Question about GE Energy Star WCVH6260F Front Load Washer
Why does it take so long to run a load of laundry in my GE Profile front loading washer?
    Problem Solver:
  • 5 Answers
Check the water supply, if the water supply is restricted in some way it will take a long time to fill, the m/c may need to fill 4 or 5 times in a complete wash.
Posted on Nov 19, 2009
I am finding the soap dispenser is full of water when I begin a new load of clothes. Where is it coming from? What should I do about it? I have a GE Profile Harmony.
Check that your machine is level or set according to the manual.
If it is tilted forwards the water cannot run out of the dispenser under gravity, which is how it empties.
Nov 06, 2014 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
What is the capacity of the GE Profile WPRE6100G?
• King-size, 3.5-cu. ft. stainless steel basket makes room for more items, which
means less time doing laundry
Oct 25, 2014 | GE Profile WPRE6100G Top Load Washer
Leaking into wash tub
The water inlet valve needs to be replaced. It is not sealing.
Here is a link to the part you need.
Aug 13, 2012 | GE Profile WPRE6100G Top Load Washer
GE top load profile washer won't spin. It starts
The tub hangs on 4 support rods. Lateral movement is kept in check with 4 bungy cords bolted to the top of the tub. If that washer is not level the tub will hang to one side and the fancy controls will declare an error. Make sure all your rods are good (they drag the base of the machine when worn out and make a heck of a racket) and the bungys are not stretched and the machine is level.
Aug 04, 2012 | Washing Machines
GE Spacemaker Washer Tan does not spin or drain
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 20, 2011 | GE Spacemaker Washer and Dryer Electric...
GE top load Profile washer. Spin cycle not
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 11, 2010 | GE WVSR1060A Top Load Washer
Water leaking from underneath the front of the washer..
It could be a seal on the bottom of the tub or a loose or damaged hose where it pumps out. It could also be a loose hose on the water level switch. Remove the front and run it to check it out.
I believe you need to pry up slightly on the top and reach through the gap with a small screwdriver and press on the clips on either side to release the top and lift the top. Then there are two screws that hold the front to the sides and you should be able to lift the front off. Good luck.
Mar 07, 2010 | GE Profile WPRE6100G Top Load Washer
I am trying to fill the washer to do a load of laundry but the water is coming out the back of the washer instead what should I do
Open the washer and make sure the tube is not sitting forward .If not then you will have to lift the top of washer up and cheak for leaking hose.Also when washer is filling look with flashlight behind it to see if there is a leak there.
May 20, 2009 | GE Profile WPRE6100G Top Load Washer
GE Energy Star WBVH5200 Front Load Washer
My GE Energy Star Front Load Washer is reading 5.9 instead of 59 minutes and not washing clothes. We cleaned the filter and still no luck. Please help.
Jul 30, 2008 | GE Energy Star WCVH6260F Front Load Washer
Ge front load washer
because the frontloaders are set up differently and use less water. The regular soap sudds to much and can cause a number of problems in front loaders.
which can be but not limmited to burned out pump, motor etc.
Mar 19, 2008 | GE WSXH208A Front Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
456 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
