Question about Canon PC-921 Black and White Copier
What button do you push, or how do you make a double sided copy on this machine...I've been stuck for awhile. thanks
    President:
  • 1,126 Answers
Canon PC 921 copier does not offer automatic duplexing. It is possible to copy first side, then take the copy and feed it into the bypass (manual) feeder on the right side of copier with printed side facing down or placing in paper cassette printed side facing upward. Don't forget to change your original for second side.
Posted on Nov 25, 2009
Cannot remove control panel from a Zanussi FJ1295 WASHING MACHINE, trying to replace push button which is stuck
take 2 7mm scews top left and top right then the screws from soap tray
when looking into machine from the top there are clips on the inside of the front panel down the side push them in ward and use a flat head screw driver to push the panel out repeat on other side not to much force is needed take your time
Jan 31, 2015 | Zanussi Washing Machines
Xp 9000 stuck in descaling process
Do you hear the pump running? Is it possible that the pump has ceased to function?
Aug 25, 2014 | Krups Coffee Makers & Espresso Machines
Double sided copies
Your printer has Duplex printing Capabilities. However when you are ready to send the print job, open the Printer Properties and select Double Sided.
To copy a Double sided document, insert it in the ADF (Automatic Document Feeder) and open the copy settings on the machine and select Double sided.
Jan 07, 2014 | Office Equipment & Supplies
Copy machine is stuck in the copy mode
Sounds like the machine does not have a fax board on it. Have you been able to fax in the past?
If nothing else, try rebooting the machine, then have your servicing dealer come out to check the fax board module if rebooting doesnt help.
Skelton Business Equipment Houston Copiers
Nov 18, 2013 | Sharp Mx-m260 26ppm Copier
E-Studio 281c is it possible to scan a double-sided document on this machine? thank you.
Welcome to FixYa!
It cannot do double sided scanning but can do double sided copying.
Thank you for using FixYa!
Jas247
Mar 24, 2011 | Toshiba Office Equipment & Supplies
Cannot print double sided
On the machine when a 2 sided document is inserted in the document handler, select the 2x2 button on the console. Press the start button and the machine will feed the document in, and do a reverse of the document for the second scan. In the paper feeder, the machine feeds the paper in and reversed the copy back into the machine, flips the copy then feeds the copy back for the second side to be copied.
If you do not have a m20i, the lower model numbers will not do two sided copies.
Aug 14, 2009 | Xerox WorkCentre M20i All-In-One Laser...
My hotpoint washer drier power on/off button has broken.pls help
Smithbrother is on to it I think. Those push on push off buttons fail after awhile. You can get a replacement, put it on, or have it replaced. The appliance covers must be removed to detach wires, remove button, put new one in, and reattach wires to the replacement.
Dec 26, 2008 | Hotpoint WMA35 Front Load Washer
Stuck on double-sided
you may have to go in the double sided mode to deactivate.
choose double sided, it should show you pics of different types and choose 1-1 or clear.
It's been awhile since I worked on it, could figure it out if in front of. are you in Miami?
Sep 05, 2008 | Canon imageRUNNER 2000 Copier
DVD stuck in my Panisonic VCR/DVD Combo
try unplugging the power, plug back in, quickly hit the eject button.  You might be able to get it to eject that way.
Oct 14, 2007 | Televison & Video
CANON IR 2000
Canon iR1600/2000 not a double-sided copying machine. Can print one side then reverse copies in paper cassette and copy side 2 onto it.
Jan 31, 2007 | Canon imageRUNNER 2000 Copier
Canon PC-921 Black and White Copier Logo
102 people viewed this question
old marine
old marine
