Question about Sony Televison & Video
Some dvd's fade in and out and the picture scrambles a little when this fading happens. Not all dvd's do this. Have tried a cleaning disc, but it didn't help. Is there a problem with the player?
4 Suggested Answers
fairlane
  • 50 Answers
SOURCE: My DVD player is, quite literally, on the blink...
Hi Your problem is Copy protection on your DVD's! Without going into techno-bable, your DVD player detects that you are connected to a VCR, (You have no choice in your case as it is built-in), there are methods such as "Copyguard" and "Macrovision" that try to stop you from copying your favorite DVD onto VHS. The audio is left alone, but the video will go bright and dim, and the colors will be messed up, making the result un-watchable. You will find that the cheap DVD's you get for a couple of bucks at the discount store will play fine, as it would be too expensive to protect them. There are "little black boxes" available as "video stabilizers" that will cure this problem, (but you didn't hear that from me!),otherwise you must connect into a t.v. without a built-in VCR. P.S. Make sure the t.v. you switch to has RCA type A/V inputs on it, as you will have to purchase a separate RF modulator otherwise. Good Luck!
Posted on Aug 15, 2006
Ikarus
  • 10 Answers
SOURCE: No valid disc
the codes might have got switched somehow (region codes.) go to this site www.videohelp.com/dvdhacks.php follow the instructions.....I hope this helps!!!!
Posted on Jul 24, 2007
  • 4 Answers
SOURCE: Can't Read Disc
You could try updating the firmware.
Posted on Jul 29, 2010
I hooked an Apex DVD player to my Quasar TV-VCR Combo and when I try to play a disc in the dvd the picture fades in and out
That is due to the copy protection circuitry built into the VCR. It was originally deigned to keep people from making pirate copies of VHS tapes, but the circuitry will sense that what you are playing is prerecorded copyrighted material and will do the picture fade thing.
Dec 13, 2013 | EliteGroup P965T-A Motherboard
Picture fades in and out
If only on some DVD's may not be the unit, possible issue when recording etc---the unit is not smart enough to only fail on certain discs unless it happened during recording---a mismatch of some type.
Dec 04, 2012 | Panasonic DMR-ES10 DVD Recorder
My Vizio LCD TV screen fades to dark. Sound stays on.
I w having this same issue when watching a Blu-Ray disc. I found it to be dependent upon what picture mode the TV was set to. By this I mean certain picture modes would cause the TV to dim during dark scenes of a movie. Changing the picture mode helped a lot.
Feb 28, 2010 | Vizio VW42LF 42 in. LCD HDTV
My game fades to black and doesnt go away
Sounds like a disc error. I'd check the disc or if possible, go grind levels a bit somewhere and return to the commencement, it might free up the problem. Square Enix sometimes let little things like this fall through the cracks on otherwise awesome games! If nothing else, just borrow a copy to get through that area then you should be good to go!
Sep 12, 2009 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Won't read disc
Common issues causing the dirty disc error are: dirty lenses, lasers wearing out over time, capacitors failing on the control board, grease on the rails the laser slides back and forth drying out, and using non pressed (burned) media that fades over time.
Sounds like you have tried cleaning the lens and I am assuming this is happening to all your media. So I would say that it probably needs to be replaced because lasers and other internals are not user serviceable. Especially when dvd players are so cheap now.
doesnt look like your alone by this post.
there are many lost cost options for replacement
Mar 23, 2009 | Sony DVP-NC615 Multi-disc DVD Player
Akai DVDP5851 "looding" than "no disc"
The laser pickup unit weak. Replace it. Contact any service technician. http://electronicshelponline.blogspot.com/
May 30, 2017 | Akai DVDP5851 DVD Player
When watching dvd having showing or fade background
yes it can be down to signal degradation especially via scart lead, make sure you use a decent scart if you buy an expensive one you can tell the difference. Run a cable from your sky digibox direct to your tv to see if the picture improves.
Oct 05, 2007 | LG 42PX4DR 42 in. Plasma TV
Some DVDs fade in and out
If you have it hooked up through your VCR this will happen. Try hooking it directly to your TV.
Jun 09, 2007 | Toshiba SD-K620 DVD Player
Fading light problem
need more info but sound as a power regulator problem..good luck
Jul 26, 2006 | Apex Digital AD-1110W DVD Player
Picture keeps trying to black out
Hi I have seen this problem before, and it was the video processor. I have seen the picture fade to black, then come back, and also fade to green. The cost to repair is prohibitive unless you could find a shop that perhaps has hung on to a unit that was hit by lightning, and only has a blown power supply. The only ray of sunshine I could offer, is if you recently connected your unit to a vcr, because the effect you describe is also what appears when you try to play a dvd that is copy guarded. If your DVD player is connected to a vcr then to the television, take the VCR out of the loop, connect straight to t.v. and all will be well. Goog Luck!
Jul 16, 2006 | Toshiba SD-K741 DVD Player
Televison & Video Logo
136 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
