Question about Garden
Will not start when hot,runs well when starting from cold,will run and work hard using a complete tank of fuel, but will not start after refuelling.I can start it by removing spark plug and pouring a small amount of fuel in the cylinder.
  • dontbother10
    dontbother10 May 11, 2010
    If my saw I'd take it to local Stihl shop for pressure tests of fuel system and fuel tank vent. I think you may have leaks in fuel supply system. Lou
    Problem Solver:
  • 15 Answers
It can be a multitude of things. Without knowing what kind of saw it is, I might venture a guess that it might have a buildup of sawdust between the engine case and the fuel tank. This causes it to run MUCH hotter than normal, which causes the gas to get way too hot, making starting very hard. On older Homelite saws, if it isn't kept clean it will acually boil the gas in the fuel tank. Take the starter cover off, and blow it out as good as you can with compressed air, wearing safety glasses.
Posted on Nov 20, 2009
200e chevy tahoe sputtered shut down while driven on turnpike after getn gas started back up few minutes later thot it was bad gas what else could be problem
It could be the fuel pump. The pump is in the gas tank. The pump is actually cooled by the fuel. Occasionally, in hot weather, when the pump starts to get old, if you run the fuel tank very low, the pump will heat up. Then, when refueling, you are putting fuel in the vehicle that comes from underground at about 50 degrees F. This can cause the pump to fail.
Aug 01, 2014 | Cars & Trucks
They put gas in my trimmer instead of the fuel oil mix snf now it will not start. what must i do??
Drain tank completely, pump primer to drain that back into the tank, empty tank again. Refuel with correct fuel oil mix 50:1. Hopefully if it wasn't run too much, it might not have dameged the cylinder and piston. keep your fingers crossed
Jul 31, 2013 | Garden
Hard to start at times hot or cold
engine wont start cold or hot could be fuel problem.check for fuel or spark.try doing little troubleshooting make sure sparkplugs and wires good condition.fuel filter been changed.engine need fuel and spark ignition to run.turn ignition on listen for fuel pump operation in fuel tank if no check fuel pump fuse and relay.if fuse relay okay.problem could be the fuel pump but first use code scanner look for PCM, CRANKSHAFT POSITION SENSOR,CAMSHAFT SENSOR AND DISTRIBUTOR IGNITION FAULT CODE.MAKE SURE YOU HAVE FUEL INTANK I SEEN THAT HAPPEN BEFORE.
Dec 27, 2012 | 2002 Lexus RX 300
My 1996 chevy truck want stay runing,when i push the excelerator it die i change the fuel relay,i reset the distribution timing. please help
You may have the same problem my Wifes car has right now- ice in the fuel line.
Dump a can of DryGas (or "Heet") in the tank, and after about an hour, start your truck. Let it run for 15 minutes or so (restart if it stalls) - if it will not run that long try moving your truck into a warm garage, let it sit for about an hour, and try again.
The DryGas does not perform miracles, and takes time, especially in the bitter cold as of late.
Fuel line icing is usually caused by allowing your vehicle to run nearly empty, and then refueling in cold weather. This causes condensation in the gas tank, which freezes in the gas lines.
I have repeated this mantra to my Wife for nearly our entire 27 years of marraige, but she still will run her tank nearly dry before getting gas, even though it has so far cost us two replacement gas tanks, more than a couple gas tank leak patches (the other problem with running low all the time is rotting out your tank!), and uncounted winter car starting problems. Please help me break the trend!
Feb 01, 2011 | 1996 Chevrolet C1500
Starts only when it cold and does not start whwen hot
just off the top of my head. it may be the fuel pump relay, when its cold it is ok. but when hot it will not work. check it out. hope this helps. have a good day. if when hot. see if fuel pump is running, just get under car at tank in back. and have a person turn the key to on, while you put hand on tank to feel vibration. if pump works its not the relay. if it does not when hot,it is the relay! a fuel pump only turns on a few seconds to get fuel to engine, then when running it is on all the time.
Jan 19, 2011 | 1999 Land Rover Discovery
2001 GMC Jimmy is Hard to start after refueling only. Runs great after finally starting until next refuel. Tried new fuel cap but engine light comes on and shows P1441 on code reader. Says it could be Evap...
Try filling up a little less. To me it sounds like a vapor lock issue which clears after you burn off the top bit of gas.. Next time you need fuel up be sure to keep track of how much you put in. Another idea is to run the tank down and then only fill up to half a tank. If the problem clears then you know that you're having a vapor issue probably due to gas saturation of the canister (which can happen if you overfill the tank).
Nov 06, 2010 | 2001 GMC Jimmy
Difficult starting when hot. When first
First suspect is the fuel filter which is combined with the tank fuel connection. Remove the rear engine housing to access the tank. To access the carburetor, the front housing must be removed. The worst part of this is disconnecting and reconnecting the throttle wire from the carburetor. You might try running some fuel system cleaner through before going through this procedure. Good luck!
Apr 19, 2010 | Garden
Starts ok when cold. acts like it's out of fuel when hot.
Clean or change the sparkplug. Also make sure you have fresh gas and the proper fuel mix.
Jul 23, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Audi 80e 1991 hard starting when cold
I've owned the same car. Check that the fuel relay 'primes' the system before you start the car. When you turn the key to the on position (all you dash lights, ready to start) you should hear the fuel pump run for a second or two. If it doesn't run you can replace the relay for about $30. If the relay is not the problem, it may be a check valve within the fuel line to the engine. This valve keeps fuel from draining back to the tank when the car is sitting. That way, there is fuel close to the motor when it's time to start. The temp senor was not a bad shot, they were thinking it was bad sensor not telling the cold start injector to run. Obviously not the case. However, the injector itself may be faulty in some way. As long as the car always starts, it's one of these problems, assuming the ignition system and engine mechanicals are in running order.  good luck. JK
Jul 05, 2008 | 1991 Audi 80
Garden Logo
62 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
