Question about Dremel Variable - Speed Multipro Rotary Tool 395
No power about 2 months back it got hot and shut down i let it cool down then read about the brushes may need to be filed down, ran fine since, and now it is doing same not turning on i pulled apart and cannot find any burnt spots on the copper
    Scholar:
  • 115 Answers
If you already checked and replaced the brushes but it is still not turning then you do these:
Try to see if your unit have a safety breaker and reset it,most of power tools have also a fuse in the plug itself.
Also some have a thermostat fuse.,you can find it attached on the rewined coil.
Posted on Nov 20, 2009
Running great but shut down mid ride. Acted Like the kill switch was hit. Checked the switch it was fine. Started right back up. Ran for another minute then shut down again. Plugs have spark, fuel...
My guess is that this is not a car or truck, but rather a 4 wheeler. It may have a low oil shutoff, or bad coil that fails as it gets hot, but hen cools a bit and seems fine. Check for spark immediately as it fails.
Feb 10, 2015 | Cars & Trucks
I have a Bunn Ultra 2 machine it was working fine last week I left it running and when I went and looked at it yesterday it had shut off and would not start up. I unplugged it from the outlet and it...
was it hot? the compressor may be overheated and went into shutdown until it cools. it's safety feature if the fan stops or if the airflow is blocked by too much dust. clean the filter, check the fan, and try again. if it's not hot, it's the transformer that powers the main circuit board.
Apr 14, 2013 | Bunn Margarita Machine Ultra 2 Slush...
I have a 2002 buick lesabre and the water pump was changes about a month ago. The car ran fine. The last week, the car is temp gauge is reading hot very fast. I dont smell any coolant and it doenst sm
some times when the water pump is changed you gotta fill up the radiator with coolant, run the engine until it gets hot, shut off the car and wait until the car cools down to put more coolant because some air may stay trapped inside and by following this steps you get rid of the air trapped inside.
try this:
1) when the car is cool take the cap of the radiator off and see if it's full. if it isn't, with the car still off, put some coolant until it gets full.
2) once the radiator is full, start your car and wait to see if the coolant goes down the radiator. if it does, keep putting coolant until it doesn't take any more.
Hope to be useful.
Sep 07, 2012 | 2002 Buick LeSabre
1998 s10 4.3 when it gets hot it lost all power cools down runs fine till hot. Idles fine
sounds to me like it could be a couple of things one being the coil is breaking down and causeing it to lose power and shut down or mabe its the fuel pump getting hot and slowing down and not pushing enough pressure write back and let me know if this helps...
May 21, 2010 | 2000 Chevrolet S-10
2000 chevy blazer. In warm weather while driving this vehicle, after about 20 miles it will shut down everything and leave you stranded. It does not do this in the winter or when it is cool out. On a hot...
You might be having computer failure. You would need to use a heat gun on the computer. On 2 minutes off 2 minutes to see if the problem can be duplicated.
May 02, 2010 | 2000 Chevrolet Blazer
Truck looses power and shuts down while driving
did you check fuel filter ?? and or fuel pressure
Jan 31, 2010 | 1999 Ford F150 Regular Cab
After a long drive, won't start when hot. Usually cranks after cooling down .Before this started,it ran hot but the temp guage was not reading hot.The motor shut down and would not start until the engine...
definatly crankshaft position sensor, had same problem hour ago and changed it and started right up.. crankshaft positions sensors are known to cause this problem, stays open circuit when hot.
Jul 07, 2009 | 1997 Buick LeSabre
94 deville shuts down when motor gets hot
sounds like you are having a coil problem
Jun 12, 2009 | 1994 Cadillac DeVille
Dremel Variable - Speed Multipro Rotary Tool 395 Logo
280 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
rodhep
Level 1 Expert
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
