Question about GE WJSR1070A Top Load Washer
I have a WJSR4160D5WW top loading washing machine that is over flowing. I think it is the preasure switch, but cant find a diagram of the washing machine to figure out if it would be to hard to do myself. anyone that can help???
    Guru:
  • 1,738 Answers
The pressure switch is located up there buy the timer. Just take the that part off and there should be about four to six screws and it should get there.
Posted on Nov 19, 2009
My top loading machine will not stop fill it overflows is there anything I can do to fix it
Does the water come in when the machine is off ? If so, the fill valve is jammed open and needs to be replaced. If the water only floods the machine when the machine is on, it is most likely the preasure tube is blocked or the preasure switch is faulty. Job for an engineer.
Oct 04, 2014 | Washing Machines
GE washer won't stop filling with water and go into the wash cycle.
then you need to look at the pressure switch ,,,the pipe to it ?? has no holes on it ??
or you have a doggy water valve?????
Dec 14, 2013 | GE WDSR2080D Top Load Washer
Hot point wm vlsr1090g3ww leaking
Is this a top loading machine? Are you seeing water flowing through the overflow or are you thinking that may be your problem? Asking because I've personally never had a prob with that tube. Leaks have always been attributed to other causes. Top loading hotpoint leaks are usually caused by a leaking transmission seal, water drain pump, inlet valve or faulty pressure switch. Need more info sorry.
Dec 08, 2012 | Washing Machines
Top load washer, starts l flowing water normal and
Check if there is not a blockage in the supply pipe or the gauze filter at the connection at the back of the machine.
Jun 24, 2010 | Maytag PAV2300 Top Load Washer
WASHING MACHINE IS OVER FLOWING. THE LOAD SIZE IS
The problem is the pressure switch has failed. These are usually inexpensive and are very easy to replace. There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the inspection and replacement of this part. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
May 16, 2010 | GE WJSR4160DWW Top Load Washer
Maytag washer will not fill
If it wont fill properly it sound to me me like a preasure switch. Take the control panel off and look at the load size selector switch (preasure switch). This has a hose connecting it to the wash tub. Follow that hose back to see if it may have some kind of blockage in the line. If not you may need to replace the switch.
Jan 26, 2009 | Maytag PAV2300 Top Load Washer
No water to machine
Start checking the water supply connected to the machine, if water is regularly coming to the machine, the problem is either a faulty inlet valve, a defective membrane water level switch, or a faulty timer control (the first two are more likely).
Call a local technician and have the appliance fixed.
You find replacement parts and diagrams here.
Dec 27, 2008 | Maytag PAV3240A Top Load Washer
GE WJSR1070A Top Load Washer Logo
127 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
