Question about Intermatic T10004R - Pool-Spa Mechanical Control Center - One T104M - All-W
Intermatic t10004 control panel trips the circuit breaker
I have an intermatic t10004 control panel that runs my pool. When the timer is tripped to turn the power on, or the unit is turned on manually, this trips the circuit breaker. What is the next step for me?
  • jkfred10 Nov 20, 2009
    Thanks so much for the feedback. The heavy plastic tubing that houses the wiring leading from the timer to the motor had quite a bit of water inside it, but there were no obvious cracks or holes in the plastic insulation that covers any of the three wires inside. Of course, I can only see about 2 inches of wiring in what is about 5 feet housed within the heavy plastic, so this may account for the short. Is it now just a matter of waiting for the whole thing to dry out and try again?
    Thanks so much for the advice....the thick plastic housing that runs from the timer box to the motor had quite a bit of water inside, so the short must be occuring in the wiring inside there. I could not see cracks or holes in the insulation covering any of the 3 wires inside, but it could be anywhere along the length housed inside the thick plastic tubing. Do I now just wait for this to dry out and try again? How long is a reasonable wait time before I could conclude that emptying the water out did not solve the problem?
  • 1,305 Answers
That circuit breaker is letting you know that you've got a problem in the electrical wiring.... What's next is to turn the power off to BOTH legs of the breaker.
Begin by physically inspecting all the connections in the timer box, and at the breaker and all the way to the pump motor. Make sure all connections are dry, and there's no water in any of the conduits...this will cause a short circuit and trip the breaker. If there's any bare power leg wires touching a grounding point , this can cause the breaker to trip. Lastly check the motor on the pump; on the motor end, there should be a cap you can remove and use a crescent wrench to make sure the motor shaft is moving freely. It could be jammed with debris....this happens around my pool often because I'm surrounded by trees with needles. If the motor cannot turn freely, this will cause the breaker to blow... I'm pretty sure that your timer isn't the issue... Please let me know what you find out.
Posted on Nov 19, 2009
  • KEN LaPOINT
    KEN LaPOINT Nov 20, 2009
    How much time to wait? Good question... depends on ambient temp etc.. While you're waiting, be sure to look around for a possible short somewhere.. esp around where the motor contacts and cables connect. Be sure the power is off.. it's 240Volts!
Intermittent Intermatic Pool Timer T40003RT3 The pool timer is 220v but only one 110v 20amp breaker in the breaker box to the pool equipment and when it is off the pump will not run in manual mode.
http://waterheatertimer.org/How-to-wire-Intermatic-control-centers.html
http://waterheatertimer.org/Intermatic-control-centers-and-manuals.html#RT3
RT3 series has T104 240 volt timer -or- T103 120 volt timer, -plus- low voltage transformer for pool light.
The circuit breaker can be used for transformer, or another outlet or nearby light etc, or it can be used for a T103 120 volt timer.
To trace the wire back to breaker box.... open you main panel and start turning off breakers one at a time and label the panel.
See if you have single breaker or double breaker supplying power to pool equipment.
Gene
Water Heater Timers Save Money
Jun 10, 2015 | Intermatic Timer T40004RT3 300 Watt Pool...
Is timer the problem
I would think whatever is hooked up to the timer is bad. Not the timer itself. Disconnect/unplug the pool pump from the timer and see if the timer trips the breaker.
Dec 04, 2013 | Intermatic 220v T104p Swimming Pool Pump...
Pool pump breaker tripping
1) Not likely the timer is problem, unless there was fire or overheating in timer box. Use nose and eyes to inspect for signs of high heat.
2) Eliminate timer as suspect:
Move wires on timer to test if timer relays have gone bad.
Move terminal 4 to terminal 3
Move terminal 2 to terminal 1
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T104
3) Check watt rating of Hayward pump, and voltage.
1Hp motor at 240Volt draws 8 amp, and can draw 6 to 8 times that amount when starting. Up to 100 feet, should be at least 12 gauge wire and double-pole 20 amp breaker. Over 100 feet, 10 gauge wire and 30 amp double-pole breaker is best.
http://waterheatertimer.org/Color-codewire.html#motor
4) Intermatic T104 240V timer is rated 40 amps
Can safely handle 1 Hp motor without nearing heat-rating capacity of timer
5) Make sure the motor is wired correctly for 240Volts.
If motor is wired for 120, and 240 is applied, then tripped breaker can result.
