Question about Pantech Matrix Cell Phone
My phone starts up and shows the at&t graphics. Then after it boots up the screen is black. Can this be fixed?
  • 55 Answers
The phone must be sent in to be flashed.
Posted on Nov 20, 2009
Screen blank on x836 turns on screen blacksout help thanks
Black Screen, Working Phone [Solved] - Phones - Cell Phone General ...
www.tomsguide.com/forum/id.../black-screen-working-phone.html
Dec 14, 2015 - 12 posts - ‎10 authors
I turn my phone off and then turn it back on, same result, black screen. I then tookout the battery and put it back in, same result. I took the battery ...
Why is my screen black but everything else works ... - iFixit
https://www.ifixit.com/.../Why+is+my+screen+black+but+everythin...
iFixitThe Samsung Galaxy S3 is a multi-touch, slate-format smartphone with ... I have a problem with my phone i dropped it and it works but all i see is a black screen ! ... was fine but then a couple of mins. later the screen started turning pink and when I .... i dropped my gs3, the screen cracked & the screen stays black, everythimg ...
Phone stuck on a black screen during or after a call? Here's ...
www.smartmobilephonesolutions.com/.../cell-phone-shows-a-black-scree...
Is your phone showing a black screen after finishing a conversation and not allowing ... causes and better yet some solutions to fix this issue on your cell phone. ... phone up to your ear, so that the phone will lock (turns on the black screen), ...
Jan 04, 2016 | Cell Phones
Mac book pro. Black screen cannot start but with boot sound
Have you tried connecting an external monitor.
A boot chime means the Mac has passed POST, that the screen remains black initially suggests there is a problem getting image to screen which could mean a bad cable to the LCD or the LCD display its self is having problems.
By connecting to an external display you verify the graphics on the logic board is functional, and it could get you up and running till the display problem is fixed.
Also try powering up and when you hear the chime, hold down the COMMAND+OPTION+P+R keys, and keep holding them till the machine has chimed 3 times, this will reset the 'BIOS' in case there is a glitch there stopping the display from showing up.
Apr 14, 2014 | Apple Computers & Internet
Black screen
re-seat your hard drive and check your settings in the bios.
make sure your adapters are properly configured for the boot drive you are trying to boot from.
Jun 12, 2013 | Computers & Internet
My jetway v4mpmd onboard graphics has failed just a black screen appears. Originally had an FX5200 card for graphics which showed a black screen but that works in another computer . Should I try to boot...
First make SURE your monitor/screen is working (you can do it by plugging it into a working computer)
Try putting a different graphics card in it, if it still gives a blank screen after leaving your computer on for a few min, then the problem is most likely *********** board, and it cannot be fixed.
Nov 25, 2009 | Computers & Internet
Displays 'Input Not Supported' at start up om black screen
Seems that you have set the resolution on your graphics card to a setting higher than the maximum resolution supported by your monitor.
Try to boot into Safe Mode & lower the resolution of your graphics card. If not possible, go to Device Manager & remove the graphics card from it, then reboot your computer. This will reset the resolution.
You can then re-install your graphics card drivers & get it to work properly.
Sep 20, 2009 | AOC LM 720 17" Flat Panel LCD Monitor
Screen black on reboot
start the computer and when the computers splash screen shows (dell) etc. tap the F8 key repeatedly until you see the multiple startup choices. Scroll to "safe Mode with Networking" and select it, you will see the operating system listed as the target operating system, click that (hit enter) start in safe mode. When it boots do you see the screen with no problem? if so then the resolution may be wrong on the normal start up. On the dektop in a clear area free of icons, right click and scroll down to properties, click on settings, then move the resolution slider to either 800 X600 or 1028 X 768. click on yes to change the settings, restart the computer by hitting start > Turn off computer > restart. Reboot it normal mode (just let it boot as you would normally) If you can see the screen, you are all set, if not there is another issue to deal with.
Sep 03, 2009 | Computers & Internet
Blacked out windows with geforce 5500pci
i would get another card and try it.
or, boot to safe mode with F8 which will load default drivers, so you can un-install any that might be left over from an older card
Mar 17, 2009 | Gateway GeForce4 MX440, (128 MB) Graphic...
Monitor stays black until boot up to Desktop
you use a graphics card as your main output?
and you have onboard graphics output too that you dont use?
if so then you will have to plug your monitor lead into the onboard output socket to see bios. i think you need to go into bios and change which device starts from boot.
it sounds like you have the onboard graphics as your boot device and windows using the graphics card.
Feb 26, 2009 | Sceptre X9G-NagaIV 19" LCD Monitor
Computer freezes with black screen
check that all cables are securley fitted to your drives . try unistalling the graphics card , boot up the computer , if it boots up then you will need to install the drivers that came with the graphics card first
Jan 25, 2009 | MSI : 661FM-L P4 SIS661FX FSB800...
Dead... system?
Well the part that shows the graphics on the tv screen for the console is starting to wear out then and time to buy a new one.
Aug 09, 2008 | Nintendo 64 Console
Pantech Matrix  Cell Phone Logo
122 people viewed this question
Top Pantech Cell Phones Experts
Computer Repairing
Computer Repairing
Jax Planet
Jax Planet
Abdul Mannan
Abdul Mannan
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
