Question about IBM Thinkpad 560 Series Laptop 20h4241 Keyboard
Letter Y popped out and I lost a white plastic piece to pop it right back. Can i buy it?
    Problem Solver:
  • 10 Answers
Take a look on ebay, if not look for a faulty keyboard around $10 and use the key of that
Posted on Nov 19, 2009
White macbook 10.5.8 pop spilled on keyboard
Ooouch ! After you've dabbed up (the spill) as much as you can, you may find some keys sticking ... i.e. when you touch (push) it (down), it doesn't pop up immediately. These are the keys you'll want to clean individually.
You can pop off the key top off (with your fingernails) from the top corner of the key. Once the key-cap top (cover) is pried open, lift the key-cap upwards and detach it from the bottom edge. You'll hear pop's when you do this. Once the key-cap is off, you'll see the mechanism under it. You'll want to clean things as best as you can ... very carefully. If the underside of the key top (cap) is sticky/dirty, rinse/wash it (with water), dry it well (before reinstalling it). Often the "stickiness" is caused by the (white translucent) plastic pieces (at the very top) not dropping flat down (immediately) after you lift it. (You wouldn't want to disassemble the parts below the (white translucent) square plastic pieces. Just clean/wipe it carefully using a cotton swab/toothpick).
You can remove the top (square plastic) pieces by pushing the tabs at the bottom corners ... downwards ... using a toothpick. This "top" square piece is actually two (square) pieces (snapped together), one inside the other. The inside piece is supposed to spin easily/quickly .... if not. it's probably sticky/dirty, rinse/wash it (with water), dry it well (before reinstalling it).
The trick is to make sure you know/remember how to reassemble the 2 pieces (after taking it apart and washing/rinsing/drying it) applying the right connection points to fit ... before you put the key-cap back on . The key-cap is put in place by just putting it in place and pressing down to snap it back on.
The larger keys (Shift, Space, etc.) has metal bars holding down the cap, etc., so it may take more effort to pop the key top (cap) off.
If you have quite a few to do, and you don't want to risk breaking anything, the Apple store is probably your next stop.
Oct 26, 2013 | Computers & Internet
The letter "C" popped off
Hi Madelaine_an,
I'm sure that when the letter popped off, two white plastics also came off beneath the letter. Now if you kept them and did not throw them away, you have to first fix both of them, one facing up, the other facing down. There are two insertion points on the missing space on your key board where they are to fit into. These white plastics have edges on them, and can be a little bit depressed to fit into their insertion points, where they expand to fill it after fitting. They are designed such that when you see them you would know which goes into what direction. If you try it one way and it doesnt fit in, then you are trying it wrongly. Reverse the directions. After you have done that, get your letter 'C', and press it into the white plastic. If you fixed the white plastic well, the key should lock into it, but be flexible, ie move up and down.
I hopoe that was able to solve your problem? I would appreciate a rating.
Have a nice day.
Jun 26, 2011 | Dell 0Y3740 Keyboard
Washer will not begin spin cycle
Hello,It needs a drive coupler for the motor/transmission.
Unplug machine. Just lean the machine back, pop the two clips on the pump and put it to the side. Take the two screws out of the motor clips (usually 1/4 inch), and pop those clips off. Motor will come off. You will see the 3 fingered white piece on the motor shaft and one on the transmission shaft. There is a rubber coupler that connects the two. Replace which ever white plastic piece is broken, or the rubber piece if that is it. Make sure not to bang the white plastic piece too far onto the shaft. The shaft should go flush with the white plastic part facing you. Put motor and pump back together and plug in motor.
Thanks
May 23, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
My kenmore washer will not spin the motor sounds like it's starting the spin cycle but the drum does not move.
Unplug machine. Just lean the machine back, pop the two clips on the pump and put it to the side. Take the two screws out of the motor clips (usually 1/4 inch), and pop those clips off. Motor will come off. You will see the 3 fingered white piece on the motor shaft and one on the transmission shaft. There is a rubber coupler that connects the two. Replace which ever white plastic piece is broken, or the rubber piece if that is it. Make sure not to bang the white plastic piece too far onto the shaft. The shaft should go flush with the white plastic part facing you. Put motor and pump back together and plug in motor. You should be good to go. http://www.youtube.com/watch?v=WLPGs2UMUJc
Jan 12, 2010 | Washing Machines
Washer will not spin in any cycle but motor runs and pumps out.So lid switch is good? what shifts to spin a sol?
Jan 11, 2010 | Whirlpool LTE6234D Top Load Stacked...
WONT WASH OR SPIN
Jan 11, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Popped a key off my Dell Inspiron laptop keyboard by accident.
You should be able to just pop off another key from your keyboard using a flat screwdriver. Then just compare how that key looks and reassemble the plastic components and the key just snaps back on. Also you may want to check your warranty at support.dell.com under warranty status and enter your service tag. If you are under warranty dell will replace it. Also ebay dell keyboards are cheap to buy and easy to install just two screws and a simple cable. If you need more help let me know.
Nov 30, 2009 | Dell Inspiron 6400 Notebook
My T popped off key cap and I need instrutions to put it back on.
It just snaps right in. just make sure it's right in the middle and snap it in. If it doesn't work, make sure it's being aligned correctly, but like I said, it should snap back in.
Nov 21, 2009 | HP D8597A Keyboard
Wires hanging in ice maker area
Look underneath the 2nd row from left in the ice tray there should be a white plastic piece that pops in and out from the bottom of the ice tray. Pop it off. There should be a piece of styrofoam on top of the piece you removed. the white wire runs along the bottom of the ice tray there may be little plastic hooks to place wire along the way. The sensor should fit right where the white piece of plastic and styrofoam you removed goes. Just place it there and pop that piece back in. It really doesn't attach to anything just lays there.
May 26, 2009 | LG LSC26905TT Side by Side Refrigerator
Key popped out
no do not glue anything this will couse more problems just try to pop them back in if totally broken then you will need new keys
Nov 03, 2007 | Dell Inspiron 6000 Notebook
IBM Thinkpad 560 Series Laptop 20h4241 Keyboard Logo
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
