Question about Cameras
I'm trying to replace the date-time battery in a digital rebel 300D. I can't get the battery holder out.
5 Suggested Answers
koraypek
  • 6 Answers
SOURCE: digital rebel EOS 300D
The card reader on this camera is soldered on the mainboard, therefore it requires professional SMD soldering equipment and skills, sadly, not a DIY job. You either sell it for parts on ebay, or buy a broken one (with a good mainboard) from ebay, and replace the mainboard. That should cost you around £50-60 (far less than a professional repair job)...
Follow this link on disassembling 300D (in case you want to replace the mainboard yourself)...
http://ghonis2.ho8.com/rebelmod.html
Good luck!..
K.
Posted on Sep 21, 2008
old marine
  • 1992 Answers
SOURCE: Will a quantaray 28-105 1:3.8-5.4 Zoom lens
The 35mm Rebel Ti and the Rebel 300D use the same lens mounting protocol. All Canon cameras designated 'EOS' use the autofocus EF lenses. If your Quantaray lens worked on the Rebel Ti, it will fit and should work on the Rebel 300D.
Posted on Mar 20, 2009
  • 155 Answers
SOURCE: 300D Digital Rebel is in truble err99
Try the following diagnosis steps: -
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Posted on May 05, 2009
  • 3 Answers
SOURCE: My Digital Camera, EOS 300D, Digital Rebel EOS 5D
There are two was around this:
1) Get an external USB card reader - I recommend this, because it is faster and does not require any software updating
2) Download the latest EOS Utility from the Canon web site; you also need to download the latest drivers. The cameras you name are supported by Vista, but the original software isn't.
Posted on Aug 29, 2009
Battery door latch broken
look for a Canon eos 300D battery door (they are the same camera just came out in different countries) or buy of ebay a cheap broken 300D and salvage the parts that way.
Mar 21, 2013 | Canon Eos Digital Rebel Ds6041 6.3 Mp...
I need a replacement for my battery door for canon eos 300D
You can order the part in a choice of color from
http://uscamera.com/drebel.htm
Sep 24, 2011 | Canon Digital Rebel / EOS-300D Digital...
Date in camera menu resets to 00/00/0000 every time I remove battery to recharge it and meta data for each shot shows 01/01/1980 until I reset date in menu.
The back battery is faulty and it is important that to keep your date in order the battery needs to be replaced. You will need to open the camera to check the back up cell.
Feb 09, 2011 | Canon Digital Rebel / EOS-300D Digital...
Will a quantaray 28-105 1:3.8-5.4 Zoom lens Autofocus from a 35mm rebel ti fit on Canon EOS Digital Rebel 6.3 MP 300D?
Mar 19, 2009 | Canon Digital Rebel / EOS-300D Body only...
Canon rebel eos ds6041
DS6041 is the model number for Canon EOS Digital Rebel or 300D. It is a 6.3 megapixels DSLR camera from Canon.
All software and manuals available from the Canon site
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=314&modelid=9430
Feb 18, 2009 | Canon Digital Rebel / EOS-300D Digital...
ERROR CODE C--6C CANON DIGITAL REBEL CAMERA
This code means that your backup (date/time) battery is dead and needs to be replaced. This is a small button battery that maintains date and time settings and other settings when the main battery is removed from the camera. You will need to get a CR2016 battery (button battery). It is located in the battery compartment, in a plastic holder right next to the battery door hinge.The holder should slide out of its socket.
Apr 29, 2008 | Cameras
Level Warning
battery level. charge it or replace it if it does not come up to full power state. the camera has a batter meter. refer to the manual and see if the battery is low. it requires you to push a few buttons while looking at the data window.
not really difficult.
the battery that might be dead or extremely low is the small battery that keeps the date etc, which is much like a large watch battery.its usually coin shaped, but on some models its a small version of a aaa battery only slimmer and shorter. not sure which that unit uses now.
if these are both ok, then you probably have a service issue
good luck
mark
Dec 12, 2007 | Canon Digital Rebel / EOS-300D Digital...
NO POWER
I would have to agree sounds like a motor or gear that the motor turns.
Dec 10, 2007 | Canon Digital Rebel / EOS-300D Digital...
Cameras Logo
35 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
