Question about Toshiba Satellite P25-S507 Notebook
How do you remove the keyboard to replace it with a new one
    President:
  • 2,600 Answers
Removing the Keyboard
To remove the keyboard, first remove the battery pack, then follow the steps below.
1. Open the display panel.
2. Insert a thin tool into each of the narrow holes in the strip cover and lever the strip cover up to release its latches.
3. Remove two M2.5×3 silver screws securing the keyboard.
4. Lift the keyboard out and place over the display hinges, revealing the keyboard cable.
5. Disconnect the keyboard cable and remove the keyboard.
Below is the link for your service manual for future refernce. It is free to copy, print and use.
http://tim.id.au/laptops/toshiba/satellite%20p20-25.pdf
Posted on Nov 19, 2009
Remove keyboard 646125-001
  1. Prior to replacing your replacement keyboard for sony vaio vgn-fe880e/h, make sure to remove the keyboard and disconnect the ac adapter from your laptop.
  2. The first step to replacing your laptop keyboard is to remove the screws from the back of your vaio vgn-fe880e/h. Sometimes your laptop will have a picture of a keyboard next to the screws that need to be removed. Otherwise, see your laptop manual for details.
  3. Above the laptop keyboard for sony vaio vgn-fe880e/h, you have a cover panel. If required, remove this part to easily access your keyboard. If you have screws above your keyboard, remove those screws.
  4. Now that you have removed all the screws, you are ready to remove and then replace your new laptop keyboard.
  5. To remove the vaio vgn-fe880e/h Keyboard, take a thin object and pry the keyboard out between the keyboard and motherboard. Be careful when removing the keyboard.
  6. Now that your keyboard is loose, simply disconnect your keyboard. In order to disconnect the keyboard, pay attention to the keyboard connector and connector cable. Unlock the connector cable device and remove your laptop keyboard. Your sony vaio vgn-fe880e/h connector cable should be easy to remove by simply sliding it out.
  7. Now that your keyboard has been removed, get ready to install your new laptop keyboard. Look at the back of the keyboard. If you see any screw holes, you will have a good idea of where to place the screws back in at the bottom of the laptop.
  8. Connect your laptop keyboard for sony vaio vgn-fe880e/h to the motherboard keyboard connection slot. Secure the keyboard cable. Now turn your keyboard in place, and align the grooves on the bottom of your keyboard with your palmrest or plastic bezel. Secure your laptop keyboard in place, make sure it fits properly and is snug. Now simply place the screws back in place.
Nov 30, 2012 | HP 646125-001 - Keyboard Tm - Us
Some of my keys on the keyboard don't want to work and I was told I need to replace it. But how do I remove my current keyboard on my Compaq Presario 2100 laptop?
You need to unscrew some of the screws on the bottom of your laptop. They may be under your battery, or under little rubber covers. It is likely but not gauranteed that the right screws will have little keyboard icons next to them, if not, guess, and then try to remove the keyboard, if it doesn't come off, remove another screw...etc.
Finally, when it comes off, there will be a bus (group of wires) connecting it to the motherboard. Wiggle the bus slowly and gently out of the port on the motherboard, and then wiggle the new bus of the new keyboard into the port and screw the new keyboard in.
The drivers should be installed automatically, and it should work right away.
Jul 05, 2011 | Compaq Armada 7400 Series Replacement...
How do i remove and replace the keyboard on a panasonic cf-52 laptop?
There is a plastic piece above the keyboard, pry that off gently, take your time, then remove the screws underneath it that holds the keyboard....make note of the keyboard wiring how its plugged in before you remove the cable, plug in new keyboard and replace everything you took out...should take 15 minutes.
Jul 04, 2010 | Computers & Internet
How do I replace the keyborad?
