Question about Lexmark C543dn 26B0000 Workgroup Up to 21 ppm 1200 x 1200 dpi Color Laser Printer
107.08 service printhead error message appears on screen - only installed printer 2 days ago.
Take the back panel off and reseat the ribbon cable in the top middle of the system board..Just got off the phone with tech support and it worked...
Posted on Mar 10, 2010
Solution #3 worked for me too. I just bought the printer last night and printed 5 pages. This morning I had the error. I removed the ribbon and reseated it, and it worked fine after that.
  • shaunplus3 Mar 10, 2010
    Sorry... Solution #2 worked. Remove back panel and reseat ribbon.
  • 320 Answers
This error means the printer has lost communication with the scanner. lexmark says some surge protectors can cause this error also static discharge near the printer if you cannot clear this error by powering the machine off with it plugged into a grounded wall socket return it to where you bought it as an out of box failure
Posted on Nov 22, 2009
Testimonial: "thanks ... will need to return!"
    New Friend:
Hi Stang393,
this was the best problem solving ever!! - Thanks from germany
Bj?rn
Posted on Jul 14, 2016
    Champion:
  • Lexmark Expert
  • 217 Answers
The cyan printhead is causing the problems. You better contact Lexmark for help and warrenty
Posted on Nov 20, 2009
Failed printhead
Check as the error message suggests.
Apr 27, 2018 | The Office Equipment & Supplies
Print head
The carriage does not accept one or more of the printheads. Typical causes are dirty contacts on the printheads or carriage, defective printhead(s), or a defective carriage.
If parts are replaced or fixed in any of the steps listed below, attempt to verify printer functionality by turning the printer on and printing internal test prints. If functionality is verified, no additional parts should be replaced.
  1. Turn the printer on.
  2. Allow printer to complete initialization.
  3. With the printhead icon highlighted, press ENTER.
  4. Select Replace Printheads and press ENTER.
  5. If the message "Printheads still functional" appears, select Yes to continue testing the printheads.
  6. Open the top cover.
  7. Open the carriage cover and remove all of the printheads.
  8. Turn the printer off.
  9. Clean the electrical contacts on the carriage and the printheads using a lint-free cloth dampened with water.
  10. (for this step I suggest using the erraser on the back of a regular pencil instead of a cloth and water)
  11. Allow the contacts to dry.
  12. Reinstall the printheads and close the carriage cover.
  13. Close the top cover.
  14. Turn the printer on and attempt to verify functionality, as instructed in Step 19.
  15. If the error reappears, replace the affected printhead(s).
    NOTE: If the printhead error icon is a question mark, each printhead will have to be tested separately, as the printer is not sure which printhead is causing the problem.
    1. Following replacement of the suspect printhead(s), attempt to verify functionality (Step 19).
    2. If the problem persists following, replace the carriage and trailing cable (refer to pages 8-36 to 8-46 of the service manual).
    3. Following replacement, turn the printer on.
    4. Make sure the printhead alignment completes successfully and that no error messages appear on the front panel.
    5. Print a troubleshooting plot (as instructed below) to ensure the print quality is acceptable.
      1. On the front panel, select the printer icon and press ENTER.
      2. Select Utilities and press ENTER.
      3. Press the UP and ENTER buttons simultaneously.
      4. Select Yes to enter the Service Menu.
      5. Select Service Utilities and press ENTER.
      6. Print pages 1, 2, 3, 4 and 5 to prove printer functionality.
Mar 25, 2014 | HP DesignJet 5500PS InkJet Printer
There's a problem with the printhead
Try this approach to fix the printhead problem:1. Open the printer cover > remove the ink tanks > open the printhead latch > remove the printhead > close the printhead latch.2. Visit the Lexmark website to download and install the Lexmark Pro700 Series Firmware Update.3. After the update is successful, open the printer cover > open the printhead latch > re-install the printhead > close the printer cover > if no error appears, continue with normal installation steps for cartridges. If error still appears, try to remove and re-insert the printhead firmly.
4. Try to print again to verify that the problem is fixed.
Should the error persist, it could be that the printhead itself is faulty. If that's the case, please contact Lexmark Technical Support for further assistance.
