Question about Bulldog& Remote Alarm System With 1-wire Hookup
Installed a bulldoge security system into a 2008 Ford F150 and now the only time the vehicle runs is when it is hooked up to a battery charger. What could be causing this?
  • 344 Answers
You could take the fuse out of the main alarm harness for a couple of days and see if your problem persists
Posted on Jan 25, 2010
My heater fan won't work when car remotely started with Bulldog remote starter
The yellow wire at the ignition switch is not connected to the remote start system. Once it is connected to the accessory output of the remote start, it should work properly.
Jan 08, 2013 | Remote Starter with Keyless Entry
How to hook up bulldog 1-wire alarm
Hello my name is Israel and I will be glad to help you out. This alarm system uses a drop in voltage sensor to work. First mount the siren on a firm ground metal of the vehicle. Be sure that the base is mounted on metal and not plastic. Then, the best way for the system to work is to run the wire into the vehicle cab and connet the one wire to the positive side of either the dome light fuse or dome light wire. This will help in it "catching" voltage drops when the lights go on. Good Luck.
Feb 15, 2011 | Bulldog& Remote Alarm System With 1-wire...
Hi, I have RS92 in my 1998 ford E150 van. It has worked fairly well the first two years. This winter season I engaged the remote from several distances with no results. I installed a new battery...
  • Give Bulldog Security's support a call or shoot them an email. I've heard their support people are knowledgeable and friendly. techsupport@a2-c.com. Call: 800-561-1110
Oct 20, 2017 | Basic Remote Vehicle Alarm System
Have installed the Bulldog remote starter in my 2005 jeep liberty. I have to hit the button several times to get it started. I have already changed the jeep's battery.
There is some sort of a feedback to tell the starter if the unit is running - make sure you have the 'tach feedback' connected. There are settings for it to run the starter for specific length of time, or for it to know that it started by the tach feedback. Check your users' manual.
Dec 29, 2009 | Remote Starter with Keyless Entry
When it try's to start, my Jeep cranks 2 to 3
You have most likely installed the remote starter in the standard mode. You will need to follow the directions and hook up the tachometer wire and program the remote starter unit to start in the "tach" mode. That way it will continue cranking until the vehicle starts on your battery goes dead, whichever comes first.
Dec 16, 2009 | Remote Starter with Keyless Entry
Bulldog Deluxe 500, remote not starting the the vehicle
Remove the battery in your remote for 15 sec, then put back in, start your car with your key, wait 15 sec, while the car is running press the * star button 2 times, it should beep , if not try it again, if still nothing post me back and we can go from there
Feb 22, 2009 | DLX 500 Remote Car Starter
Set up
Turn the valet switch on, start the car with your key wait 15 sec, press the * star button 2 times with the car running, it should beep and program if not turn valet switch the other way and try again, if still nothing post me back and we will go from there
Jan 15, 2009 | Bulldog& Remote Alarm System With 1-wire...
Bulldog Remote Starter On 92 Blazer-Cranks but no fuel pump
I've wired several of these and you have likely hooked up the wires wrong its not giving power to the right wires at the bottom of your steering column...........re check your connections
on your truck there are 3 wires that need power for the starter to work they are the orange,pink and brown
hope this helps!
Dec 30, 2008 | Bulldog Remote Starter & T-Harness Kit for...
Remote won't work and parking lights blink
the blue wire needs to go to -input then unit should work
Nov 03, 2008 | Remote Starter with Keyless Entry
Bulldog& Remote Alarm System With 1-wire Hookup Logo
121 people viewed this question
Top Bulldog Security Vehicle Parts & Accessories Experts
John
John
baire
DROPNDEAL
DROPNDEAL
Are you a Bulldog Security Vehicle Part and Accessory Expert? Answer questions, earn points and help others
