Question about Garmin nuvi 200W GPS Receiver
Nuvi 200 frozen and/or is showing wrong location
    Problem Solver:
  • 9 Answers
Press the reset button on the bottom of the uni, Nut the chances are you will lose any favourte address you have entered.
Posted on Nov 20, 2009
Computer symbol when charging my Garmin Nuvi 200
TRY SWITCHING GPS OFF WHILE CONNECTED. IF NOT DOWN LOAD NEW SOFTWARE AND WHEN FINISHED IT LEAVE CONECTED SHOULD SHOW CHARGING AND YOU WILL BE ABLE TO USE
Dec 18, 2009 | Navigon 2100 Portable GPS Receiver
Tip
Garmin Nuvi 200 Favorites Backup and Restoration Procedure Models: Garmin Nuvi...
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 275
Would you like to back up a copy of your Garmin Nuvi 200 Favorites and Waypoints?
Backup and Restoration Procedure for Favorites:
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After a hard reset or loss of data, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
I hope that helps.
_________________________
Garmin Nuvi Hard Reset Here.
Download Nuvi 200 Manuals here.
Download Garmin WebUpdater here.
on Apr 17, 2010 | Garmin nuvi® 200 Car GPS Receiver
My nuvi 200 just stays on the screen that says Garmin like it is frozen. Am i supposed to be replacing a battery periodically?
Your Nuvi has suffered the firmware or system software equivalent of a stroke.
I can help you fix your Garmin Nuvi 200W.
There are three steps to take to get your Nuvi running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
___________________
Nuvi 200 series manuals available here.
Sep 25, 2009 | Garmin nuvi 200W GPS Receiver
Won't turn off, frozen screen
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Try "resetting" it.
The reset button on your nuvi will switch the device off. The reset button can be used to switch your device off if the screen is frozen and you are unable to switch the device off by the power button.
To reset a nuvi 2xx:
  1. Look at the bottom of the device
  2. Locate the small circle with a dot inside (very small)
  3. Press the circle to reset the device.
To reset a nuvi 3xx or 6xx:
  1. Lift the antenna
  2. Locate a button with the word Reset inside
  3. Press the button to reset the device.
The device will now switch off.
Jul 25, 2009 | Garmin nuvi 260W GPS Receiver
I have a Nuvi 260. Where is the reset button? The manual that came with the unit is for a 200. Is the button under the sticker somewhere?
It hard to see, not hard to find....look CAREFULLY
Might need glasses to see it depending on your age!!
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The reset button on your nuvi will switch the device off. The reset button can be used to switch your device off if the screen is frozen and you are unable to switch the device off by the power button.
  1. Lift the antenna
Jun 06, 2009 | Garmin nuvi 260W GPS Receiver
Nuvi 350 System Software Missing
If you have a nuvi 350 download the software to your computer and then load the software onto a formatted sd card. Insert the sd card and bootup the Nuvi 350. The sofware will then load onto the Nuvi 350. If you have a Nuvi 200 I would think it works the same but I have not tried it.
Hope this helps
May 12, 2009 | Garmin nuvi 200W GPS Receiver
Garmin nuvi.200 pin
there are 2 ways to do this: 1. send your unit to garmin and pay a large sum of money. 2. go to the area where you first set your pin (safe location)
Apr 02, 2009 | Garmin Nuvi 660 GPS Receiver
I can't get my nuvi 300 to turn on. Can it be locked somehow? Any help would be appreciated.
Jim,
I wrote the wrong model...it is the nuvi 200. I do not see an antenna or any kind of button other than the on off control. Where would I look?
Thanks!
Angela
Sep 30, 2008 | Garmin GPS
Gamin nuvi 200
need to get unlock code from garmin ! they will give it to u for free !
Jun 14, 2008 | Kenwood SIR-KEN1 SIRIUS Radio Receiver
Garmin Nuvi 200W, trip planner
First of all , this is a NUVI 660 FORUM REVIEW not 200.
He was wrong , and a trip planner sir is where you want to go.
Point A to point B .
The small guide show you but the best way to learn it's to play with it.
best regards
Dec 29, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi 200W GPS Receiver Logo
164 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
