Question about Vivitar ViviCam 10 Digital Camera
Do not have original usb cord. the one I purchased doesn't seem to work. when camera is attached to computer using usb cord, get error message -- cannot detect camera.
  • ALBERT GARCIA
    ALBERT GARCIA May 11, 2010
    did you download the installation disk ?? let me know AJ
SOURCE: USB Power Surge Error
normally usb ports are plug/play it could be tht there is something wrong with your usb cable if i knew your mailing address i could send you a usb cable i have tons..
Posted on Sep 27, 2007
jackboy
  • 2985 Answers
SOURCE: lithium crv3 3v battery and charger and usb cord need to purchase.
Google is a good place to look
Posted on Jul 21, 2008
  • 326 Answers
SOURCE: HOW TO GET MY PICTURES FROM THE CAMERA TO THE COMPUTER
when i take photos off the camera i always plug the camera in, switch it on. after the pc has picked your camera up and installed the driver go to my computer and go to the removable drive create, there will be a folder in there, your pictures will be in that folder. just copy paste to a new folder on your desktop and you have them off your camera. if your going to be editing then youll need another program. i dont use the software provided because i never edit my photos so i find it easier this way.
Posted on Sep 29, 2008
calif-jones
  • 15 Answers
SOURCE: pictures not loading to computer
It sounds like you don't have software on your PC that will recognize the camera when connected. I am going to recommend that you do not use the camera to upload photos. It is better practice to use external (SD) memory cards and remove them from the camera to upload. You can use a USB SD reader or purchase SD cards with a built-in USB interface. You should be able to see a new drive when connecting the SD card to your computer; then all you need to do is copy over the images. One advantage is that you will save camera battery while uploading because you dont need the camera at all. It also allows you to take images with you without taking the camera, i.e. school or work. I hope this helps...californiajones7889e54.jpg67432f4.jpg4db3d64.jpg
Posted on Mar 09, 2009
farr64
  • 121 Answers
SOURCE: computer cannot detect camera, tried different USB cables
is the usb port active still? try wiggling the cable at the camera connection.good luck farr64
Posted on Apr 30, 2009
Connection error, check usb cable....
This may sound silly and I am not trying to be a smarty but mine does that quit a bit and it always because I don't have the on switch on when I pull up my soft ware and if the cord you bought is to long it will not work I suggest only because i do this frequently go back to the original cord hook it up turn it on then pull it up on your computer
Sep 06, 2015 | Singer Futura Xl-400 All-In-One Sewing And...
Computer doesn't recognize camera
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Dec 18, 2012 | Nikon D3000 Digital Camera
I have a Nikon Coolpix 7900 camera I purchased used. It came without the proper USB cord, so I purchased one separately. When I attached the camera to the USB port of my computer (and I've tried...
I'm afraid that USB port has been damaged and is drawing excessive current causing the error message. You are at least fortunate in that your computers' ports are protected since the camera could have otherwise caused damage. Using a basic multimeter one could probably measure across the pins 1 & 4 to determine if the camera's input is shorted; it should in no case measure less than 5-6 Ohms regardless of lead polarity. The current capability of a USB port varies by version but is between 500 & 900 Milliamperes.
Sep 23, 2011 | Nikon Coolpix 3200 Digital Camera
Sony NEX-3 - I can't seem to connect to my computer with USB connection. Camera is on and cord for usb is attached
Hi there, If you haven't already done so... Try connecting to a different USB port, or on a different computer. I noticed on my brothers computer, that when I use one USB port - doesn't work, but the other one does (probably something faulty inside on one of them). Also can try connecting using another different cord...
Hope you can get connected... ****.
Nov 26, 2010 | Sony Cameras
Pictures not loading to computer
Mar 09, 2009 | Kodak EasyShare C875 Digital Camera
USB DEvice not recognized
Turn off the CPU unplug the power cable and all usb cables, let it sit for about 15-20 minutes. Plug power cable back in, turn on CPU, plug in your usb devices.
Mar 06, 2009 | Canon PowerShot SD790 IS Digital Camera
Sep 26, 2007 | Vivitar ViviCam 5385 Digital Camera
Vivitar ViviCam 10 Digital Camera Logo
20 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
