Question about Refrigerators
Water does not come out of refrigerator door Ice cube are fine but know water
    President:
  • 3,433 Answers
The water slenoid may be at fault. Chk the water line running up the freezer door hinge for damage and trace it back to the solenoid valve. verify the line is ok running under the fridge,then confirm solenoid is actuating wher water lever is pressed. Good Luck.
Posted on Nov 19, 2009
My fridge wont make ice
you need to replace the ice maker .
Sep 12, 2009 | Refrigerators
Ice maker stopped making ice
Hi
When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 08, 2009 | LG LFX25960ST Stainless Steel French Door...
Water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
Jun 02, 2009 | Frigidaire FRS26R4A Side by Side...
Ice Maker frost and freeze where ice drops into refrigerator door
You need a service guy to look at it. It could be water leaking or a simple case that the flap isnt sealing and the ice melts and then freezes the flap open
May 14, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
NOT MAKEING ICE CUBES
well 9 1/2 times out of ten it is the ice maker i recommend you shop for a new ice maker... whirlpoolpartssurplus.com can get you a real good discount and free shipping...call them
Apr 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE Side by Side only dispenses crushed ice
remove the ice cube tray assy, remove all the ice, save the cubes, wash the assy with warm water dry the assy, be sure the lever in the rear of this ice cube assy is moving and spring loaded, move the lever and it should snap back and return if so you know the unit is ok(the cube assy), now with the assy still out of the freezer close the freezer door and select crushed ice and push the pad where the glass normally hit to activate the ice cubes,if the operates and you here a thump and snap and hum most likely your ok,if not you could have a defective auger motor assy,but if you here all the sounds as decribed oped the freezer door and select cubed ice push actuator on despensor door with the freezer door closed, reopen and install the ice cube assy tray bucket assy,push it in firmley, and try it with some ice in the bucket you should be fine,if not replace auger motor assy..
nbcrca:)
Apr 11, 2009 | GE Profile PSW26P Stainless Steel Side by...
Bad water & ice cube taste
Hello redwood City
Welcome
You said,
Your Kitchenaid Superba KSRG25FKBL15 has bad tasting water and ice cubes. You replaced the copper tubing which delivers the water to the fridge and that didn't help. You replaced the copper tubing again with plastic tubing...no better. Any suggestions? Your tap water doesn't taste this bad.You bought a Kenmore french door fridge with water dispenser in the door in July 2008. The fridge has a filter. A few weeks after the fridge came the water and ice started tasting really bad, unlike any bad water taste I have ever tasted. And your tap water is fine. The bad taste appears to be random. Sometimes you get a cup full of nasty water and sometimes it tastes fine.
First you must know you have a 1 year warranty and can have them come out to fix anything, no charge.If it persists. You will have to get tough and you , MUST INSIST THEY REPLACE YOUR FRIDGE
When installing the water line these were a part of the directions!
Did you do this before connecting the water line to your fridge?
"Place the free end of the tubing in a container or sink, and
turn ON the main water supply. Flush the tubing until water is
clear. Turn OFF the shutoff valve on the water pipe. Coil the
copper tubing."
Whirlpool remedy
Off-taste, odor or gray color in the ice
1.Are the plumbing connections new, causing discolored or
off-flavored ice? Discard the first few batches of ice.
2.Have the ice cubes been stored too long? Throw old ice
away and make a new supply.
3.Does the freezer and ice storage bin need to be cleaned?
See “Cleaning” or “Ice Maker and Storage Bin.”
4.Has food in the freezer or refrigerator been wrapped
properly? Use airtight, moisture-proof packaging to help
prevent odor transfer to stored food.
5.Does the water contain minerals (such as sulfur)? A filter
may need to be installed to remove the minerals.
6. Is there a water filter installed on the refrigerator? Gray or
dark discoloration in ice indicates that the water filtration
system needs additional flushing. Run additional water
through the water dispenser to flush the water filtration
system more thoroughly (at least 2 to 3 gal. [8 to 12 L] or 6 to
7 minutes initially). Discard discolored ice.
Let me know what works,
Thank You ,
HUUUM!!
Please remember to leave a rating.
Sep 25, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice & water control buttons
sound like a bad(shorted) dispenser user interface INTERFACE DISP ASM WR55X10415
Apr 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Frididaire Gallery series side by side with ice and water in the door
First pull out the ice bucket and close the door.  Set for cubed ice.  Press the button for ice to come out and listen for a loud clunk noise.  That is the sound of the solenoid.  You can open the door, hold the light switch and press the button and watch for the solenoid moving up and down.  Solenoid is at the back of the freezer in a little square opening where the rod on the ice bucket goes into.  If that solenoid is moving ok then put the bucket back in while the solenoid is in the down position and cubes should work.  If solenoid is not working then it will need to be replaced.  Let me know what you find.
Oct 14, 2007 | Frigidaire FSC23F7D Side by Side...
Refrigerators Logo
52 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
