Question about Sony Televison & Video
Wont switch on
After been unpluged from mains. If left pluged in switches on/off ok.
  • 3 Answers
Just put in the remote code that you put in last time or check it in the internet.
Posted on Nov 20, 2009
Interior wall panel battery lights does not lightup when 120 power is not pluged
The lights run off of 12V DC and use your RV's batteries to run when not plugged in. When plugged in it uses the AC and converts it to DC and runs the lights.
Please check your battery disconnect switch. It's most likely off. In my Winne there is a battery disconnect switch which disconnects the two batteries near the door. Lights wont work when unplugged and the switch is off. Lights works when plugged in or unplugged and switched on.
May 05, 2015 | Winnebago 2015 Ultralite 27RBDS
I unpluged my panasonic tv but when re pluged in now it wont switch on
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Feb 20, 2015 | Panasonic Televison & Video
I have a amana front loader washer and it was doing its norman cycle and stopped at 35 min left and wont do anything and the door was locked so I unplugged it for a hour went back and pluged it in makeing...
This is an error involving the door switch, it is actually DS not D5. The door may not be closed properly, try pushing it in. Or you may need a replacement door switch.
Jan 27, 2015 | Amana Washing Machines
Wont build presure
Unplug power and remove left side cover. Press down on red breaker switch to reset it.
Apr 02, 2010 | Rancilio S24 Espresso Machine
Compaq presarios s5500uk wont boot up fitted new motherboard,pentium e5200 processor. existing hard drive ide seagate barracuda 7200.7 120 gbytes os windows xp
check the power supply: unplug the main connector from the motherboard,plug in the ac/mains power cord and switch on the on/off switch if any located on the power supply, locate the GREEN wire on the main connector that plugs on the motherboard, using a small length of wire insert one end into the plug where the GREEN wire is located and the other end into a BLACK wire on the connector. the power supply should power on if it is good: you will see and hear the fan turn on in the power supply. if it is good remove the wire and re-plug it.if it is not good replace the power supply. also check that the 110/220vac swithch is in the correct position for your mains voltage.do you have a floppy drive connected to the system? if so un-plug it and try again,re-check that you pluged the power button switch connector on the mainboard correctly,
Nov 19, 2009 | EliteGroup G31T-M7 Motherboard
PS3 WILL NOT BOOT UP ALL THE WAY HAS MAIN SCREEN DISPLAY WITH NO ICONS FOR USER ID OR ANY OTHER NORMAL OPTIONS UPON SYSTEM POWER UP. SYSTEM WILL NOT TURN ON OR OFF BY CONTROLLERS UNPLUGED OR PLUGED IN,...
I know you said it wont turn off using the front power switch, but I have something for you to try.....
When the system is on hold your hand on the power button for 30+ seconds and see if it beeps at you twice (2 times) if it does, the system will reset to factory firmware settings (depending on your firmware version) hope this helps.
Oct 26, 2009 | Sony Playstation 3 (PS3) Console
Konica minolta d183 error code C0000
Main motor malfunction.Change the main motor and check the fusing unit.For reset turn OFF and ON the power switch,unpluged the cords and wait 10sec. pluged on and then ON the power switch.
Oct 22, 2009 | Office Equipment & Supplies
Oven wont turn off i unpluged it last night and it turned back on this morning when i pluged it back in
If you have turned the on/off switch to off and the oven stays on then the on/off switch contacts have fused together inside the switch.
If it were the thermostat it would get hot but would shut down in the off position
You need a need switch as simple as that
Jun 04, 2009 | Cooktops
Top up tv dtr box froze then staying on orange light, wont work
i had same problem today, it had locked up during deal/no deal
unplugged it three times nothing happened, wouldn't switch on
unplugged again left it for 5 minutes
then plugged in and left alone for 15mins plus
lights flasing then evetually green light went
all ok
May 03, 2009 | Televison & Video
HP PHOTOSMART 475 WILL NOT SWITCH ON WHEN PLUGED IN
hmmm...ok..unplug from computer first
then with power switch/button depressed, AND power cable out of wall, plug it into the wall, hold button for 30 seconds..
if that's not ok, then make certain the light on your power input is good. We're assuming the power is good from outlet, right?
http://tinyurl.com/6qcpgy
Aug 18, 2008 | HP Office Equipment & Supplies
Televison & Video Logo
19 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
