Question about LG Incite Cell Phone
Incite won't unlock
My incite has been locked and to unlock you have to push unlock in the bottom right hand corner but the touch screen doesn't work in just that corner.. help?!
Iphone 3gs screen problem
If the problem is consistent in other windows besides strictly the keyboard it is possible that the capacitive touch panel is defective or has been damaged.
Dec 12, 2011 | Apple iPhone 3G
Where on my phone I can do the APN settings
On the LG incite do the following:
1. Select Start from the Main Screen.
2. Select Messaging.
3. Select Messages.
4. Select the Menu key in the lower right hand corner.
5. Select "MMS Settings".
6. Select New. (or edit existing) the APN settings will be in there and editable.
May 04, 2011 | LG Incite Cell Phone
LG touch phone. Touch screen keeps blanking out, it that the touch screen will not work. Screen shows everything but the touch of the screen does not work. I have took out the battery and replaced it. It...
when phone is idle, the auto lock feature locks out the screen. you can set the time when lock engages or disable completely. To unlock, press top right corner button or use touchscreen options by sliding finger up from bottom to top or press unlock button on bottom of touchscreen
Feb 19, 2011 | AT&T Cell Phones
When my daughter touches any object with the pen nothing happens. It will keep telling you to touch a picture on the screen with your pen.
You need to recalibrate. Try pushing B, A, Hint, and Home when you turn it on. Do not have a cartridge in the player or it will think it is a regular Leapster. Once it says calibrate screen it will say to press A, then wait until a target appears in the upper left hand corner, touch it and you should hear a sound, then a new target appears in the lower left hand, repeat actions, then lower right hand screen, and finally the upper right hand screen. If it stops at any time and doesn't get more arrows, try it again or turn it off and see if the pen works. It may take a few tries to get it to recalibrate correctly.
Jan 05, 2011 | LeapFrog LeapSter L-Max Console
When i turned on the leapfrog and asked me to log in my name it doesn't let me go in when i press it with the leapfrog pen
the screen needs to be re-calibrated. Do this: while powering on the Leapster, hold down the ? key. If it's been worn off, it's the round key on the left hand side above the t-arrow keys and it's the middle button. A new screen will come up that lists Base Info Cart 1 Info, Cart 2 Info, Cart 3 Info. In the right hand corner is a "A" that you can touch with pen beside it, it says "Touch Calib" Touch on that.It will say starting...then in the upper left hand corner there is a +. touch it with pen. it will move to bottom left hand corner. Touch it with pen. It will move to right bottom corner. touch with pen. It will move to upper right hand corner. Touch with pen. It will move to the center of the screen. Touch with pen. Repeat until you come back to the Base Info screen. You're DONE! Power off and on again and you should be all set! Good luck!!
Feb 28, 2010 | LeapFrog Leapster 2 Learning System
I have htc 3450 smart phone. the touch screen is not working and the screen is locked. how i can ulock the screen
There must be "unlock" button at bottom left corner. Click on it and a new screen with another "unlock" button in the middle will be displayed. Press it and screen will be unlock. Let me know if this doesn't work for u..
Oct 26, 2009 | HTC Touch P3450 Smartphone
Locked LG Incite phone with nonresponsive touchscreen
You have to reinstall the rom
http://www.wireless.att.com/answer-center/main.jsp?t=solutionTab&solutionId=KB102425
May 27, 2009 | LG Incite Cell Phone
HTC Touch Screen malfunction
hi, i want to formate my htc touch phone.... i dnt want a number formate.... i want a clear full formate
Jan 31, 2009 | HTC Touch P3450 Smartphone
Analogue hands don't correspode to digital clock
Sometimes a watch will be off center due to shock, dead battery etc. Symptoms are; hands don’t line up, digital and analog time doesn’t match, Compass function doesn’t have the hands exactly opposite etc. This can all be fixed. The Synchronization function can be used:
1. Activate Crystal
2. Tap center until you are the unit’s screen (12h or 24h, F ft or C m).
3. Push and hold (at least five seconds) the center crown
4. Watch will beep and word (SYNCHRO) will appear in the display.
5. Use the top + button to line up the minute hand right on the 12.
6. Use the bottom – button to line up the hour hand right on the 12.
7. When finished, press crown and you will go back to time.
Jan 08, 2009 | Tissot T-Touch T33159851 Wrist Watch
Touch screen issues
Has the unit ever been really wet or is there a hole in the touch screen foil? If not have you ever done a cold reset?
. First turn the unit OFF, then HOLD your thumb on the furthest bottom right hand corner of the screen, push as far into the corner as you can on the screen itself. While holding your thumb/finger on the screen press and hold the POWER ON button until you see the ZUMO splash screen, once the splash screen is up you can release the power, but continue to hold your thumb in the right corner of the screen for another 5 - 10 seconds, you should see a window that pops up and asks "Do you really want to erase all user data?", make sure to answer YES to this window, if you don't see this window, then turn unit OFF and try the above instructions again, ensuring your thumb is in the furthest portion of the bottom right hand corner of the touch screen.
Jul 23, 2008 | Garmin zumo 550 GPS Receiver
LG Incite  Cell Phone Logo
149 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
