Question about GE WSXH208A Front Load Washer
Washer locks for about 10 seconds then unlocks no water comin throu.
I have a code of loc coming on and my dryer wont work how can I fix this issue??
The control panel is locked. on the control panel, there will be either a "lock" button that you hold down for 3-5 seconds to unlock, or it will have "lock" in small letters with a line pointing to 2 of the option buttons. hold the 2 buttons it points to for 3-5 seconds and it will unlock. the control lock is a child safty feature that will not allow any the washer to work until it is unlocked. P.S. to put the control panel into the lock mode, is the same way as you unlock the control panel.
May 29, 2015 | Frigidaire ATF6000ES Front Load Washer
Kenmore elite he5t front loading washer door locks, unlocks, then locks again before beginning cycle
This is aself test procedure on the door locking mechanism . You will also hear a click, the drum will make a partial turn,and the door will unlock berore locking again. Once the door has locked a second time the washer will begin tumbling and adding water. The sensing process will continue until the correct amount of water is added to the load.
Feb 12, 2013 | Kenmore Elite HE5t Washer
I have a front load whirlpool washer. Could you please tell me how to get the washer out of control locked mode?
Without the model number of your washer, it is difficult to advise you on how to unlock the controls. Most controls will have the instructions for locking/unlocking on the front panel. Check for a lock icon on the controls. Some washers have a specific lock button with a padlock icon on it. The normal method for locking/unlocking is to hold the button for 3 deliberate seconds or until the control unlocks. This may take as long as 10 seconds on some models.
Aug 16, 2011 | Whirlpool Washing Machines
Un lock child lock 10d52 seimins washer dryer
to deactivate the child lock, set program to Easy-Care and hold option down arrow for 5 seconds. If still it does not get unlocked then Try pressing "dry" & "spin" together for 10 seconds or until the CL disappears. Also try pressing "end of cycle" for over 5 seconds. If this doesn't work then try pressing "options & select" till the light goes off. Also try and press ECO and rapid buttons together for more than 10 seconds.
IF IT IS LIKE MY 5202 YOU HAVE TO PRESS AND HOLD THE UNLOCK BUTTON FOR LIKE 3 SECONDS. THIS PREVENTS SOMEONE FROM JUST PRESSING THE BUTTON AND ACTIVATING THE LOCK . TRY THE PRESS AND HOLD METHOD
Jun 26, 2011 | Washing Machines
The door wont open . I have tried to put it on for a cycle and you can here the the water for around 5 seconds then it stops and does nothing.
Check and make sure your pump or filter is not clogged, then next I would suspect you have a faulty door lock mechanism
More common issues with the door lock.
Is water hooked up to the washer?
The door will remained locked while draining water. If during installation the washer was plugged in and turned on without water hoses attached, the washer may attempt to drain for 8 minutes before the door unlocks. Let the washer run until the door unlocks. Do not turn off the washer or unplug the washer.
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Select Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle. For models that have Rinse/Drain & Spin, push the Extra Rinse button to turn off the rinse to remove excess water.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
Trying to gain access into a locked door can be a bit frustrating. Upon researching your question I found some links that may help you unlock your washer door. I attached all links below. I hope this helps!
http://www.managemylife.com/mmh/questions/204092-how-do-i-get-the-door-open-on-my-kenmore-washer
http://www.managemylife.com/mmh/questions/220303-does-front-loader-door-open http://www.managemylife.com/mmh/questions/134692-why-wont-the-door-open-on-my-kenmore-frontloading-washer
Jun 10, 2011 | Washing Machines
How do i unlock the childlock
Hi
To unlock the washer press and hold 'dry' & 'spin' button. It should unlock now. If this doesn't work then press and hold "end of cycle" button for 5-10 seconds. However, if it is still locked then unplug the washer for 5 minutes and then plug it back. After plugging it back press and hold Start button for 10 seconds to unlock it. Hope this helps...
Daniel
Sep 01, 2010 | Bosch Washing Machines
How do i deactivate the child lock on the bosch axxis washer
Hi
Daniel
Aug 28, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Control locked. How do you unlock it?
The Control Lock is actually a safety feature that enables the consumer to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance.
The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
Check below link for detailed explanations
http://www.fixya.com/support/r3608801-control_panel_lock
Courtesy JSROCK
Mar 31, 2010 | Kenmore Elite 45986 Front Load Washer
Control locked how do I unlock?
The Control Lock is a designed safety feature that enables the us to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance.
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds to 10 seconds.
Please do refer this link for a detailed explanation for your knowledge.
http://www.fixya.com/support/t4186517-control_lock_light_machine
Mar 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
GE WSXH208A Front Load Washer Logo
62 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