Feb 08, 2012 | Lexmark Prevail Pro705 Wireless All-In-One...
We just bought the Pro901 about 3 weeks ago and it has been working fine until today when we got a "Printhead" error. Following the instructions on the machine we removed the printhead and wiped...
Updating the firmware for your Lexmark Pro901 printer will help fix the problem. You will need to get rid of the error first before you can successfully update your printer. Follow the steps below:
1. Open the cover of the printer > remove the printhead. If the printhead will not go to the center, turn off the printer and pull the printhead to the center.
2. Once you have the printhead removed, close the cover of the printer and turn on the printer.
3. It will ask you to "Open Cover to Install the Printhead". Press the Home icon.
4. It should take you back to the Main menu.
5. Proceed with the firmware update, go to http://bit.ly/p905fw.
6. Once the firmware update is successful, you may reinstall the printhead. Follow the steps on the printer screen.
Source: There is a Problem with the Printhead
May 20, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
I called a few days ago about my printer problem. I had an error message 6202. I have received the printer that you sent me to replace mine. This printer has a problem, too. My reference no is #6823342...
Would you mind if I ask you to please clarify? Did you call FixYa or did you call the Printer Manufacturer support? If you reference number and the order number is FixYa's, I'll help you forward it to the FixYa support so that they can verify the order and it's status.
Since you didn't mention the Printer's model and Brand, I can't give you any tip, it'd be much appreciated if you can let me know about your printer so that I can help you fix the problem.
Thanks and Awaiting.
Oct 19, 2010 | Office Equipment & Supplies
Printer wont copy error code 3802
Hi,error 3802 Means Printhead Failure
All You need to do is turn the printer Off and On
And if the problem still there
Remove the ink cartridges and the printhead
Do it again for (5x)
And if the problem still there,
i will suggest you contact their customer care for further assistance.
Apr 16, 2010 | Office Equipment & Supplies
Officejet Pro L7590 printhead message (printheads only 2m. old)!
Pull out the printhead from the computer and check the date under "warranty ends" If the warranty period did not lapse, call HP technical support and tell them about the problem. They will replace the printhead for free. I have gone through 3 black/yellow printheads and I received the replacement printheads via FedEx within 1-2 days. They will send you a pre-paid envelope to return via U.S. Postal Service via US Postal Service.
If the Warranty date on the printhead expired, then you may have to come out of pocket to replace the printhead since HP will argue that they are not obligated to replace the printhead since the manufacturer warranty lapsed.
If this is the case, check to see when you purchased the printer. If the purchase was within a year, the retailer (i.e. Best Buy) is on the hook since there is a 1 year implied warranty on products such as printers, regardless of whether the expiration date on the HP printhead expired.
Hope this helps
Aug 05, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Error message re printhead.
To resolve the error condition:
  1. Open the printer access door.
  2. Remove the color and black ink cartridges.
  3. Remove, then reinstall the printhead
To reinstall printhead follow the link.
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/AiOPrinters/printhead/AUR1780-9_UE_RevC.pdf
Nov 15, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Printhead errors
sounds like a carridge issue , check that the carridge can move freely and theres nothing stopping it
Oct 27, 2008 | HP Designjet 110plus nr InkJet Printer
System Error 04C300 00260000
System Error 04CXX Try the following Steps to resolved an eror:
1.)Press ENTER and switch the printer OFF. Remove the Hard Disk Drive (if installed) and make sure that the EIO card is installed
correctly by pushing it firmly inwards and checking that the two installation screws are completely tightened. Switch the printer
ON again. If this error code continues to appear then replace the EIO card.
2.)If this Error Code disappeared after removing the Hard Disk Drive, then switch the Printer OFF and reinstall the Hard Disk Drive, making sure that the two installation screws are completely tightened. Switch the Printer ON again. If this Error Code reappears, then the Hard Disk Drive could be faulty.
Replace the Hard Disk Drive.
3.)If this system error continues to appear after replacing the EIO card or the Hard Disk Drive, then replace the Electronics Module...
Aug 21, 2008 | HP DesignJet 1050c plus InkJet Printer
Lexmark C543dn 26B0000 Workgroup Up to 21 ppm 1200 x 1200 dpi Color Laser Printer Logo
3,759 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
