Question about Kenmore Elite 45986 Front Load Washer
My calypso washer does not start none of the buttoms turn on?? I check the plug looks fine and i tried it in different outlets as well? Please help
    Problem Solver:
  • 5 Answers
Have you tried other appliances in the same outlets ?? if outlets are fine, fuse in plug is fine, then you have a problem with the machine, most likely problem is with the programer, you could try holding in the on/off button and cancel button, failing this, its an engineers visit.
Posted on Nov 19, 2009
My Kenmore Calypso washing machine has is
Where the power cord goes into the washer is a small box called a line filter. It is there to protect the electronics in the control. It might be that the line voltage filter has failed. Remove the rear panel on the control to access it. Calypso Service Manual
Jul 12, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Machine won't start- checked plug -didn't start- used yesterday and worked fine. tried unplugging and replugging but didn't help. Help!
Make sure that the AC receptacle has voltage by plugging in another device. If it is dead, the breaker servicing that outlet may have tripped (without reason, I've replaced a couple of failed breakers) or the outlet may be protected by a 'Ground Fault Interrupter' (GFI). If this is tripped it would be due to either a momentary imbalance of the line or possibly electrical leakage within the washer. This latter problem needs to be cured as it presents a safety hazard if the GFI fails to trip as it should.
Dec 14, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
We went camping for 2 days came home and the calypso washing machine won't start. We ran a load the day we left with no problems. The outlet works fine, we even tried plugging it into another outlet just...
The same happened with my Sears Calypso machine. The common problem is the front display panel. If you are able to find one at a very good price, post it here.
Aug 09, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Pf error
Pf is power failure code you must push clear or reset washer by unplugging and plugging back in Good luck
Mar 07, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Trips GFCI receptacle for laundry circuit.
I ran into this problem with a washer this summer. the gfi breaker needs to be replaced. it is weak and trips easily. if you can run an extension cord to an outlet without the gfi andrun your washer, you probably will not have any issues. that is what I found with the washer this summer. when it was plugged into the gfi, itwould trip. but when I had it plugged into a regular outlet, it was fine. Joe
Nov 18, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Unit will not turn on
I plugged in the coffeemaker at an outlet in a different room in the house. Apparently, none of the plugs in the kitchen worked (although) other appliances did work in the kitchen outlets (very strange, perhaps the coffeemaker needs more juice than other appliances) Now I have to have an electrician come out and fix the kitchen outlets...
Aug 23, 2008 | Cuisinart Thermal DGB-600 Grinder
Whirlpool Calypso Problems
Make sure the outlet has power, if it does then you have a control board issue or possible wiring problem inspect/test control board input voltages
Sep 26, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Washer won't turn on
try running an extension cord to another outlet (another circuit breaker). ensure the cord is not too long (25 feet ok) and able to carry 15 to 20 amps (use 12 AWG cord).
Sep 03, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
96 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
