Question about Sony Cyber-shot DSC-W170 Digital Camera
Cybershot will not power up it has been charged and i tried removing the sd card and battery then reinstalling them and still no power. It tried to turn on but shut down. Its giving the error messag too Turn off and turn back on!!! and when it does nothing.
fausto1980
SOURCE: "Turn the power off and on again" error message
I just had the same problem and I didn't know what to do and I found this post it was somewhat helpful. After I read this I disassembled the camera and I pulled out the lens cover up a bit its held by this white plastic inside be careful not to pull to hard because it looks like it could break easily. After I got the lens cover a little bit above the lens itself I powered it up and the lens MOVED! I tested it again and it worked. So I placed the lens cover back over the lens. And it all back together. It was a really quick fix it took me less than 10 minutes. I hope this is helpful to anyone that gets "Turn off the power off and on again" error.
Posted on May 01, 2007
INTERLOGIC
  • 326 Answers
SOURCE: sony cybershot dsc-w200 zoom system error
try formatting the cam
Posted on Jan 17, 2009
SOURCE: camera says SD CARD NOT INITIALIZED
card not initialized
Posted on Jul 17, 2009
  • 11967 Answers
SOURCE: C190 does not read the SD card even when SD card
Where are you formatting these cards? You're supposed to do them in the camera.
Posted on May 02, 2010
SOURCE: My sony cybershot dsc-w220 will not turn on the
I have the same problem and best buy said it was the motherboard and I'm trying to figure out how much that cost... good luck
Posted on Oct 16, 2010
Tried downloading to my computer from my Nikon p60o,now camera will not turn on
Have you tried removing the battery, charging it, reinstalling the battery and then powering it on. also remove the memory card and reinstall it. You didn't say whether you had removed the usb cord either.
Oct 05, 2014 | Nikon Coolpix P600 Black Digital Camera...
I reformat my sd card in the computer to remove all the photos the when im using it in my sony cybershot camera it appears "reinsert memory card" how can i fix the it to use it again in the camera
When you need to delete the photos from the SD memory card, do not use your computer to do it. Use your camera to format the SD memory card.
To fix this problem, insert the SD memory card in your camera then go to the camera's Menu and format the SD memory card.
Nov 03, 2012 | Sony Cyber-shot DSC-W80 Digital Camera
Canon cybershot
It's not the memory card. Try the procedures in this tip.
Aug 13, 2012 | Sony Cyber-shot DSC-W170 Digital Camera
Sony cybershot dsc-w330 functions buttons does not work
Remove the battery and the memory card, press and hold power for 60 seconds this should remove residual voltage and reset the processor ic, if there is no change the systems controller board has failed, cheaper to replace camera.
Jun 09, 2012 | Sony Cybershot W330 Digital Camera
Will not power up when charged
try restting your 920
  1. Check that the battery is charged properly.
    Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
  2. Remove the SD card
    If your device uses an SD card, remove it.
  3. Reset your device.
    Use a straightened paper clip, or something similar, to push the reset button for 15 seconds.
  4. Turn your device on.
    Press the On/off button for at least 5 seconds.
  5. If your device uses an SD card, insert the SD card.
Aug 26, 2009 | Tomtom GO 920 GPS Receiver
Kodak M1093
It requires service or repair
Sep 05, 2017 | Kodak EasyShare M1093 IS Digital Camera
Sony cybershot 4.1 won't recognize SD card
Try another SD card all SD cards (even though they fit and look the same) are not compatable withall devices
Hope this helps ya!
(Please rate to help keep this site free!)
Thank You
Dec 15, 2008 | Sony Cyber-Shot DSC-P2 Digital Camera
My sony cybershot t-70 does not turn on, the battery is fully charged. I don't know what to do.
Remove the SD card then try to turn it on.
you might need to reformat the SD card on a computer with a card reader if the above works
Dec 04, 2008 | Cameras
My Camera will not turn on
try removing the battery and the memory card and reinstall memory card and battery then recharge battery- connect camera to ac adapter and try powering it on.
Apr 05, 2008 | Cameras
Sony Cyber-shot DSC-W170 Digital Camera Logo
24 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
