Question about Samsung SGH-E390 Cellular Phone
I have got a data lead for the e390 mobilephone but when connected the phone to the computer nothing happened
No power
test all power and data leads that attach to your hard drive SATA
the leads from your (motherboard to your hard drive) make sure they have a secure dust free connections and are not faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty
even something as small as faulty fan lead can cause you problems
computers need all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all power and data leads make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
check the CPU central processing unit make sure it has thermal paste and dust free secure seating
also check your computer ram modules and cmos battery make sure it has charge and they are dust free and securely seated some motherboards cmos batteries are soldered in
hope it helps
Jul 24, 2012 | Computers & Internet
How to connect my mobile phone on internet
basically, u just need to fill all the parameter from your provider. click the internet (globe icon on your phone), choose data account, select gprs and make a new account based on your provider parameter such as apn, username, password, etc... u can access this features inside the setting menu too... after you fill all the data correctly, your phone should be able to surf... hope this will help you..
Jun 14, 2012 | Nokia C3 Cell Phone
Would like to reset factory settings to my phone SGH e390
Hi Kelly Ann, try this one:
*2767*3855#
Follow onscreen instructions.
Dec 06, 2010 | Samsung SGH-E390 Cellular Phone
How to download some themes for my mobilephone or games and other things?
try connecting you usb cord to your phone and then to the computer and then just drag and drop into the icon of your phone. or just send it to your phone through bluetooth but you will need a computer with blue tooth to do that.
for more info vote me
May 14, 2010 | Samsung SGH-S5230 Cell Phone
Have a phone forgot password for samsung e390
it is impossible for you to bypass password, either you use the formal password you used before or you need to unlock the phone for you to get access to the phone again.
Take care.
Mar 15, 2010 | Samsung SGH-E390 Cellular Phone
Cannot transfer photos to pc with usb cable
1. Reinstall the Sony Ericsson phone driver and software.
2. Update the software and restart the system.
3. Try connecting the data cable and PC will detect the phone.
tell me if it helps....tc! :)
Download the driver : http://www.sonyericsson.com/cws/products/mobilephones/overview/w995
Jan 03, 2010 | Sony Ericsson Walkman® W995 Cell Phone
N70 not charging
Here is a generic solution for all mobilephones!
This problem could be caused by either battery, charger or firmware failure. you can try the following to secure which!
-Try your mobilephone with another charger or connect it to a PC using a USB cable
> if ok? the problem is your charger!
-Try your mobilephone with another battery
> if ok? the problem is your the battery!
-Try your battery and charger on another phone
> if ok? the problem is your mobilephone/firmware :(
If you dont have access to other phone, battery, charger or USB-cable you can at least try the steps below:
1. Turn off your mobilephone
2. Take out your battery, Sim-card and memmory-card
3. Connect your charger
4. Put the battery in
5. Turn on the phone
If it doesn't help, with a little luck! you should get a USB-cable, back yor phone up and reset it to factory default and upgrade your firmware/software on the phone to the latest version!
OBS! You should only do it with a fully charged battery! or you could damage your phone irreversibly!!!
Jul 12, 2009 | Nokia N70 Cellular Phone
Transferring photos to sim card memory from phone memory
Hi sir,
You can tarnsfer all the photos to your computer by using the data transfer cable that comes along woth the mobile phone. Insert one end of the cable in ur phone and ther other end in your laptop/computer where USB sign is given. The laptop/computer would detect a new object and open all the data avilable in your mobile. You can select the photos from those folders and copy them and then paste them on your desktop.All the photos in ur sim card and memory card would reflect in your computer once the wire is inserted. Please contact me in case issue is not resolved.
Jan 28, 2009 | Sony Ericsson K750i Cellular Phone
How to download pictures taken on the mobile to a pc
I can't tell you the exact procedure because you didn't mention any mobile brand or model. If you'd mentioned it would easy for me.
However, normally 2 things are needed for connecting mobilephones to a pc. 1, Data cable for that phone and 2. A software relevant to that brand. For example, a) Nokia- Nokia PC Suite b) Motorola- Motorola Phone Tools c) Siemens- Mobile Phone Manager etc.
If your phone has bluetooth or infrared and your computer also has those transfering devices than you can also send pic to PC without any soft or cable.
May 20, 2008 | Cell Phones
Samsung SGH-E390 Cellular Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
