END of the Roller with the toner/developer on it. TURN IT CLOCKWISE about 1 turn and see if you see toner spilling out.
If you do, then your machine needs a Developer change.
Hope this helps.
Let me know if you have more questions.
If you need parts for this machine, I have a couple contacts that I can give you and you can see if they have the parts in stock.
Good Luck.
Mac
Jun 26, 2008 | Office Equipment & Supplies
Sharp AR-C160 Color Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