Apr 14, 2013 | Intermatic 220v T104p Swimming Pool Pump...
Breaker began to trip and now trips each time clock turns on. Was fine before
There is a short circuit, breaker is bad, or wire is overheating, or load is too heavy.
Timer brand, type and model are unknown.
Copy following link to possibly identify timer
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
http://waterheatertimer.org/Intermatic-trippers-and-parts.html
Move wire to different same-amp breaker and see if breaker is problem
Inspect timer terminals for loose wires and signs of burning.
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
Nov 23, 2012 | Hardware & Accessories
Pool time switches pool on, but off does not trip off, and can't do it manual. When I push it on off, the pool pump tries to stop but continutes running. Have to use breaker box.
Model number of timer is not known.
Is this new installation? Or installation that worked before and recently stopped working?
If the manual override lever on timer does not turn Load on-off, then 1) wiring is wrong or 2) timer has gone bad or 3) pump has a short.
I suspect a short since you say the pump 'tries to stop running.'
Copy following links for troubleshoot walk-thru, and correct wiring:
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timers.html
Jun 28, 2012 | Intermatic T104 24h 208-277v Mechanical...
Model 4001-ov trips the circuit breaker.
Assuming you have Paragon 4001 40 amp 120Volt timer
By-pass the timer so only pool pump is connected to breaker.
To do this, move wire from terminal 2 and connect to terminal 1.
If breaker no longer trips, then replace timer with Intermatic T101
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Crossover wiring: Paragon terminal 1 goes to Intermatic terminal 1.
Paragon terminal 2 to Intermatic terminal 2.
Paragon terminal 3 to Intermatic terminal A
If breaker keeps tripping after bypassing timer, then tighten wires on circuit breaker and test again.
If breaker keeps tripping, then move wires to another same-size breaker.
Breakers trip when they sense overheating.
If motor is causing problem, you might need electrician to track down source of overheating.
Jun 19, 2012 | Paragon 4001-0G Defrost Timer
So my intermetic time is broken, the gears dont turn, and the on/ off override isnt working. I need my pool heater, what do i do?
Sounds like you lost power to the timer. Look in your electric panel for a tripped breaker. Turn it OFF then back ON.
Aug 20, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
How to wire model t10004 control panel intermatic inc? I am just looking for a picture of the wiring diagram. All I need to do is hook up a the wiring for the light.
T10004 control panel has 240V T104 timing mechanism.
1) You can use T104 timer to control 120volt light if you have a neutral wire:
http://waterheatertimer.org/images/T-104-control-120V-Load3-45.jpg
2) Lights are usually 120Volts with black hot wire and white neutral wire.
3) T104 timer is 240Volts with two hot wires L1 and L2 that can be white-black wires or red-black wires.
4) Open following link to see basic 120V and 240V circuits.
http://waterheatertimer.org/B220C.html
5) Open following link for T104 wiring options
Jul 17, 2011 | Intermatic T10004R - Pool-Spa Mechanical...
My pool sweep had been doing fine. Now the new pump seems to be dragging as if it is running on half power and the sweep crawls slowly. The pump gets hot and shuts off. The pool filter pump on the left...
My opinion is that new pump is defective.
You posted under Intermatic pool timer.
The timer will not have any effect on the new pump overheating.
Insufficient wiring can cause new pump to overheat.
However if wiring is undersized, and/or if both pumps are turned ON at same time, the circuit breaker would get hot and trip.
Instead of the breaker tripping, your new pump is getting hot, and turning off.
Remember, any pump that slows down and overheats is getting damaged.
Replace the defective pump.
Feb 28, 2011 | Intermatic T10404R - two 220 time clocks...
My Intermaric EH40 does not work. The time display is blank and the load switch and on/off switch do not work. Is it completely shot?
You've lost power to the timer. Look in your main circuit breaker panel for a two-pole breaker that has tripped. Turn it to full OFF, then back ON.
Sometimes it hard to detect if a breaker has tripped, so turn it OFF, then ON anyway.
If that doesn't work it's possible that the circuit breaker is bad.
Sep 11, 2010 | Intermatic EH40 Energy Controls -...
Intermatic T10004R - Pool-Spa Mechanical Control Center - One T104M - All-W Logo
317 people viewed this question
Top Intermatic Electrical Supplies Experts
Hippy_dd
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Electrical Supply Expert? Answer questions, earn points and help others
