Question about Sony BRAVIA KDL-40V2000 40 in. LCD Television
I can switch channels from reg TV to hd with no problems viewing but when i change the channel from hd back to reg. 480p the screen goes split and unviewable. I have to turn it off and on again. Whats the problem?
    Sergeant:
    Champion:
  • 245 Answers
CALL SONY SERVICE CENTER AND ASK FOR HEP
Posted on Nov 20, 2009
Brand new TV with Light leakage on the screen
I happen to have the same tv brand, size, and problem. The only difference is model. I bought mine black friday 2012 and its got screen problems. Im looking for a solution also to why it has the problem it has. It was working great for the time being until i noticed cloudy white spots around the perimeter edges. I found out its do to a few possibilities. One is the one thats wrong with mine that i believe is dead pixels. My tv doesn\'t look damaged in the screen butt when the image darkens while watching tv u can see it. Its like a bleeding discoloration. Me personally im taking mine back to either get my money back or new tv. From ur breaf description sounds like u have the same issue except yours came that way.if u look at my follows on here u will see pictures of my tv and the issue to my screen. I bought mine from best buy. So i got a thirty day store return warranty plus i purchased a 2 year warranty. So im going back and going to see what they are going to say. I advise u to probably do the same especially if u got warranty.
As far as changing ur setting for HD picture quality with ur dish is to go through your menu options on the dish.i use comcast so mine is different butt im sure in a way the maybe might b in somewhat similar. With comcast theres a format button on the front of my box that i can press to change different format quality. If that dont give u what your looking for then see if you turn off your box while tv is on and then press menu on box and see if a user menu pops up if so then u should be able to change quality. You then can program it to be 1080 if ur using hdmi or components. One thing with comcast box is that i can make every channel 1080 bt the regular channels that dont broadcast that quality makes the picture smaller. So then u have to have HD channels to get 19080 quality. Butt u can get a good quality setting still with regular broadcast channels by overriding to 480p or to the best quality its puts out to that channel. Most broadcast channels set out a 480i or a a better HD 480p. Other than that you have to have HD channels and then ur box should automatically format to 1080u quality on the HD dish channels so you dont have to keep changing. Then when change ur channel back to standard broadcast channel it will automatically format to back to 480peither and so one as you change channels. Well hope it all helps and you got what you were looking for.
Dec 04, 2012 | Westinghouse " 46"" Class - LED - 1080p -...
Mitsubishi VS-60805 Rear Projection won't operate in HD mode with Cable Box
Since this is an older first generation (1999) HD TV it may not be compatible with newer HDTV receivers because the standards back then were different - Make sure the HD cable box is plugged into the HD component inputs on the back of the TV (not the DVD inputs) and that the menu setting on the TV is set to DTV (not RGB) video. This TV will only accept 480i and 480p signals on the DVD input. Also the HDTV input will only accept 480i,480p and 1080i (it will not work with a 720p signal,make sure your cable box is not set to that mode)
Aug 17, 2007 | Mitsubishi VS-60805 60" Rear Projection...
The aspect ratio on the HD channels are full screen - which is correct. However all other channels have the incorrect aspect ratio. (reduced size) A solution please???
Many times HD channels will come in more clear, but with a smaller picture or widescreen view. There should be a button on your remote called 'wide' or 'zoom' and it will let you adjust the size on the fly. If you adjust the view while watching an HD channel, and you switch to a standard channel, you will have to change the ratio back. For other information and help with LG TVS visit http://www.lg.com/us/support. Thanks
Mar 31, 2011 | LG 42SL9000 42 in. HD-Ready LED TV
Switching between a 720 hd channel and a 1080 hd
The unit has an auto detection circuit to determine what signal is being input, it then processes it, however if the signal is altered (different channel) the TV will at times try to process it through the wrong resolution circuit causing problems. Change the input of the TV and then change it back and it will redetect the 720p instead of the 1080i and display it properly. Check with Sony for possible updates.
Crampy
Nov 28, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Split screen
Yes I get the same problem with my Sony XBR and its Pace PVR.
The problem seems related to using HDMI interconnects; viewing the PVR through component leads allows the TV to switch modes easily, otherwise I have to turn the tv off and then back on again.
Nov 14, 2008 | Panasonic PT-52LCX66 Projection Television
Picture shifted to the lift
Press menu on remote and tab over to settings
Scroll down to tilt correction
Sep 10, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Color screen
If you are hooked up with a DVI cable you need to either use hdmi, component cables or turn off the non hd override...
Jun 15, 2008 | Toshiba Regza 32LV67U 32 in. LCD HDTV
HD channles
Hi Scan 1080: Enables you to receive the 1080i, 720p, 480p and 480i digital TV formats. By using the VIDEO 5/6 IN jacks, you can connect a DTV (digital television) receiver to view DTV programs. q DRC Multi-Function: Unlike conventional line doublers, the DRC feature doubles vertical and horizontal lines, resulting in four times the density for quality sources such as DVD, Satellite and Digital camcorder. q CineMotion: Using the 2-3 Pull-Down technology, the CineMotion feature allows you to obtain a smooth picture movement when playing back movies or other video sources on film. q Twin View: Using Multi-Image Driver (MID-X), Twin View allows you to watch two programs side by side with the ability to zoom in one picture and listen to selected window. You can watch pictures from two different sources (1080i, 720p, 480p or 480i) simultaneously. q 16:9 Enhancement: Vertical Compression technology that maximizes picture resolution on “anamorphic” or “enhanced for wide screen” sources, including selected DVDs. q Steady Sound: Equalizes volume levels so there is consistent output between programs and commercials. q Parental Control: V-Chip technology allows parents to block unsuitable programming for younger viewers. q Component Video Inputs: Offers the best video quality for DVD (480p, 480i) and Digital Set-top box (1080i, 720p, 480p, 480i) connections. q S-VIDEO Inputs: Provides a high-quality image for connected equipment. q Favorite Channel Preview: Preview up to eight favorite channels
Jun 02, 2008 | Sony KP-61HS20 TV
Picture shifts to left
I had the offset left issue for non-HD channels with my Panasonic 42" plasma, using Comcast HD cable box. Went into the configuration menu (to get there with the newer Comcast boxes, you have to turn the box off, then hit the menu button on the box immediately after). You will see on the menu a resolution (probably says 1080i), then below it a "4:3 override". Our said 480i. When I changed it to "none", so that it stayed 1080i, it worked! It also works by selecting 480p, but then the picture is stretched.
Mar 13, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
HD Issue
are you using scientific atlanta cable box by any chance?
Nov 27, 2007 | Mitsubishi WS-48613 48" Rear Projection...
Sony BRAVIA KDL-40V2000 40 in. LCD Television Logo
101 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
