Question about Intuit QuickBooks Pro 2007 Full Version (299116)
Quickbooks does not recognize license key after reinstall to repair. This is a multi user license.
    Guru:
  • 830 Answers
Hello and thank you for using Fixya's services.
You will need to call Quickbooks customer service and they will re-activate the licnese for you. They do this so that it will keep the license safe from pirating or stealing.
Hope this helps!
Posted on Nov 19, 2009
Testimonial: "Thanks! We'll try that next."
I need QuickBooks Pro and Premier Accountant License
Intuit QuickBooks Software Reseller 1 844 414 4868 Find an Intuit Reseller near you - Experts you can trust, Intuit Resellers ... Intuit and QuickBooks are registered trademarks of Intuit Inc
Apr 22, 2014 | Intuit QuickBooks Pro 2011 (License Only)
I need prodouct key for quickbooks 2014
Apr 17, 2014 | Intuit QuickBooks Pro 2011 (License Only)
I can not activate QuickBooks Pro 2006, Please help me.
Your only solution is to call Quickbooks help. Give them your license number and they will be able to walk you through how to re-activate your license.
Note: If you are attempting to install quickbooks on a second computer and you purchased a one user license, that will be the reason. They will make you pay for another license. You can only load Quickbooks single user license on one computer.
Hope this helps.
Aug 09, 2013 | Intuit QuickBooks® Pro 2006 Full Version...
I am installing quickbooks 2011 Pro and keep getting Error code 3371 status code 1
The 3371 error means that the software couldn't read the license information. possibly due to an incomplete install. You need to reenter the license; you may need to do a full uninstall and reinstall. Have the license available before starting.
First try just deleting the license file:
Close Quickbooks if it is open. Depending on your OS, search for the hidden folder with the license file and delete EntitlementDataStore.ecml . (You may need to enable viewing of the hidden folders. This is accessed via the File Explorer. Double click the Computer (My Computer in XP) icon (or Start > Control Panel > Computer) to open the explorer. Click on Organize and go to the Folders and search options. In the View tab, select Show hidden folders.) For Windows Vista or Win 7, search for C:\ProgramData\Intuit\Entitlement Client\v6.0 . In XP, you need the folder C:\Documents and Settings\All Users\Application Data\Intuit\Entitlement Client\v6.0 . Just select the file and choose delete then confirm the delete command. Launch Quickbooks and follow the on-screen directions for registering the program.
The MSXML 4 software may be damaged or missing. This program is on the CD; however it may be better to download it from Microsoft, http://www.microsoft.com/downloads/details.aspx?FamilyID=7F6C0CB4-7A5E-4790-A7CF-9E139E6819C0&displaylang=en . Try to repair the software with the command msiexec.exe /fvaum "%userprofile%\desktop\msxml.msi" (then press enter) with the above file saved to the Desktop. (Click Start or Start > Run, depending on the OS.)
If the repair doesn't work because the program isn't installed, install with the downloaded file. Otherwise uninstall it (Start > Control Panel > Programs > Uninstall) and then reinstall first the MSXML 4 and then Quickbooks.
If the above step doesn't work, then you need to uninstall Quickbooks completely. First uninstall Quickbooks from the Uninstall Wizard mentioned above. Then run the Clean Install Utility from Intuit, https://www.quickbase.com/up/bd9yykidd/g/r9/eg/va/QuickBooks%20Clean%20Install%20Utility.exe , to remove any information from the program that was left after uninstalling. Reinstall Quickbooks after clicking OK when the program says Quickbooks is ready for a clean install.
You could manually rename the installation files instead of using the Clean Install Utility but that would clutter your hard drive.
I hope this helps. Let me know if you need any help; if you do, please add a comment with your OS.
