Question about Avaya Definity 6408D Corded Phone
Saving Changes I'm in the Change station XXXX screen, "how can I get back to the command promp" to enter the command save translations to save my changes. I'm not able to make the changes, can't save it !
    Problem Solver:
  • 8 Answers
Re: Saving Changes
Press F1 key or by using mouse you click cancel in ASA tool
you will come out of Change station XXXX screen,
One important thing is that to save the changes made in station form you need press F3 or click ENTER boutton in ASA tool.
No need to go for Save translations.
Posted on Jan 14, 2008
0 characters
3 Points
Tried to change to daylight saving time, but it keeps changing back to standard time.
Hi Joyce,
Your device *might* be pre-programed to adjust for ST to DST changes on another date. In 2006, the ST to DST change took place on the 1st Sunday in April and the DST to ST change took place on the last Sunday in October for the last time.
Congress decided that beginning in 2007, that the ST to DST change would take place on the second Sunday in March and DST / ST change back would take place on the first Sunday in October - and has ever since. So, you'll likely see the mismatched time again in November.
If it worked last year - then there is another issue. Unfortunately, without your brand and model, there's little anyone can do to help you out. If you need more help, reply and be sure to include the brand / model info of the device.
Clock changes in Washington DC District of Columbia in 2009
Mar 12, 2015 | Phones
When another extension calls me, the speaker automatically picks up. Need to know how to stop this.
Have you tried this ...
In ASA, enter the command ch sta xxxx.
Select tab 2
In the second column of features , you will see "Auto Answer". This should be set to "none".
Good Luck!
Sep 16, 2013 | Lucent PARTNER18 Corded Phone
I locked out the phone and do not remember my password
Before you get all hairy about the answer, remember that you have asked the question in a PUBLIC forum. If you get step-by-step instructions, everybody will be able to hack a locked phone in a Panasonic system and FixYa has a pretty good hit ratio in a search engine.
The feature you have activated is probably electronic station lock. It's set by 77 xxxx xxxx #. The xxxx is a 4 digit password that you key in twice. You unlock the set by dialing 77 xxxx , the password you used to lock it.
However, the operator can lock and release each extension from the console. The instructions are in the system OM (operating manual or user guide). In fact, an operator locked station can't do anything.
Jan 08, 2011 | Panasonic KX-T7030 Corded Phone
I have an avaya corded speakerphone without a user manual and I need to change the time on the screen to update it for daylight savings. How do I determine the model # etc.
Partner ACS, any release
Changing the time on a Partner system must be done from extension # 10 or 11. 1. At station(Ext.10 or 11) press feature, 0, 0
2. Press the left intercom 2 times
3. Enter # 103
4. Enter the correct time in 24 hr. format, for example:
* to set the time for 09:00 A.M., enter 0900
* to set the time for 04:45 P.M., enter 1645
5. Press feature, 0, 0
May 10, 2010 | Avaya MLS 12D Corded Phone
Samsung iDCS 28D Voicemail Problems
If you have administrator access use the following steps to change the code:
Access the Administratin Main Menu and select 4 for mailbox programming.
Select the mailbox to program. Dial option code 1402. The current value will be played. To hear the current value press 1, to enter a new value press 2, to hear the range of valid values press 3. Press 2 to enter new value. Enter the access code for the mailbox. The value you entered is played back. Press1 to save or 2 to re-enter. Press 3 to exit without saving. Press # to exiit or hang up.
Aug 03, 2009 | Samsung DCS 12 Corded Phone
Switchboard KX-T7730
The electronic station lock requires a couple of things, first it's dependent on the system, second, it requires some toll restriction programming, and then you can put in a lock code. At a minimum, in a TA-824 series, dial 77 xxxx xxxx #, where xxxx is a 4 digit number repeated twice. That locks the set, but it might not do anything different. It's released by 77 xxxx #. If you need help, consult your programming and features manual, or post back with the model of your phone system. Carl
Jun 10, 2009 | Panasonic KX-T7730 Corded Phone
How do I add a new number into my Avaya (model 1408) phone's pickup list?
use list usage ext xxxx to find the pickup you are in
use change pick xxxx to amend the pickup group.
A station can only be in 1 pickup group.
Oct 26, 2008 | Avaya Phones
Display for Caller Id incorrect
After calling Panasonic US at 1800-211-PANA (7262) regarding my kx-tga5420 and kx-tg5230 system's handsets.
On the handset, verify that Caller ID Edit is turned on first.
Menu-->Initial settings
Go to Caller ID edit
Select Auto edit ON
Exit the menu
On the handset main display
Hit the button that relates to CID
Scroll down until you find the desired 1-xxx-xxx-xxxx number that you want to
be displayed as xxx-xxx-xxxx
Hit the edit key until you see the number displayed as xxx-xxx-xxxx
(Note: You have to initial a call once you have saved the change.)
Now hit the TALK button to dial this number
Now when you receive calls from this number it wll show as xxx-xxx-xxxx instead of 1-xxx-xxx-xxxx.
Jul 06, 2008 | Panasonic KX-TGA520M Cordless Expansion...
External caller id
In ASA give the command
change station extension#
you will get a station screen,In Name field
give the name which you want to display for a particular extension user.
then press F3 to save
When that particular extension user called then you will see mentioned name.
Jan 21, 2008 | NorStar T7316E Corded Phone
Changing the display
In your system support room - - you will have two computers set up for your phone system - maybe (at least that's how it's set up here).
One is for the voicemail system and one is for the phone display, essentially.
You will log in to that other station and when you get the command prompt type
change station xxx (where xxx is the extension of the phone display you wish to change).
Sep 13, 2007 | Avaya Definity 6408D Corded Phone
Avaya Definity 6408D Corded Phone Logo
57 people viewed this question
Top Avaya Phones Experts
D. E. Hev
Are you an Avaya Phone Expert? Answer questions, earn points and help others
