Question about Vacuums
Removing handle of Hoover Widepath Floormate Spin-Scrub
I have to repackage this item for return due to a defect. However, once you've installed the handle, it seems impossible to remove. I've tried removing all the screws that splits the handle into two sections, but the part that locks it in place is down into the base. How can I get the handle off?
  • debneedshelp Feb 01, 2008
    I no longer have the problem since the faulty appliance has been replaced with a new one.
    Thanks!
  • Lauren Junge
    Lauren Junge May 11, 2010
    What is the model number??
5 Suggested Answers
Kaoeria
  • 36 Answers
SOURCE: hoover floormate plus model #H3010
It seems to be a common problem with this series of floormate... some home quickfixes (a hassle, i kno) but put downward pressure while using the solution.... Check your warranty that came with it, and how long you purchased the floormate... Alot of vaccuums come with 30-90 warranties, I'd recommend having it checked out. That, or if u bought it recent enough,take it back... like i said, these models are unfortunately known to have this problem... Some people have ones that operate normally, but alot do not. >.<
Posted on Jan 09, 2008
SOURCE: Repack the Hoover Floormate
Did you ever get the handle off? I'm having the same problem.
Posted on Jul 12, 2008
VacuumRepair
  • 438 Answers
SOURCE: I have a Hoover V2 Steam Vac widepath and the
This is a notorious problem with the Hoover V2 SteamVac's. In fact the tank design by Hoover on your SteamVac was so bad, that Hoover redesigned this tank almost immediately due to the numerous problems customers were having.
For your particular problem, you really have two options. The first option is putting a bandaid over the problem, but will still fix it. We sell the entire gasket assembly on the bottom of the detergent tank as a replacement part. Unfortunately it's sold together with the seal, spring, and valve together as an assembly;
http://www.govacuum.com/hoover-steamvac-dual-v2-tank-valve-part-43513015.html
You also may wish to fix the problem completely by replacing the entire clean water solution tank. Hoover has redesigned this tank, and the new one I don't see near the amount of problems that I do on the older style tanks. The plastic is much more sturdy, and less prone to having the gasket and valve issues that the old tanks do. It's important to point out that the new tank does not come with the handle. You'll need to remove the handle from your old tank if you buy a new tank assembly complete. Rest assured that if you do purchase any part from GoVacuum, you'll have 60 days to return it for a full refund, just in case the repair doesn't work. Not only do we not deduct restocking fees or shipping charges, but we also include a return label with every order that you may use to return any item to us, and we'll even pay for your return shipping!
Here's the Hoover SteamVac V2 Clean Water Solution Tank, Part 12002549
If you'd like us to do a repair photograph series on this repair of the valve and gasket assembly, please just request a repair clarification here on Fixya, and we'll be happy to do so. If you found this helpful, please be sure to rate the review as helpful by clicking on the 4 Thumbs Up Icons in the top right hand corner of the repair.
Thank you so much,
Chris J.
GoVacuum
Posted on Mar 23, 2010
  • 294 Answers
SOURCE: Hoover Tempo Widepath - propellor not working
If you are refering to the roller underneath, the belt nees to be replaced. Simply remove 4 bottom screws and then the roller, Place new belt on roller and thenon motor shaft, pull belt with the roller to install in position and install bottom plate.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Posted on May 02, 2010
Testimonial: "Thank you - it helped me look for the right source - thankfully, belt was not broken, just slipped off the hinge - but atleast i knew what to look for :)"
My floormate spin scrub solution dispenser button is difficult to push and when I do push it I can not see the plunger rod moving to raise the solution tank plug. How do I fix this?
Hi Melissa, this is one of our older designs that we recommend you take to a service center to get checked out. Find one here: http://hoover.com/locator/. We do listen very carefully to feedback like yours and implement that in our newer models. If you are looking for an upgrade, take a look at our FloorMate Deluxe: http://bit.ly/1sLrS5x. Hope this helps!
Dec 20, 2014 | Hoover H3040 FloorMate SpinScrub Widepath...
Hoover F7410-900 Steam Vac Dual V scrub brushes not working
If the brushes will to spin when you try to turn them by hand remove them from the machine. If the brushes spin ok after removing them the the turbine assembly is seized up and will likely need replaced. If the brushes won't spin when they are removed from machine take the plastic cover off the brushes and clean out the gears.
Nov 03, 2013 | Hoover F7425-900 SteamVac V2 Widepath...
Thank you so much,
Chris J.
GoVacuum
Mar 23, 2010 | Hoover F7425-900 SteamVac V2 Widepath...
The scrub brushes dont spin anymore
The brushes are turning by an air driven turbine. The turbine has a pivot bushing made of steel inside of it that gets rusty because of the water that is running through it. The turbine gear will have to be replaced. You can access the turbine gear by removing the hood. You can find a genuine hoover replacement part by following the link below. Just find the model number of your Steamvac.
http://www.usavacuum.com/Hoover-SteamVac-Parts-s/105.htm
Oct 23, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
My spin scrub brushes don't spin at all.
Check that the belt that spins the brushes is not broken, also that the
gear that drives the belt is turning.
Tom
Aug 10, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Brushes won't spin on FloorMate
you need to replace the belt or make sure the brushes are locked into place.
Jun 18, 2009 | Hoover H3030 FloorMate SpinScrub 500...
Water keeps coming out of my hoover spin scrub
The bottom of the solution tank has a rubber stopper, if this tank is not installed just right that rubber can get caught, or damaged. Here is the manual for your machine.
http://www.hoover.com/pdfs/manuals/H3030.pdf
I hope this helps.
Jan 18, 2009 | Hoover H3030 FloorMate SpinScrub 500...
Hoover floormate.
Can't do it. The machine vacuums in both scrub and pick-up. Sorry.
Kirk Thompson
San Juan,PR
Sep 01, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
HOOVER STEAM VAC SPIN SCRUB
Cannot hook the upholstery cleaner into slot..lost manual in fire
Jun 16, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Vacuums Logo
160 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
