Question about Gateway Solo 9550 Notebook
Will not start up successfully - Gateway Solo 9550 Notebook
    President:
  • 2,600 Answers
Try this to repair windows....follow the guide closely.
Windows Start-up Errors
Step one, you need a Windows Installation CD. If you only have a recovery disk set like the ones from HP or Compaq they will not do what you need done. Under normal circumstances however, you can use a Dell disk because the Operating system is on a stand-alone disk. All retail versions are also acceptable as well as upgrade disks. For a rule of thumb, if the disk has the Microsoft hologram it should work.
While the computer is first starting up and you see the manufacturers splash screen, tap F12 (some computers it’s F9, others it may be another key, you may have to watch and see if the computer lists the key strokes for getting to the boot menu. If you still cannot find it, boot into the BIOS settings and change your boot order there. Save your settings and exit, the computer will now seek the cd rom as its boot source first.
Place your Windows disk in the computer and start it up. When you see the test at the top of the page “Press Any Key To Boot From CD” Just hit the space bar to activate. The next screen you will see will most likely be a Windows setup screen, when you see this press the “R” key to get to the recovery console. It will get there, it may take a little time, patience. Once it loads you will be given a choice of Windows installations, there should only be one, if there are more, always pick number one. It may ask for an administrators password, if you have not set this particular password, then just leave it blank and press enter. The next prompt you see is:
C:\Windows>
You need to type the following:
cd \
hit enter. Pay close attention to the spacing between the characters. There is a space between the character “d” and the “\”
You are now at the ROOT of the drive, this is where basic commands can be given and changed. You should now see the following:
C:\>
Now type the following:
CHKDSK /R
Hit the enter key.
The chkdsk /r command also includes the P command and will also look for lost recoverable information in bad sectors.
There are occasions depending on how corrupt the system is, that this process could take several hours, so be patient with it.
Now, after chkdsk has run type the following:
FIXBOOT
Hit the enter key.
It may prompt you with a warning, that’s ok, just continue. When fixboot has finished, type: EXIT hit enter and windows will reboot. When the system reboots, tap the F8 key during this time and you will see the multi-boot menu come up. Scroll to the title “Last Know Good Configuration” and hit the enter key. If you were having some simple drive errors this should have fixed them.
Posted on Nov 19, 2009
Irregular ignition success with my 2004 Subaru Baja.
Replace the ignition switch.You can replace the key tumbler ignition.It mostly is faulty and giving u this problem.
Apr 02, 2014 | 2004 Subaru Baja
Tip
Why Start a Business from Scratch When You Can Buy One?
Have you heard about an alternative called entrepreneurship via acquisition? It's a simple concept. The entrepreneur buys an existing business which can be established as a successful enterprise. This concept has good chances of success than starting a brand new business.
To know more :http://www.biz2credit.in/blog/2016/10/07/starting-business-scratch-not-always-great-idea/
on Nov 25, 2016 | Miscellaneous
Tip
How to Start Home Based Bakery
Let us talk about Alisha, a successful bakery owner. Alisha left her engineering profession to spend some time at home, taking care of her twins. It was during this sabbatical that she started pursuing her hobby - baking for family and friends.
See more at: http://www.biz2credit.in/blog/2016/04/20/a-tried-recipe-for-a-successful-bakery-business/
on Apr 28, 2016 | Miscellaneous
12RES GEN.NAT.GAS FAILS TO START BY STRT BTTN AND TRNSFR SW
If the succession is 3-5 sec crank - 3-10 sec pause, it is OK, but the cranking is not successful (the reason should be investigated).
If the succession is more rapid 1 - 2 sec you may have bad PCB control.
Jun 03, 2010 | Kohler 12 kW Emergency Power System -...
My laptop can't start successfully,,what can i do? (we apologize we did not start successfully)
Best way is it start it in 'safe mode' or 'start with recovery disk' support and just do a reinstall of the os.
tx.
Jul 13, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
I would like to restore my system. i do not know how to start it
click on start, all programs, accessories, system tools, system restore,
once u open system restore, click on next, select a date to which u want to restore the system and click on finish, system restore will happen and system will restart, if successful it would show the msg system restore successful
Nov 14, 2008 | Gateway Computers & Internet
Emachine m5310 laptop
This generally is the indication that the hard drive has failed and needs replaced. You can try reloading the system, but 99% of the time when I see this the hard drive is shot.
Jul 17, 2008 | Toshiba Satellite A105-S2716 Notebook
Black screen comes up "windows did not start successfully...." choose from safe mode, safe mode with networking etc Last known Configuration or Start Windows Normally. Computer then tries to...
You should opt Safe Mode:
  • On the black screen just navigate throug up and down arrow keys.
  • Goto Safe Mode and press enter.
  • It will boot your system in safe mode.
If the boot is success full:
  • try to remember any software or hardware you recently installed/change. Then remove/uninstall that software/hardware. Also remove some device driver like Video/Audio driver and make re-start. and try to normal boot. If success then install your audio/video.
If no success then I think its time to re-install your windows.
Please post your feed-back.
Gud Luck
Iqbal
Apr 20, 2008 | Computers & Internet
Computers & Internet Logo
89 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
