Question about Nintendo DSi White Console
Our dsi cannot connect to our wireless network we keep getting error code 051300
  • 644 Answers
Make sure all your settings are correct and any ip adresses youve typed in dosent conflict with any other mechine using your internet connection
Posted on Jan 15, 2010
2 Suggested Answers
  • 110 Answers
SOURCE: my dsi console wont connect to wireless connection
You need to get your hubs wireless settings up, to do this type bthomehub.home in the address bar of your internet browser, you will then be propted for your hubs username and password which can be found on the back of the hub unless you changed it in which case you will have to use those instead.
Click on settings and choose wireless-
Make sure you have the following settings applied:
1) Interface type: 802.11b, g or n (as far as im aware the DSi wont work with n so either have the mixed (b,g or n) or just b)
2) Encryption Type: TKIP
3) Authentication: WEP or WPA
First try the WPA as its more secure but if you have no luck try the WEP with a 128 bit key first and if it don't work try a 64 bit key.
Hope this helps, any further problems feel free to contact me via my profile page and I will do my best to help you.
Regards,
SOD69
Posted on Feb 12, 2010
Try to access the internet but keep getting error code 051300
This is a common problem, first do the basics to make sure nothing has went wrong maunally, try re-typing the password if there is one. if not. just try reconnecting.
If that does not work, this is where it starts getting a little hard but usefull, go to your router and press the reset button, fix the connecting antenna towards your dsi and then try reconnecting with your dsi very close to the router, (dont worry you dont have to stay close to the router for very long) when it connects you can move but i reccomend you stay in the same room as the router, Your welcome plz rate :D
Aug 18, 2011 | Nintendo DSi Matte Blue Console
I keep getting the Error code :051300 -2 what does it mean?
It means: Unable to connect to your wireless network
Likely cause: It appears that the security settings entered into the Nintendo DS are not the same as what your wireless router is set to allow.
How to fix: Make sure the security key and security type are entered into the Nintendo DS exactly as they appear in your router's settings.
Don't know how to find your router's security key?
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=051300&system=DS&locale=lang
Jun 18, 2011 | Nintendo DSi Matte Blue Console
How do you get internet on my DSI ERROR CODE : 051300
It appears that the security settings entered into the Nintendo DS are not the same as what your wireless router is set to allow. Make sure the security key and security type are entered into the Nintendo DS exactly as they appear in your router's settings. If it is different from you router's change it to what your router has, then try to connect again in the internet.
If that does not resolve your issue try to unplug your router and wait for a few minutes then plug it again. Wait for the router to initialize and connect your DS again to the internet. Check if it will work.
I hope this resolves your problem.
Mar 08, 2011 | Nintendo DSi XL Burgundy
My nintendo dsi won't connect to my home wireless network. I have no idea how to set it up and I keep getting an error code when I type in the number on the back of my router
I am pretty sure the problem is that you wireless router uses a form of encryption that the DSi does not support. I would suggest buying the Nintendo wireless adapter off of the internet and trying that.
Feb 12, 2011 | Nintendo Dsi XL Midnight Blue - Utlsbka
The problem is most like that you DSi does not support the type of encryption that your wireless router uses. The only things I can suggest are that you buy the official Nintendo wireless adapter or you set your router to a different encryption method. The DSi XL supports WEP and some forms of WPA encryption.
Feb 12, 2011 | Nintendo DSi XL Burgundy
Error code 051099
It appears that the settings entered into the Nintendo DS are not compatible, or the router's broadcast settings should be changed.
What we need to do is try creating a new connection with your system.
1. Turn on your Nintendo DSi and access the System Settings by clicking on the wrench icon
2. Scroll over to the third page, and select "Internet."
3. Now choose "Connection Settings."
4. Click on "None" for "Connection 1." (Don't see "None" for Connection 1? To ensure any existing settings don't interfere with getting connected, tap the button, then choose "Clear Settings.")
5. Click on "Search for an Access Point."
6. The Nintendo DSi will search for any wireless networks within range. Once it is finished searching, it will display the names of all the wireless networks it finds.
Look for your wireless network.
7.What to do next will depend on the "lock" icon you see next to your network on the Nintendo DSi.
You will now have 3 options
A. GOLD UNLOCKED LOCK (No security - Tap on your network name to save the settings and begin a connection test.)
B. GOLD LOCKED LOCK
WEP security - Your wireless network is secured with WEP and requires a security key.
Follow the steps now depending on your option
A.
Select "OK," "Save Settings," and then "Yes." The connection test was successful - Your Nintendo DSi is now connected online.
The connection test was not successful - If the test was not successful, you will receive an error code. LET ME KNOW WHAT IT IS
B. WEP security - Your wireless network is secured with WEP and requires a security key.
Enter your WEP key
On the upper screen you will be informed that "A security key is needed to connect to this access point." Enter your security key by tapping the empty field, and select "OK" when finished.
  • The connection test was not successful - If the test was not successful, you will receive an error code.
    • Error Code 51300 or 51099: This means the security code entered into the Nintendo DSi is not the same one the router is set to. Scroll back up to step #3 of this page for the step-by-step directions. To reach your connection settings, click "back" on the error code screen. Make sure to pay extra attention to the security key you find in your router's settings and enter it exactly as it appears (the key is case sensitive).
    • All other error codes: Let me know what it is.
  • Jan 15, 2011 | Nintendo DSi (0.25 GB) Blue Console
    I cant get my DSi to connect to my wire-less network. When I search for an access point I find my network and I put in the network password ( witch I am sure is correct), but it wont connect. I keep...
    1. you need a open wireless network to open the golden lock or you can type in a wep code which you can get in the nintendo service shop . for you information i am only 12 and i could not get it befor but it takes a while to get i got it.
    Nov 21, 2010 | Nintendo DSi White Console
    I carnt connect to the internet by my dsi error code keeps comeing up 051300-1
    Im going to guess that your wireless router is a "wireless-n". If it is then you will have to go into your router settings and change it to either G and N or just G as the DSi does not support the wireless-n configuration.
    If thats not your issue then give me a message and I will do my best to help you out.
    Regards,
    SOD69
    Jan 31, 2010 | Nintendo DSi Black Console
    My dsi console wont connect to wireless connection error code3 051300 my network is a bthome hub 2
    Regards,
    SOD69
    Jan 24, 2010 | Nintendo DSi White Console
    Nintendo DSi White Console Logo
    1,531 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Bee Santiago
    Raj Patel
    phil
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
