Hello, I bought a printer a few months ago but it doesn't seem to work. I've installed the proper drivers but every time I try printing sth a got a message "Service error 5100, cancel printing and then turn the printer off and on again" and when I do so it still won't work. What shall I do
-   Hi my printer has the message error 5100 please turn off and restart and if problem continues check manual. THe problem continues and there is nothing in the manual. Can you help please
-   den6
May 19, 2008
-   Grinding noise and service error, even after changing ink cartridges, and will not print.-   Guest
Apr 06, 2008
-   Error 5100 I have tried taking out cartridges I have tried the suggestion of holding down pause cancel etc>>>>>>>>>
No solution at this time...still doesn't work and grinding noise -   tecdisturbed
Well, gonna say this is a cannon printer correct? This seems to be kind of common, usually is a problem with the carriage inside of the printer.
Check inside your printer through the gears that you can see under the lid, then use some canned air and spray it in there, is there any physical damage?
McAfee VirusScan Plus HP Customers-Buy Now & Save. I tried www.hp.com/go/deals5 . could...
(More)
McAfee VirusScan Plus HP Customers-Buy Now & Save. I tried www.hp.com/go/deals5 . could not get it? What can i do. fchenette9@sbcglobal.net
pure edge 6.5 won't print. downloaded pure edge from AKO. hp deskjet f4280 prints all other word...
(More)
pure edge 6.5 won't print. downloaded pure edge from AKO. hp deskjet f4280 prints all other word docs.error message said printer drive end page failed.
The canon ip50000 refuses to print a fault code on the led on/off displays five flashes pause then a...
(More)
The canon ip50000 refuses to print a fault code on the led on/off displays five flashes pause then a further 5 flashes, It will not take paper from the bottom tray or top feed.
