Question about Kenmore Elite HE4 Electric Dryer
Drive belt has broke mod# 7691100 ser # F84420622 kenmore dryer what is the belt part# to replace it
  • Kenmore Master
  • 7,482 Answers
Try these two website, I am sure they will have what you need. They also have a chat line and it is open 24/7 Good luck, I hope this helps
http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx
Posted on Nov 20, 2009
Have a Kenmore Elite Dryer that won't start. Mod 110.65962401 Ser MS0303258 Type DDOT-ELE-2406028-CV54
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 22, 2011 | Kenmore Elite HE4 Electric Dryer
I have a Kenmore dryer, mod 110 60956990, ser MJ4102370, type DDOT-ELE-2406028-EH54. When I push the button to start the dryer, nothing. If you wait several minutes, it sounds like it is trying to come on...
heatman101
Oct 28, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
Want a wiring diagram for hotpoint dryer, mod#DLB2750BAL.ser#AD 209876H dryer wont run after starting
Make sure the belt is good. These dryers have a belt switch located near the motor. If the belt is broken the dryer will not run.The belt switch could be bad also. Also check the door switch.
Verify 220 volts of power at the terminal where the cord attaches to the dryer.
Feb 11, 2010 | Hotpoint Dryers
I have a broken broken belt but can't get replacement around tension pulley. Kenmore Dryer, Mod: 110 62612100, Ser ML 2202910, Type: DWRJR-ELE-2406028-FM54 Thank you
Make sure you have the correct replacement belt first. If you still have the old broken belt, measure it with a tape measure and do the same with the replacement. The new belt may be slightly shorter because the old one will have been stretched with use. Also check the part numbers again, but Kenmore changes numbers sometimes so that isn't always reliable.
The tensioners can be a little tricky sometimes. You can loosen it up if need be, then install the belt, hold the tensioner in place and tighten it back up. During re-installation, try to keep the belt as straight as possible around the drum so it doesn't take up more space, making it more difficult to install on the tensioner..
Jan 28, 2010 | Dryers
A circular belt came out of the back of the dryer?
The drive belt broke. ou need to replace the drive belt. Remove the back panel and you will see a motor and a pulley, attach the new belt there and it will work just fine. Here is a website to get the belt that is right for your unit.
http://www.repairclinic.com/Kenmore-Dryer-Parts?s=a8b6
Feb 10, 2009 | Kenmore 63942 Dryer
Dryer runs no heat
Sounds to me you either blew the fuse or tripped the circuit for the heating element. Try replacing the fuse or resetting the breaker before trying any repairs.
Jan 09, 2009 | Kenmore 64602 Electric Dryer
My dryer is ot blowing hot air
Remove the heater vent, then turn dryer on. Does this fix problem? If so then you have a block in your vent hose.
Dec 31, 2008 | Kenmore 75962 Gas Dryer
Kenmore dryer not spinning---how do i disassemble to see if belt or motor is bad?
kenmore dryers are the easiest dryers to work on. unplug! remove 2 screws @lint screen top. insert screrwdriver under top @ each end and pop top up. disconect wires to door panel. remove 2 5/16 screws at each end inside. lift front door panel up and out.( the bottom of the panel is held by spring clips. replace belt if broke. remove drum if not and check rollers. note: belt route at idler pulley.
Jul 19, 2008 | Kenmore 75944 Gas Dryer
Kenmore Elite HE4 Electric Dryer Logo
59 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
