Question about Canon Video Cameras
Can you erase the tape on a canon zr40 digital video camera so i can start over
  • 405 Answers
You don't have to erase the tape, just rewind and start recording over existing video.
Posted on Nov 20, 2009
SOURCE: canon zr video camera
I have the same problem with my zr200, its driving me nuts!!!
Everything looks and seems fine. Without a tape it works perfectly. With a tape it wont retract and it says to remove the tape. It just started out of the blue, no warning.
Posted on Jul 08, 2008
  • 57 Answers
SOURCE: tape not loading
Chances are it is in need of a major cleaning. Usually by the time this happens the cleaning tape will do no good. A good internal cleaning is usually the only thing that will help it........Has it been droped? If it has then you could need repairs
Posted on Jan 04, 2009
zohail
  • 1223 Answers
SOURCE: During playback, only seee a blue screen.
kindly rate me if ui have helped u !
i hope ur problem gets solved
Posted on Apr 24, 2009
  • 11 Answers
SOURCE: Canon ZR-800 Mini DV Camcorder tape stuck
The way I can get a tape unjammed on my Sony camera is to remove the battery, plug the camera into the AC charger that is plugged into the wall outlet. Then power the camera on, wait a few seconds. Then unplug the charger from the outlet, wait a few more seconds (camera still in "on" position) and then plug it back in. I have used this method at least 3 times to get the camera to release the tape and finally eject. However, the tape is usually pulled or stretched and I use a small flat head screwdriver to wind the tape back in, but expect that portion of the video to be ruined.
Posted on Sep 09, 2009
supertech6
  • 513 Answers
SOURCE: cannon zr100 digital video camera tape compartment
This is caused by problems with the mechanism. There should be an indicator on the LCD screen when this happens. If the indicator shows a teardrop, it means the unit thinks it has moisture (dew sensor).
The most likely fault is a defective capstan motor, the motor that moves the tape through the camera. Time for a Canon service center.
Posted on Mar 28, 2010
How do I turn on digital effect
Press the DIGITAL EFFECTS and select D.EFFECT from the Digital Effects menu. If needed, you can find a copy of the User Manual on the Canon website:
Canon Support Drivers ZR40
Apr 24, 2014 | Canon ZR40 Mini DV Digital Camcorder
Can you copy your tapes to a computer?
Hello friend,
The Canon ZR40 Mini DV Camcorder has the port "Firewire" so you can copy your tapes to a computer. you will need to check your computer if it has also a firewire socket (All the new laptops have it).
You don't need any drive software, Windows has all the necessary drivers built in. You can use Windows Movie Maker for the capture, but if you want to burn your finished movies onto DVD then look at something like Adobe Premiere Elements 4.0 which is one stop shop application (Capture,edit and burn). you can download a 30 days trial and try it out and see if it's what you want before buying it.
Best Regards,
Oct 30, 2009 | Canon ZR40 Mini DV Digital Camcorder
Apr 18, 2009 | Canon ZR40 Mini DV Digital Camcorder
Canon zr40 stuck in pause mode
Remove the battery.   Wait 10 seconds.  Put it back in and see if that resets it.
Sep 09, 2008 | Canon ZR40 Mini DV Digital Camcorder
How to record
Checkout this manual(click here). it has everything that you ever need to know about your camera.
Aug 30, 2008 | Canon ZR40 Mini DV Digital Camcorder
Re: Canon Digital Video Camcorder ZR70 MC DC 7.4V
hello,
As your camera only has analogue outputs, you will need to buy a video capture card for your PC, such as those made by Leadtek. As mentioned by Tela above, there are also external USB-connected devices that do the same job.
Make sure your PC exceeds the minimum spec or you may lose information during capture. I would recommend at least 1GHz processor.
Hope that helps.
Jul 31, 2017 | Canon ZR40 Mini DV Digital Camcorder
Canon ZR40 would not turn on
The battery is probably so dead it is using all the power from the wall supply.  Remove the battery, and run only from the wall supply.
Dec 16, 2007 | Canon ZR400 Mini DV Digital Camcorder
Video Cameras Logo
106 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
