My panasonic tv
It won't go past channel 27. How do I reprogram it. panasonic model pvm2048. thanks
My panasonic projection tv has a color problem .it looks like the red and blue split .if i cover the red inside the tv the problem stops but i lose my color it looks like a black and wight tv .how do i fix this [email protected] or jamie at 412 480 8179 .thank you.
Posted on Jan 27, 2008
My tv wont turn on, it is plugged in and still wont turn on
Posted on Jan 24, 2008
6ya staff
SOURCE:
HOW DO I REPROGRAM PANASONIC TC-22LH30. BOUGHT IT USED AND WORKED GREAT ON CABLE. I WANT TO PROGRAM IT ON ANTENNA,
First... You need your working Remote
  • Input
    • TV
  • Now, Menu
  • Scroll to Program
  • Locate and choose from list "Antenna or Broadcast TV or Air or OTA". Different models vary
  • Then choose Scan for channels.
It's important that your antenna is hooked up correctly, and able to catch frequencies. Otherwise NO channels will be found.
Jun 13, 2015 | Panasonic Televison & Video
Remote
Is this the original tv remote? What exactly do you need to reprogram?
Thanks,
Lee
Sep 01, 2008 | Toshiba 27A44 27" TV
I tried auto programming my tv but I can't go past channel 69. All other tvs go up to at least 99. When I try to manually program 99, the remote will only input a 9.
There are only a possible 48 channels available in the UHF bands IV and V; 21 - 68. Some Continental TV's still use band III; 1 - 20
Are you sure you are not getting confused by programme numbers which can go up to 99 and AU etc.
Jan 04, 2011 | Panasonic CT-27E13 27" TV
I moved tv now it want go past channel 13
No problem. Go into menu to channel or tuner setup.. When it was unplugged the tuner reset to air and needs to be changed to cable and then auto program the channels..
Oct 17, 2010 | Panasonic CT-27D12D 27" TV
Panasonic tv no signal?on any channel
Akai model LCT2715 will not pick up any chanels
Mar 07, 2010 | Akai LCT2715 27 in. LCD Television
Pink screen
Anything is fixable just a matter of cost or availability of parts.
Jul 24, 2008 | Panasonic CT-27SL15 27" TV
Channel
make sure that ur antenna/catv is properly connected to antenna/catv input of ur tv...better check the center lead if ur using coaxial cable..then try to reprogram/autoprogram ur set.
navigate also on tuner settings...via remote..
if u get nothin after autoprogram..probably bad tuner in ur set..u need a prof tech to fix it...thanks hope this help
Feb 05, 2008 | RCA TruFlat 27F520T 27" TV
Set up an a Panasonic TZ-20L3Z
Press MENU button, select PRESET and then , select MANUAL PROGRAM and SEARCH, when search completed the program stops. Give the channel and store.
Aug 19, 2007 | Toshiba 27A34 27" TV
Tv will not change channels
Sounds like an eeprom problem or a microprocessor problem??? Also make sure the tv didnt lose its channel memory by reprogramming the channels feature in the menu. Good Luck
Jun 23, 2006 | Sylvania 6427TE 27" TV
Televison & Video Logo
332 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
