Question about Yamaha 12V Air Pump
I have a yamaha waverunner gp 1200 1998, The starter makes a loud buzzing noise when trying to start the pwc! It seems to me the starter isn't engaging all the way. the battery was tested and is good, whats goin on?
goofduck
  • 490 Answers
SOURCE: Starter will not turn over dew to buzzing under seat
buy a new battery shelf life is not 2 yrs the only other thing that would have saved this battery is a trickle charger or battery maintainer
Posted on Apr 12, 2009
SOURCE: I have a 1999 Yamaha Wolverine. When start button
it sounds to me like you have a faulty terminal, check voltage reading to the relay from battery pos terminal, now push and hold button and recheck on same terminal, if it stays at around 12volts check terminal on other side of relay it this is lower significantly than first side replace again with new relay. of both terminals voltage drops you have faulty battery.
Posted on Apr 26, 2009
finish line
  • 207 Answers
SOURCE: how do we start a yamaha 1998 xl 1200 wave runner
first put a new battery in it. then put your lanyard in the handle bar clip push the start button make sure that you have a life jacket on when your in the water and make sure that u attach the lanyard to your wrist or life jacket
Posted on Jul 08, 2009
finish line
  • 207 Answers
SOURCE: 2006 yamaha waverunner wont idle
what is it idle at? how much? remove your seat check air filter if is black oily remove it and see if that fixes your problem you may want to change your spark plugs as well # one cylinder may be starting to foul the new yamahas are the worst for fouling plugs use a cr8eb instead of the cr9eb the 8s are hotter and work better try those and let me know thank you
Posted on Jul 09, 2009
bozcro
  • 867 Answers
SOURCE: Troubleshooting starting system on 2000 yamaha waverunner
check the starter relay switch
99 yamaha waverunner 1200 xlt starter stays engaged and powered on even after stop is pressed and kill switch is pulled.
The start stays engaged the entire time? I would guess it's a bad ignition switch -- it would be sending power to the starter (through the solenoid) regardless of if you switched it off.
Maybe it could be a bad starter, too. I'd start with the switch.
Mar 10, 2016 | Yamaha Jet Ski Pwc Watercraft Cover...
What is wrong with my wave runner
Make sure you are using Yamaha oil not an off brand. It does make a difference.
Jul 17, 2014 | Yamaha Waverunner Xl 800 / Xlt 1200 Jet...
What is the size and year model of my yamaha waverunner the hull id # yama31321394
Yamaha did not make the GP model until 97 and if the numbers you posted are correct you have a 94, that being said all yamahas up until 93 were either a 500 or a 650 so im guessing its not a superjet which is a standup so you may have a waverunner 3, Raider, Blaster, or a wave runner LX. What colors are on it? does it have twin carbs? there will also be a sticker on the engine cases noting engine size.
May 29, 2014 | Yamaha Boating
Relay replace starter
if its xlt 1200 its inside the big black electric box at rear of engine ! unbolt it and remove the back cover !
Jan 10, 2014 | Yamaha Waverunner Xl 800 / Xlt 1200 Jet...
Yamaha 1200XL PWC won't start
hi there could be corrosion on the switch gear and kill switch check and clean as well as the wires going tostarter soliniod,corrosion on these electrical connections are always a problem cheers pete
Jun 11, 2013 | Yamaha Waverunner Xl 800 / Xlt 1200 Jet...
Just changed the starter motor on my xl1200 limited 1999 and it's now making a grinding noise what should I do ?
U may have the wrong starter or it requires shims ( spacers) to adjust proper clearence.did u possibly drop or not see them when takin out?
Jan 09, 2013 | Yamaha Jet Ski Pwc Cover For Waverunner...
Efi makes buzzing noise
glad you solved the problem
Jul 30, 2012 | 1989 Toyota Camry
Jet ski start is not working
is the starter button putting out power to the starter?
Jun 29, 2012 | Yamaha Jet Ski Pwc Cover For Waverunner...
Yamaha 12V Air Pump Logo
542 people viewed this question
Top Yamaha Water Sport Experts
Colin Stickland
Colin Stickland
Piyal Perera
Piyal Perera
Are you a Yamaha Water Sport Expert? Answer questions, earn points and help others
