Question about Nokia N70 Cellular Phone
My cell phone with this network problem, no longer recognizes SIM card, so remains in offline mode
  • 75 Answers
1st solution :clean the simcard connector or replace the simcard ic.
2nd solution :unlock the simlock of your phone with nokia box,like Jaf or Ub.
Posted on Nov 22, 2009
My 6720 nokia phone has gone into offline mode and can not get it back online can you please help as this is a company phone, i have tried taking sim card out, and memory card out, still does not work
This problem occur when the phone gets dropped on a high place, water damage or setting on your mobile is changed.
Please follow this basic solution :
1. with the sim inserted on your phone, go to profile and select GENERAL. might you accidentally set your profile to offline mode.
2. check the simcard socket if its clean or well align,might corrosion is the problem that's why the sim fails to recognized.
3. Also clean the simcard itself using an pencil eraser.
4. align the battery terminal,might the power supply is not sufficient if the ground (middle terminal) doesn't reach the battery interface. as well as clean the battery connector.
If the above method doesn't work,consult a mobile service center for assistance,maybe the sim IC or some components related to insert sim problem maybe damage.
Good luck...
Jun 22, 2011 | Nokia 6720 Classic Cell Phone
SHOWS OFFLINE MODE CANT RECEIVE OR SEND TEXT. DO I NEED TO REMOVE OFFLINE AND HOW?
no offline mode means that your is not receiving a signal from your network or rather the inserted sim is already expired. possible solution:
1. check whether your sim card is not expired by inserting it other phone. 2. remove the battery and wipe the sim card pad with a cotton soaked in a lighter fluid. this will clean the sim card contacts in your phone
Mar 27, 2011 | Nokia 5800 XpressMusic Smartphone
My phone is offline when ever i inserted my SIM it rejected
change offline mode ,
you can check it with other sim card ,if it remains the same problem ,it may be locked to particular network wont accept any sim card other than the particular network ,you can unlock it and used to other network,try here http://www.wickedunlock.com/nokia-5230-nuron/rs11wp9/
Jan 18, 2011 | Nokia 5230 Cell Phone
I have nokia xpressmusic 5800 its was working all good til i took my sim card it for a minute then put it back it ,keep saying offline mode .I switch it off like 20 times , I also went to profiles to...
It may be due to network lock,
you can check it with other sim card ,if it remains the same problem ,it may be locked to particular network wont accept any sim card other than the particular network ,you can unlock it and used to other network,try here http://www.mobile-unlocker.com/nokia-5800-xpressmusic/rs2wp9/
Jan 17, 2011 | Nokia 5800 XpressMusic Smartphone
My phone is on offline, i try to change the profile then is telling to insert sim whereas i have sim card on the phone
change the offline mode,then
http://www.superunlockcodes.com/nokia-e75/rs12wp9/
Dec 22, 2010 | Nokia E75 Cell Phone
PHONE IN OFFLINE MODE . hOW DO YOU CHANGE IT TO on line mode
Ok let me give you solution about this problem....
Offline mode is the mode in cell phones which barred your every calls sms and even your internet connection simply you can say that...
It stops all of your connection......and you can use only those things which do not need the connection or network.
So to deactivate this offline mode their is two way
1. You can restart your phone after inserting sim card and if the sim card is in good condition and readable then the cell phone will ask you wheather to continue in offline mode?
Just press no that is upper right button of your cell phone and it will be deactivated.
2. Just press on/off button gently and it will show you profile i.e. to select mode
General, silent, meeting etc. you can select any of them except offline mode.and again it will be in normal mode.i hope that it will help you,
By: Neuron
http://www.digixtream.blogspot.in
Jun 15, 2010 | Nokia E51 Cellular Phone
My N95 Nokia phone in offline mode, I cannot call. SIM card not valid
try to check your phone profile settings,it maybe set to offline mode, if it is set to offline, select a different phone profile mode from the list of the options.
try also cleaning the contacts of your sim card card and try again. sometimes, dirt or dust can be a reason for your sim not to be recognized by your phone.
if you have done these steps, try your sim in a different phone and check if it can be recognized. try another sim to your phone if the sim can be recognized by your phone. in this way, you will have the idea of which of the two has a failure.
Feb 23, 2010 | Nokia N95 Cellular Phone
N72 mobile working only in ''offline''mode.
The phone is showing Offline, hence I have inserted the sim card and switched the phone on, and choose general profile too. But it is showing Please Insert Sim Card. Please help with a solution.
Nov 22, 2008 | Nokia N72 Cellular Phone
My Nokia 3250 in "offline" mode.
The problem is with the sim card. try to remove the sim, clean it with a dry cloth and put it back in. if the problem is not solved, take back the sim to your network provider and get a replacement, asuming the sim is damaged
Apr 12, 2008 | Nokia 3250 Cellular Phone
Offline mode
take the sim card and put it bck again.restart it...there it will say "CONTINUE IN OFFLINE MODE?"....select no there...choose another profile and press ok...offline mode will b disabled....
Oct 23, 2007 | Nokia N73 Cellular Phone
Nokia N70 Cellular Phone Logo
102 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