Sep 19, 2012 | quickbooks.com
Error code 3371 status code 0 QuickBooks SimpleStart 2008
http://support.quickbooks.intuit.com/support/articles/sln40318
Aug 02, 2011 | Intuit QuickBooks Pro 2008: Windows
Can't install quickbooks pro 2009
Sounds like you have the QuickBooks Database manager running or the Quick Connect feature still installed and/or turned on. Check and see if this is the problem by going to start and then programs and see if it says QuickBooks anywhere. If it does, slide over to see which of the two listed above are on. Then go to your control panel and uninstall the program. Double check to make sure the "quickbooks" catagorey disappears from your programs and then install the new version you wish to keep.
Jul 06, 2010 | Intuit QuickBooks Simple Start Edition...
I am getting error codes 6129,0 and 6073, 816 on my quickbooks 2008. What can I do to open the company?
This error can occur when:
  • Data is converted or restored over a network.
  • Several computers are acting as host for the QuickBooks data file.
  • QuickBooks is unable to communicate with the server.
  • There is data damage in your company file.
If the error occurred when you were restoring a company file from a backup or updating a company file to a newer version of QuickBooks over a network:
  1. Copy the backup file (.qbb file extension) or the company file you want to update (.qbw file extension) to a local hard drive.
  2. Restore the backup or update the company file.
  3. Copy the restored or updated company file back to its original location.
If the error occurred when you were trying to open and use a company file:
  1. Update QuickBooks to the most current release on all computers that open the company file.
  2. Close QuickBooks on all the computers with access to this company file.
  3. On the computer you select to host the company file, switch to single-user mode, and then back to multi-user mode:
    1. Open QuickBooks and open the company file.
    2. Choose File > Switch to Single-user Mode.
    3. Choose File > Utilities > Stop Hosting Multi-User Access.
    4. Choose File > Switch to Multi-user Mode.
    5. Choose File > Close Company to close the company file.
  4. On all other computers that will use the company file, stop hosting multi-user access :
    1. Press and hold Ctrl while you open the QuickBooks program and continue pressing Ctrl until QuickBooks opens completely. This opens QuickBooks without opening a company file.
    2. Choose File > Utilities >Stop Hosting Multi-User Access. If that option doesn't appear, the computer is not hosting and no further action is necessary.
    3. Repeat steps 4.a and 4.b for each computer other than the host computer.
  5. Configure the QuickBooks server for multi-user access:
    1. Click the Windows Start button and choose All Programs > QuickBooks > QuickBooks Database Server Manager.
    2. Click the Scan Folders tab.
    3. Click the Add Folder button, select the folder that contains your QuickBooks company file, and click OK. Repeat this step if necessary to add additional company file folders.
    4. Click the Scan button to begin scanning. After the scan is finished, the company files in the scanned folders are configured for multi-user access.
  6. Open the company file in QuickBooks. If you receive the same error message, refer to Settings required for firewalls to make sure your firewall is properly configured to allow QuickBooks access to your company file.
  7. Open the company file in QuickBooks. If you receive the same error message, open a different company file or a sample company file located in one of the folders you scanned with the Database Server Manager.
    • If no company file will open, reboot the host computer and try again.
    • If other company files open without error, the company file generating the error message may be damaged. For more information refer to Verifying and rebuilding QuickBooks company data.
Jun 01, 2010 | Intuit QuickBooks Pro 2008: Windows
Quickbooks 2008 reinstall
Yes, the license key and produsct code are required. These are embedded into the windows registry at the time of install, and are not stored in the backup.
In fact, these need to be entered to get the software operational to restore the backup file.
Mar 03, 2009 | Microsoft Office Professional 2007 Full...
License key of Quickbooks Accountant 2006 Edition
License key MUST be provided by manufacturer togather with product CD. If you got a CD copy from someone and want to register it, please refer to the producer website. Thy sometimes want people to call them, sometime you can register the copy online.
Oct 16, 2007 | Microsoft Office Professional 2007 Full...
Intuit QuickBooks Pro 2007 Full Version (299116) Logo
510 people viewed this question
Top Intuit Computers & Internet Experts
Alun Cox
Chris Larocque
Mike
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