The repair of the replacement of your laptop keyboard www.LaptopPartsExpert.com
is not that difficult of a task. Once you have a new or replacement keyboard for your model, its just a simple process of removing a few screws and attaching a few cables. In most laptops, keyboard can be replaced by removing a single screw on the bottom of the laptop, usually designated by a "K" and removing the snap on strip located above the keyboard between the keyboard and the monitor display hinges (usually where the power button and LED indicators are). Sometimes you will need to remove a couple of screws on the rear of the laptop hinges to remove this strip. This all depends on the make and model of your laptop. Once this strip is removed, you should have access to any additional screws securing the keyboard in place. From there, the keyboard can usally be gently lifted out. There will be a ribboon cable connected to an interface on the keyboard to the mainboard. This is normally latched in place by a small clamp. Insert the ribbon cable from the new keyboard into the mainboard interface and lock it down, then lower the new keyboard into place and replace the screws (if any) which hold the keyboard. Replace the cover strip and snap back into place and replace any screws you had to take out to remove thestrip. Replace the locking screw on the bottom of the laptop and that should do it. Things to remember: 1) Always remove all power sources, both AC and battery before removing any screws or servicing your computer. 2) When the power sources are removed, always push the power button and hold for a few seconds to make sure all power possibly stored in the laptops capicitors is full discharged. 3) always make sure you keep track of all screws removed and put them back in the exact location you removed them from. 4) Do not over-tighten or strip the screws - a quarter turn past the point of of where the screw feels resistant should be sufficient. 5) Always make sure to ground yourself by touching a metal object before you touch any elctronic components of the computer - static discharge held in your body can damage your laptop.
I would normally recommend you locate a service manual before attempting this service, however I was unsuccessful in finding one for you during my search for this model. These are general instructions for changing out a keyboard. There may be specific differences based on your model. If in doubt, consult with a PC Tech at an authorized service center.
I hope this helps FixYa! Please leave us some feedback and a testimonial if you find this information helpful.
Apr 06, 2010 | Compaq Presario CQ60-220US PC Laptop
How do i remove the keyboard from a compaq pressario laptop please? need to replace as keys have been removed, already have new one, but cannot get laptop to split although all screws seem to out???
I removed the panel above the keyboard, removed the four screws and tilted the keyboard forward. Unclipped the ribbon cable and the keyboard was out. Replacement was the opposite procedure to removal, very easy after I thought about it. Thanks
Oct 11, 2009 | Computers & Internet
How do i replace the keyborad on acer6935g got replament keyboard but cant find out how to undo laptop to replace keyboard
remove the battery and take ou all screws under it, remove the screws under the laptop that surround the keyboard and in middle of it.
now remove the power button pannel (the long plastic) then take the screws that u find after removing the panel which hold the keyboard.
now lift the keyboard and disconnect the cable using your fingers located in your hands,
putting the new one reverse the steps.
Aug 17, 2009 | Computers & Internet
How do i replace the keyboard on a dell inspiron 1525
How to Install a Replacement Keyboard on Dell Inspiron 1525 Laptop Computer You may need:
  • New keyboard
  • Screwdriver
---Be careful to not break off any of the plastic tabs on the keys as they are difficult to replace.---
  1. Turn the computer off and slide the tip of the screwdriver in the notch on the right side of the hinge cover (the plastic section above the keyboard). Slide the hinge cover up and remove it from the computer, exposing a series of bolts. Unscrew the bolts and remove them.
  2. Pull up on the edge of the keyboard and slide it forward toward the display. Slide the keyboard all the way out of the computer case slowly.
  3. Unhook the flex cable from the computer board to disconnect it from the computer.
  4. Slide the new keyboard into place, connecting the flex cable first.
  5. Screw down the edge of the keyboard with the 4 bolts from before and replace the key cover.
  6. Power up the computer and see how your new keyboard works!
May 01, 2009 | Dell Inspiron 1525 Notebook
Replacing the keyboard
did you try replacing the key? it should just snap on...
May 03, 2007 | Acer ASPIRE 9504WSMi Notebook
Toshiba Satellite P25-S507 Notebook Logo
195 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
