Question about Toshiba Satellite M30X-S181ST Laptop
My laptop will not boot up
My laptop begins to boot and gets to the blue screen and will not continue booting up
  • Julie Nov 20, 2009
    cannot get it to work. it keeps rebooting now but will not every get to desktop.
    President:
  • 2,600 Answers
There may be several issues here, lets assume the motherboard and gard drive are good and windows just needs a repair and jumpstart. Try the below fix first, then we'll move on.
Windows Start-up Errors
Step one, you need a Windows Installation CD. If you only have a recovery disk set like the ones from HP or Compaq they will not do what you need done. Under normal circumstances however, you can use a Dell disk because the Operating system is on a stand-alone disk. All retail versions are also acceptable as well as upgrade disks. For a rule of thumb, if the disk has the Microsoft hologram it should work.
While the computer is first starting up and you see the manufacturers splash screen, tap F12 (some computers it’s F9, others it may be another key, you may have to watch and see if the computer lists the key strokes for getting to the boot menu. If you still cannot find it, boot into the BIOS settings and change your boot order there. Save your settings and exit, the computer will now seek the cd rom as its boot source first.
Place your Windows disk in the computer and start it up. When you see the test at the top of the page “Press Any Key To Boot From CD” Just hit the space bar to activate. The next screen you will see will most likely be a Windows setup screen, when you see this press the “R” key to get to the recovery console. It will get there, it may take a little time, patience. Once it loads you will be given a choice of Windows installations, there should only be one, if there are more, always pick number one. It may ask for an administrators password, if you have not set this particular password, then just leave it blank and press enter. The next prompt you see is:
C:\Windows>
You need to type the following:
cd \
hit enter. Pay close attention to the spacing between the characters. There is a space between the character “d” and the “\”
You are now at the ROOT of the drive, this is where basic commands can be given and changed. You should now see the following:
C:\>
Now type the following:
CHKDSK /R
Hit the enter key.
The chkdsk /r command also includes the P command and will also look for lost recoverable information in bad sectors.
There are occasions depending on how corrupt the system is, that this process could take several hours, so be patient with it.
Now, after chkdsk has run type the following:
FIXBOOT
Hit the enter key.
It may prompt you with a warning, that’s ok, just continue. When fixboot has finished, type: EXIT hit enter and windows will reboot. When the system reboots, tap the F8 key during this time and you will see the multi-boot menu come up. Scroll to the title “Last Know Good Configuration” and hit the enter key. If you were having some simple drive errors this should have fixed them.
Posted on Nov 19, 2009
UN MOUNTABLE BOOT VOLUME ERROR - BLUE SCREEN on a dell latitude D505 laptop
try to boot to safe mode using F8 key on boot and then recover system or reinstall OS
Nov 13, 2012 | Dell Latitude D505 Notebook
After installing some recent windows updates, I then did a restart to the computer. The computer no longer will boot into windows. It ' boots to windows xp logo and then changes to a blue screen after...
This may help.
http://www.user-guides.co.uk/cddownload/Samsung/N120-12GBK/Samsung-N120-12GBK-Fix-Repair-NTLDR-Missing-Corrupt-or-Compressed-Boot-Disk-CD-98-XP-2000-502214.html
I have never used one as I have my own boot disc.
Feb 15, 2011 | Samsung N120-12GBK Netbook
Hi there, have a strange problem with a brand new DVD SAMSUNG SH-S223C. Installed a few days ago and running latest SB05 firmware (Even I reinstalled twice this firmware). Now on boot with my WIN XP PRO...
Start up BIOS and perhaps change default boot drive to your hard drive because i think your default boot up device is the dvd drive.... try to put that last on the list... F2 should get you to BIOS if not try F8 Just keep tapping right at beginning of startup before the logo screen shows. Once in BIOS go to boot menu and change default device :) Hope that works for you
May 04, 2017 | Samsung SHS223C 22x Internal DVD±RW...
Try's to boot up, but goes to small blue screen
When your computer hardware appears to power up okay, but the Windows XP operating system won't boot properly, you have to begin a troubleshooting expedition that includes getting into the operating system, determining the problem, and then fixing it. To help you get started on this expedition, here are 10 things you can do when Windows XP won't boot.
#1: Use a Windows startup disk
#2: Use Last Known Good Configuration
#3: Use System Restore
#4: Use Recovery Console
#5: Fix a corrupt Boot.ini
#6: Fix a corrupt partition boot sector
#7: Fix a corrupt master boot record
#8: Disable automatic restart
#9: Restore from a backup
pls 4 stars .... :-)
Nov 29, 2009 | Sony VAIO VGN-S150 Notebook
HP Pavillion dv9000 fatal error
On the windows boot screen you should be getting choices for safe mode, safe mode with networking, etc ...
Select "Disable automatic restart on system failure'
And let me know what error message(s) you have ... write it all down
Jan 14, 2009 | HP Pavilion dv9000z Notebook
Acer laptop keeps rebooting
fdisk /mbr then format the drive and reinstall your operating system.
Aug 29, 2008 | Acer TravelMate 4150LCi Notebook
Blue screen
you have a virus on the laptop. you will need 2 take it 2 a professional to get the virus removed.
Jul 29, 2008 | Compaq Armada M700 Notebook
Blue Screen
Please try changing RAM. If same thing continues try logging on to safe mode by booting in safe mode( By pressing F8 during boot after bios check).and restore the note book .
Else Try reinstalling the operating System.
Mar 06, 2008 | Sony VAIO VGN-N250N/B Notebook
Computers & Internet Logo
73 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
