I need to move a domestic heat pump (extenal part)
I have a domestic heat pump which I need to temporaily move the external unit. Do I need to de-gas the unit ?
The external unit is on my roof and the internal part is in my ceiling cavity
  • 3,361 Answers
Attach refrigerant gauges to the refrigerant pressure service valves.Have a valve wrench at hand.
Start the unit. Using the valve wrench close"tighten" the high side valve. That is the smaller refrigerant line. Watch your gauge pressure as it falls. When the low side pressure(the large line) reaches "0" pressure,tighten the low side valve to turn it off. Once it is tight shutoff the compressor at the outside disconnect power box.
This procedure draws the refrigerant into the outside unit so that you can safely move it without losing or recovering refrigerant.
Posted on Nov 19, 2009
My boler will heat the hot water & heating but not the hot water on its own
This is possibly because you have a zone valve that has stopped working, motor maybe burnt out or could be that it is permanently open . Some valves have a manual control that clicks into position, these valves are usually placed adjacent to your hot water cylinder
Hope this helps
Jun 22, 2015 | Heating & Cooling
My Goodman split unit has bumping/knocking noise sometimes (not everyday) when heat first kicks on in the mornings only. What could this be? Also in defrost mode should the unit blow cold air?
May be the fan in the external unit is ruined or the internal pump is comming loose. But note that the pump also make much effort until the gas flows smoothly through the pipes .
Feb 27, 2015 | Goodman Heating & Cooling
MSZ-A26YV only blows air now, (no heating or cooling), no error indication. Worked all fine one day then few days later stopped. Emergency switch does the same. Looks like the external unit fails to pump...
try to check your compressor if working if not check electrical parts like capacitor. overload if defect replace. also try if compressor working observe the condensing unit fan blowing hot air if not theres possibilities of leakage of refrigerant gas need for braze leak then recharge refigerant gas. or possible compressor loose compression need for replacement.
Feb 12, 2011 | Mitsubishi Heating & Cooling
M/n 38brb060300 carrier
Hi, to tell if your unit is a heat-pump or not, if the indoor unit is not gas fired, it is a split system heat pump. If it uses gas or propane gas, its a split system gas/elect unit. Look at your thermostat also. It should have aux heat, emergency heat on it also. Maybe not both, but you will know if you have a heat pump. Please don't forget to rate me. Please be kind, as I know you will. Just remember, no gas, its a heat pump, gas fired furnace indoors, its not a heat pump.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor.
Jul 15, 2010 | Carrier 38CKC060 Air Conditioner
Is there a fuel filtr on a 2004 mazda mpv
I've never found an accessable extenal one on our 2004 MPV [crazy, huh?] But we have the official factory technicians service ["workshop"] manual, purchased from Mazda & it lists 2 fuel filters - it shows both are in the gas tank; the low pressure appears to be the simple screen on the pump intake & the high pressure is in the outflow from the pump - apparently connected to, or just under, the "fuel pump unit cover."   So the answer is: both the "low pressure" screen & what I would call the "real" high-pressure filter are inside the gas tank.. Hope that helps
Cheers, Bk
Jul 13, 2010 | 2004 Mazda MPV
Itunes on external hard drive
If you want to move itunes to an extrnal driver, ..plug in the external, click my computer..open the local driver, look for " my music icon" and scroll it to the extenal driver icon...or right click the " music and where it says save..save to external driver.
Jul 03, 2009 | Western Digital My Book Essential Edition...
Pool and Spa Heaters pros and cons
An electric heat pump needs heat available to pump. If it is 30 degrees outside, heating a spa to 102 or so, may be impossible unless the heater has some type of alternative heat source. A properly sized, gas fired heater can take care of a larger range of heating needs. A combination heat pump and natural gas heater, probably with a controller, really makes the issue more difficult, expensive, and would require a lot of study for efficient, cost effective operation. Bottom line: In really mild climates a heat pump might do the job. In cooler climates the gas heater rules. And where a wide range of temperatures and high heat demand is wanted by the customer, a gas heater is the only way to go. A backup heat pump may take years to payout.
Aug 27, 2008 | Saunacore Special Edition Residential...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
