Question about Garden
11 hp briggs and stratton engine blows gas back through carburetor Valve clearances are 0.005''
  • 169 Answers
U have a poss bad intake valve and or a poss sheared flywheel key causing the engine to fire when the valve is open Hope this helps!
Posted on Nov 19, 2009
Valve adj. B&S gen. Model 030246 10 hp. OHV
Briggs and Stratton Valve Clearances
outdoorpowerinfo.com/engine_specs/briggs_valve_gaps.asp
Briggs & Stratton Intake and Exhaust Valve Clearances. Model Series, Engine Type, Intake Valve Clearance ( in. ) Exhaust Valve Clearance ( in. ).
Briggs and Stratton 10hp Generator Carburetor Repair ...
? 6:17
https://www.youtube.com/watch?v=O-fROtibEvE
Jun 5, 2010 - Uploaded by IFIXIT4U
In this video I will show you how to clean the carb on a Briggs10hp. This is a Nikki carb.
Nov 03, 2015 | Measuring Tools & Sensors
What are the torques on a 22hp ohv briggs and stratton head and also push rods
VERIFY your engine model numbers
Briggs & Stratton Intek V-Twin
Engine Model Numbers 407777 and 44P777
Cylinders 2 (Dual cylinder)
ITEM N m (Newton metres) lb-in Spark Plug Torque 20 180 Back Plate (to cylinder) 11 100 Blower Housing Screws 9 80 Breather Screws 6 55 Carburetor to Manifold 7 65 Cylinder Head Bolts 25 220 Cylinder Shield 7 65 Crankcase Cover 23 200 Engine Mounting Bolts 48 35 lb-ft Electric Clutch Mounting Bolt 75 55 lb-ft Exhaust Manifold 16 140 Fan Retainer Bolts 16 140 Flywheel Nut 203 150 lb-ft Armature Mounting Screws 3 25 Intake Manifold Bolts 9 80 Rocker Arm Adjustment Lock Nut 7 62 Rocker Support Screws 11.3 100 Valve Cover Cap Screws 11 100 Carburetor to Intake 7 65 Valve Clearance (Cold) 0.10-0.13 mm (0.004-0.005 in)
WARNING: Uneven tightening will warp the head. Tighten Cylinder Head Bolts down evenly by hand. Then using torque wrench tighten in sequence, in 9 N m (80 lb-in) increments to 25 N m (220 lb-in).
Intake valve push rods are aluminum.
Exhaust valve push rods are steel.
DO NOT interchange push rods.
Removal and Re-installation sequence for bolt removal and tightening.
Mar 21, 2015 | Garden
Why does my Briggs and Stratton backfire through the carburetor
Ignition timing. Possibility of keyway in crankshaft being damaged. Intake valve. Check engine compression and intake valve clearance. Lean mixture. Check torque on bolts holding carb and intake.
Jun 19, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
What causes a lot of gas in oil on 8.5hp B&S
This would be caused by a sticky needle valve on the float in the carburetor.You have three cures 1. remove and clean the carburetor internally. 2. replace the carburetor with a new one. 3. or most simply buy and install a fuel shut off valve and turn it off when not in use. make sure you change the oil 1 4 ID LINE GAS FUEL SHUT OFF VALVE TECUMSEH BRIGGS
Jun 03, 2014 | Briggs & Stratton Briggs Stratton Intek V...
How tocheck timing onbriggs stratton model44577
The timing is fixed, if you suspect the timing is off the only adjustments available are the .030 clearance from pickup to flywheel and the shear Key that positions the flywheel on the crankshaft. You would also want to make sure your valve clearance is .030 as well, the issue sounds like a valve leaking, a dead cylinder or mal adjusted valve clearance causing the exhaust valve to hang open just a bit.
May 13, 2014 | Briggs & Stratton Briggs Stratton Intek V...
How do I adjust the valves on a Briggs and Stratton Intek V Twin
Remove the valve covers look up your valve clearance specs turn the engine by hand until the piston is at top dead center then go 1/4 turn past that and then put a feeler gage for the valve clearance you need for that valve and snug up the adjustment nut. Check your oil when your done some oil will spill out when opening the valve cover.
Apr 17, 2013 | Briggs & Stratton Briggs Stratton Intek V...
16 h v-tech briggs-stratton is blowing oil into carburator, what could cause this problem and possable solutions
see if the oils coming out of the rubber hose by the air cleaner ,if it is it could be the pcv valve the rubber hose is connected to. order could be too much oil in the engine, sometimes the carburetor will flood the crankcase with gas , you have to rebuild the carburetor and change the oil.
Feb 18, 2011 | Briggs & Stratton Briggs Stratton Vanguard...
Garden Logo
335 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
