Question about Mitsubishi WS-65809 65" Rear Projection Television
Hi I received an error code of 12 what does that means?
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
IF error code is 1, then two blinks it means No error is detected.
I would suggest you consider having someone look at the set for you---find someone who knows Mitsubishi sets---some places have little or no experience with them.
If you have questions or need advice let me know--I am here to help people.
If this helped you, rate this solution as I do this here for FREE.
THANK YOU FOR USING FIXYA!
SD TECH
Posted on Nov 20, 2009
I need help with a code 12 for. 95 grand Cherokee orvis 5.2l. In need of some help. I know what the code says, but don't understand what it means.
A code 12 just means that memory to the controller has been cleared within 50-100 engine starts, which can occur whenever the battery terminals are disconnected, battery completely dies, etc. Nothing to worry about really, and it is NOT related to the thread that you found.
http://www.jeepforum.com/forum/f11/jeep-cherokee-help-error-code-12-a-1172243/
The codes you found indicate there are no stored trouble codes: Code 12 means that the battery or the computer power lead was disconnected sometime during the last 50 operating cycles. This is not an indication of a problem. Code 55 means that there are no other stored codes in the computer.
http://answers.edmunds.com/question-95-5-2L-Jeep-Grand-Cherokee-Ltd-code-12-What-should-I-do-93723.aspx
http://www.bing.com/search?q=error+code+12+jeep+grand+Cherokee&qs=n&form=QBRE&pq=error+code+12+jeep+grand+cherokee&sc=0-33&sp=-1&sk=&cvid=F34E2340514C41A7B7139E3671F6D25D
Jun 12, 2016 | Cars & Trucks
Hi sir i have a xerox dc 12 giving error code 10-500 after replacing a new web cartridge
This code means that printer is not detecting the cartridge. you can try to to remove it and re seat it or it could be faulty, her is a list of all of the codes.
http://www.metrouk.co.uk/pdf/xeroxdc12faultcodes.pdf
Hope this helps.
Sep 16, 2014 | Xerox DocuColor 12 Printer
On a fisher & paykel washing machine what does it means by fault code 12. The washer is approx 8 years old.
Hi just read posting.Error code 12 means FLOOD PROTECTION ERROR.Has you machine overflowed or does not pump the water out quickly?Please reply with additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
May 16, 2011 | Fisher and Paykel Washing Machines
OUr Rinnai gas heater convector 516tr keeps on turning itself off and flashes 12 on the light panel. What does that mean and how to fix it? tks
Hi.
12 flashes means "Incomplete combustion". The code is prompted when the flame turns off because of a problem.
Check filter, check gas pressure and thermocoupling. Those are the problem that commonly trigger the code 12 error.
Here a manual.
Here Fixya thread on the problem.
Sep 06, 2010 | Heating & Cooling
1997 breeze is shooting codes 12 46 43 55
OBD Code 12 - No Distributor Reference Pulse (Diagnostic Test Active) The Engine Control Module-ECM uses the distributor reference pulse to calculate the engine speed. On newer engines, the Crank Shaft Position Sensor performs this function.
Symptoms:
  • When flashing the Check Engine Light to read codes, code 12 will always display first, indicating the diagnostic system is active
  • The engine will not run with a "hard" code 12 set
Common Problems:
  • Chances are you will never need to diagnose a code 12. Rather, the problem would be a crank, no-start condition.
  • If code 12 does not flash, that would indicate a communication problem with the ECM.
  • Code 12 does not show when reading codes with a scan tool. If there is a communication problem, the scan tool will let you know.
OBD Code 46 - Pass-Key II System Error - Circuit out of Frequency Range The ECM receives a signal from the Pass-Key module. When the correct signal is received, the ECM will allow the engine to start and run. Please review the RepairPal article on the GM Pass-Key Anti-theft systems for more information.
Symptoms:
  • Engine may not start
Common Problems:
  • Faulty ignition lock cylinder
OBD Code 43 - Knock Sensor error The ECM receives a signal from the Knock Sensor based on the amount of engine ping detected. The ECM uses information from this sensor to help calculate fuel delivery and spark timing.
Symptoms:
  • Engine ping
  • Lack of power
Common Problems:
  • Faulty Knock sensor
  • Poor connection at Knock sensor
OBD Code 55 - End Test.
Hope ehit help (remember comment and rated this).
Jul 22, 2010 | 1997 Plymouth Breeze
Rinnai 556 ftr keeps flashing code 12
Hi
Thanks for using FixYa. Error code 12 on a rinnai 556ftr means Flame failure. Check gas is turned ON.
Also see this error manual.
Please refer to this user manual for more details --
Rinnai 556ftr User manual
Please do rate the solution & revert for further assistance.
Thanks
Rylee
Jul 29, 2009 | Rinnai EnergySaver 556 Air Conditioner
ERROR CODES 15 and 12
http://audio.manualsonline.com/manuals/mfg/pioneer/deh-2800mp_2.html
May 05, 2009 | Pioneer DEH-2800MP CD Player
Error code 9 - 358
Hi,that means ,cleaning auger is stopped.Probably toner waste container is full.Try to remove and replace waste toner container(or vacuum toner from container).
BR
Feb 20, 2008 | Xerox DocuColor 12 Printer
Mitsubishi WS-65809 65" Rear Projection Television Logo
65 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
