Question about Yamaha Dtxpress Iv Special Electronic Drum Set
Does it have the option to load other sounds in it?
    President:
  • 1,137 Answers
Here is the manual if you don't have it:http://www2.yamaha.co.jp/manual/pdf/emi/english/ssdrums/dtxp4_en_om_d0.pdf The set comes with 427 drum/percussion voices and 22 keyboard voices. If you use a midi cable plugged into the midi out on the sound module you can control other midi sound modules and midi devices by plugging into the midi in on them. Page 30 of the manual describes some of the parameters. If this helps please let me know.
Posted on Nov 20, 2009
Motif 6. When turned on, reads 'now checking plug in broad'. What's wrong?
If you see this message for only a short period of time, then this is normal. The plug-in boards are options that you can add to your Motif 6 to expand sounds/functionality. The first thing the Motif does is do a self check on the main keyboard first, then the plug-in boards. If the message just stays and does not go away, then there could be something wrong with either the optional plug in boards, or the main board the plug-in boards plug into. Make sure the option boards have not come loose, or have become damaged. Check the option board connectors.
Mar 31, 2016 | Yamaha MOTIF XS6 Keyboard
How do I install patches?
Download n install 2 softwares for G2 from ZOOM website.
1. USB subsystem. Driver to connect zoom fx to PC/Notebook.
2. EDIT & SHARE. Software to create/copy sound patch.
Connect USB cable from G2 to PC/notebook.
No need adapter power supply, because the power is supply via
USB cable from PC/notebook.
Open EDIT & SHARE. It's easy,like copy,paste,rename,delete etc.
Just open the menu that you want to do and follow the
instructions. Sound patch can be load from files that you
download, or create it in EDIT & SHARE.
Patch can be load one files or group. Right Click the sound that you want to change,copy-paste it from new file/sound.
You can import/export files/patches from/to PC library (downloaded files).
It is recomended that you save/backup your original files,before load new sound.
I hope this helps.
Regards.
Aug 31, 2015 | Zoom G2 MultiEffects Guitar Pedal
My synth wont load when I power it on. can anyone help?
I suggest a hard reboot / initialize. Istructions are in your manual or on the Korg website
Jun 09, 2015 | Korg Pa800 Synthesizer
Why is gm voice not playing?
Hello, You may want to reset your machine, all data and pre loaded programs, for this you must turn on your M50 press the global mode button, click on the top arrow next to (basic) select option 2, load pre-preloaded demo data, you then choose all (PCG and demo songs). press OK. Your Korg will re install all factory samples, data and settings. Once completed It will then instruct you to turn off your machine. give it a minute or so to self upgrade before turning it back on, once you turn it back on you should see updating panel notifications right and left, you should be able to use all of the sounds and combi's available for M50. that's a factory reset. I hope this helps, Have a great day.
May 01, 2015 | Korg M50 61-Key Music Workstation Keyboard...
My Cortex Dmix 300 has automatically turned autocue on so everytime I load a track on to play it immediately cues up at the first point of sound. Any attempts to re-cue the track just takes it back to the...
hmm there must be a button w a secondary function for the auto cue. if not are you using software with it. check there as well. if you cant find it let me know ill do some research for ya.
May 11, 2011 | CORTEX DMIX-300 Mixing Deck For iPod, MP3...
This may sound dumb but I'm very new to this, my A&H ZED10FX mixer I purchased doesn't seem to have its USB output recognised for recording. It says that the computer should be able to...
Check that it is listed in "control panel" "Sounds and devices" as options in the voice, recording, and playback tabs. If not there, you may need a driver for it. There are so many options of software and operating systems for PC's that it is a wonder that any of this works.
May 11, 2011 | Allen & Heath ZED10FX 10 Channel USB Mixer...
Hallo, I have a Korg pa800 and whenevery I want to load DrumKit or a Sound from another set, I get a warning message (Load Sound Fails: not enought memory fro PCM samples). What should I do to load...
you may have to dump somethings from the memory, the memory is finite and if there is no more room there is no more room. as far as I know there is no expansion memory for this keyboard
Mar 17, 2011 | Korg Pa800 Synthesizer
What sound files can be loaded from a pc to an mpc 500? aiff, wav,mpc...? thanks
Data Compatibility
MPC1000: SEQ, WAV, PGM
MPC2000/2000XL: SEQ, WAV, SND, PGM (Most parameters of PGM file can be loaded.)
MPC4000: SEQ, WAV, PGM (DRUM program only. Only note assign and tune are loaded.)
MPC3000: SND (THRU Computer)
Z4/Z8: SEQ, WAV, PGM (DRUM program only. Only note assign and tune are loaded.)
S5000/6000: WAV only (THRU Computer)
S1000/3000: No compatibility
Feb 21, 2010 | Music
Yamaha Clavinova CLP 260
hi...
Your L/R jacks in the back need to connect to the "line-in" connector on your sound card.
I think the jacks on the Clav are 1/4 inch. Go to Radio shack and ask for an adapter that will take two 1/4 inch plugs/cable and convert it to a 1/8 inch stereo plug.
The Midi connects From (keyboard) To (soundcard)
Cables are available at any music store
Jan 12, 2009 | Yamaha Full-Size Keyboard
Yamaha Dtxpress Iv Special Electronic Drum Set Logo
154 people viewed this question
Top Yamaha Music Experts
Matthew Spark
Matthew Spark
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
