Question about Mitsubishi WT-46809 46" Rear Projection Television
When turning on the power it comes on then turns off in 5 seconds.I did the menu and input test and got 2 flashes then 3 flashes.I am pretty handy and would like to fix it can you direct me in the process
  • whites10943 Nov 20, 2009
    TY so iff I need a convergence ic replaced and the two fuses f8 or f9 is this somthing I can do .I am confident in many skills but if it takes required knowledge I can't.what do you recomend?I purchased the tv today for 75 and it worked when I seen it,then got it home and it didn't.Now its a cost issue.
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
2, THEN 3 IS ERROR CODE FOR Deflection circuit problem---means something in either the Horizontal or Vertical deflection circuits is causing the problem.
I doubt unless you have a circuit diagram and a volt/ohm meter that you are going to resolve it.
I do not often suggest this but I think you should consider having a pro look at it--tell them what the error code is--that will get their attention and also tell you if they know enough to help.
Sorry for the not so good news.
If you have questions let me know.
If this information helped you at all, rate this solution as I do this here for FREE.
Thanks for using FIXYA!
SD TECH
Posted on Nov 20, 2009
  • SD Tech
    SD Tech Nov 20, 2009
    2 THEN 3 is NOT a bad convergence chip-----someone out here needs to learn the error codes for this model:
    Normal
    0
    false
    false
    false
    MicrosoftInternetExplorer4
    /* Style Definitions */
    table.MsoNormalTable
    {mso-style-name:"Table Normal";
    mso-tstyle-rowband-size:0;
    mso-tstyle-colband-size:0;
    mso-style-noshow:yes;
    mso-style-parent:"";
    mso-padding-alt:0in 5.4pt 0in 5.4pt;
    mso-para-margin:0in;
    mso-para-margin-bottom:.0001pt;
    mso-pagination:widow-orphan;
    font-size:10.0pt;
    font-family:"Times New Roman";
    mso-ansi-language:#0400;
    mso-fareast-language:#0400;
    mso-bidi-language:#0400;}
    1 blink-then 2 blinks-------no error
    2 blink-then 1 blink-------X-ray protection
    2 blink-then 2 blink-------SHORT PROTECTION*******
    2 blink-then 3 blink---------deflection circuit problem
    2 blink-then 4 blink---------vertical circuit problem
    These are the error codes for this model---only one that indicates bad convergence chip or chips is 2-2------short protection.
    IT IS important to know the right answer before you post a solution--I happen to know.
    SD TECH
  • 585 Answers
Hi my name is Roety,
I can help you with your issue ,
Most likey you need the convergence ICs replaced.
A repairman would charge about $350 to replace them
Voltage checks and a visual would be needed to determine exactly what is bad in your TV
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Mitsub
The model listed has a self check: when you turn it on and green power light comes on and goes out in a few seconds, on the front of the set press and hold both the Menu and Input(input may be labeled Source) at the same time and hold for at least 5 seconds.
Release both buttons and the power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat for a total of 5 times.
If you have unplugged the set you will have to plug it back and turn set on, let it fail and then do the check--removing power clears all errors.
Let me know what code you find.
Dec 16, 2012 | Mitsubishi WS-55859 55" Rear Projection...
Will Not Turn On
First you need to do a self test diagnosis and then if it comes up with:
SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB
Do self test by pressing Input/Device and Menu at the same time for 5 sec. the set will show a 2 digit seq. first blinks followed by a short pause then the second.
Dec 29, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubisi wt-46809 will not turn on. i plug it in and it blinks 3 times then nothing. no error code when i hold menu and input
keep in mind if you unplug set it clears the error buffer.
Try to turn set on and if power light comes on and goes off then do the self check; menu and input for at least 5 seconds and release both buttons.
UNPLUG TV ANDTHEN PLUG BACK IN---TURNON---GREEN POWER LIGHT COMES ON FOR A MOMENT ANDGOES OFF.
PRESS AND HOLD "device" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
Before you rate this information let me know what you find.
SD TECH
Jul 20, 2011 | Mitsubishi WT-46809 46" Rear Projection...
Have a Mitsubishi WD-62327 DLP projection TV. It is a few years old. Would not turn on. Blinks red - 3 short red blinks then 1 longer blinks - and repeats. We have disconnected everything, unplugged,...
if you hold the input and menu button for 5 seconds it will flash you a code 36 is the lamp fan / dmd fan has gone bad. pretty common. not hard to change but will cost 100 in parts and whatever labor may be
Jan 18, 2010 | Mitsubishi WD-62327 62" Rear Projection...
Tv turns on then off after a few seconds. No picture or sound in these few seconds.
Try this and let me know what you find:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
let me know what you find--hope that you find 2 blinks, a pause and two blinks--this is the most common and easiest to fix.
if this has helped you rate this solution as I do this here for free.
SD TECH
Dec 10, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Green indicator light flicks about 3-5 times
The power supply has likely detected a short circuit. Hold the front panel INPUT and MENU buttons down for 5 seconds then read the code from the green light. If the light flashes a 2-2 code (2 flashes, followed by a 1/2 second pause, followed by 2 flashes) then pico fuses are blown. A 1-2 code indicates that nothing is wrong. The likely cause for blown pico fuses (FA904 & FA905) is a bad convergence driver IC. The PC board must be resoldered to replace the ICs and fuses.
Aug 09, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi turns on for 3 seconds then shuts off..after power surge
try holding in the menu and input buttons together on the front panel for about 8 seconds to see if the self diagnosis feature will blink a two digt code then let me know what happens
Jun 05, 2008 | Mitsubishi WS-55411 55" Rear Projection...
No picture
Self test: Turn on and Press the input and menu buttons on front panel together and hold for 5 sec. after 5 sec the power LED will blink a 2 digit seq. This will let you know what error code. Count the first blinks then a short pause then the second blinks. Example 2-3, 3-4, 4-1. Let us know what it is.
Dec 05, 2007 | Mitsubishi WS-55807 TV
Mitsubishi WT-46809 46" Rear Projection Television Logo
192 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
