Question about Vacuums
Power nozzle works intermittently
Brand new vacuum. power nozzle works intermittently. when you push forward works, pull back power nozzle stops working.
  • aline45 Nov 20, 2009
    Brand is Hoover Windtunnel canister Model S3670. The problem is where the wand goes into the power nozzle. It works when you push the power nozzle forward, but when you pull it back, the power nozzle stops working.
  • Vac Belts
    Vac Belts May 11, 2010
    What is the brand and model?
    Scholar:
  • 190 Answers
The pin connection from the lower handle tube to the power nozzle are not making good contact. It is new, so i would have warranty service performed.
Posted on Nov 20, 2009
Why am I unable to push vacuum forward on new area rug. But will work pulling backward. Works fine on old rugs and floor
It might be that the new rug has a backing that is not as stiff a the other rugs which can cause a rug to bunch up making it hard to push the vacuum forward.
Feb 23, 2015 | Dyson DC25 Animal Upright Ball Bagless...
How to attach crevice tool
Hi! Below is step-by-step instructions for attaching your crevice tool.
1. Place unit in an upright position. Push release button forward, then pull handle from unit.
2. Remove floor tool from nozzle.
3. Attach crevice tool by inserting into nozzle. To remove gently pull apart.
Hope this helps out!
Apr 26, 2014 | Dirt Devil Simpli-Stik 3-in-1 Bagless...
Featherlite model 3M-852H
see this instructions:God bless you
Ensure the Dirt Devil is connected to a working power supply if it does not turn on or operate. Check the fuse or breaker and replace or reset as necessary.
  • 2 Empty the dirty water tank if there is little or no suction. Turn off the Dirt Devil and grab the top of the dirty water tank. Push on the latch to release the tank and pull the tank off the base. Remove the lid and empty the dirty water into a sink. Replace the cap and hook the front of the tank onto the machine base. Hook the nozzle on the base so that the nozzle is level with the cleaner base. Push the back of the dirty water tank down and into position.
  • 3 Check the dirty water tank and empty as necessary if there is water leaking from the cleaner. Open the latch on the top of the solution reservoir and pull the reservoir forward. Fill with Dirt Devil brand cleaner to the fill mark. Fill the rest of the reservoir with hot water and close the cap. Replace on the base unit.
  • 4 Make sure the solution reservoir is seated firmly in the base unit if there is no cleaning solution dispensing from the unit. Fill the solution tank with cleaner and water if the level is low.
  • 5 Examine the hose and nozzles for possible obstructions if the carpet cleaner does not seem to be operating correctly. Remove any blockages.
  • Jul 19, 2012 | Vacuums
    Bissell Power Steamer Pro Deluxe will not move forward
    tip unit back to lift brushes off floor and roll forward until over carpet edge. tip back unit to sit flush on carpet and unlock handle so it swings freely. now pull backwards ith finger on spray trigger. that's how it works, not by pushing forwad.
    May 16, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
    The power goes off and on when using my vacuum. When I push my vacuum forward, intermittently it loses power.
    Almost certainly there's a broken wire within the electric flex. This usually happens where there's most bending and pulling - that is, where the flex enters the machine or where it enters the plug. You'll need to get someone to either shorten the flex or fit a new one.
    Beware that messing with electrics is potentially dangerous, so don't do it yourself unless you are confident you know what you're doing! Good luck!
    Feb 03, 2010 | Vacuums
    Power nozzle suddenly stopped working (no power or vibrating). Can these be repaired or should I just buy a new one?
    Hello. Check out your reset button located on the top of the power nozzle. It is either black or red. Turn the cleaner on, and while running, push in the reset. Voila! It should be working again. The reset is put in the vac to protect your power nozzle motor. You have a geared belt that is driven by a circuit breaker protected motor. This way, if there is an overload on it, it will shut off, allowing you to clear it and reset it. I hope this helps! Have a good day.
    Nov 05, 2009 | Electrolux UltraLux 2000 Bagged Canister...
    Electrolux powernozzle not working
    mine was the power head neck itself the handle got twisted to far and broke the wire a new neck cost 37 bucks online and i installed it myself wires get attached color to color and screw the head back together. it worked just like new!
    Mar 18, 2009 | Electrolux Centralux Vacuum
    Brush won't rotate when pushed forward
    I had the same problem . The reason it acts like that is due to the cable that runs from the vacuum motor to the brush assembly has an intermittent open. My fix was to find the small cable that was causing my troubles and splice it. Making sure that I recovered the insulation. Of course my local repair station wanted to replace it for $75 labor plus parts and keep it for 3 days. I took it home and did it in 30 minutes .
    Dec 12, 2008 | Hoover U8145-900 Savvy Bagless Upright...
    Agitator stops when sweeper is pulled backward
    If you have made no changes to the vacuum's setup and are using it on same carpet you have previously used it on with no problem, then the most likely cause is the agitator/beater bar's drive belt is worn or on some models may have a tension adjustment which is set too loosely. This can also be caused by having the vacuums height adjustment set to low for the carpet or flooring you are using it on, causing to much drag when the vacuum is pulled backwards for the agitator to overcome.
    The vast majority of agitators turn in a forward direction, as if it would pull the vacuum forward, when you pull the vacuum backwards the drag is increased.
    So...First check height adjustment (a no cost fix), then check out the tension adjustment (if present on you model, some engage when top of vacuum is tilted back after stepping on the release pedal) Lastly, consider changing belt especially if you have had the vacuum awhile or if it gets a fair amount of use or it you seem to need to use it on a low height setting all the time to vacuum up debris.
    Hope this helps!
    Dec 19, 2007 | Kenmore 34923 / 34925 Progressive Bagged...
    Vacuums Logo
    259 people viewed this question
    Top Vacuums Experts
    AskDyson
    AskDyson
    D. Floyd Kolb
    D. Floyd Kolb
    Are you a Vacuum Expert? Answer questions, earn points and help others
