Question about Belkin F5L017 Mouse
Can't get my mouse and usb to sync - Belkin F5L017 Mouse
    Sergeant:
  • 275 Answers
There might be a button on the bottom of the mouse that syncs it to the port. Also there might be a button on the usb insert that has to be pressed also. Hard to tell without seeing it.
Hope it helps.
Posted on Nov 20, 2009
Belkin wireless mouse won't connect on power up of PC
A Belkin Mini Wireless Optical Mouse frees you from the restriction imposed by the limit of the wire that your mouse uses to connect to your computer. The Belkin model works up to three feet away from the receiver and operates on a 27 MHz frequency. It's smaller than a regular mouse, making it easy to add it to a laptop case or desk drawer without losing much space in the process. Before you can use the Belkin Mini Wireless Optical mouse, you must install it. The receiver and the mouse should sync automatically; if they don't, you must perform the sync manually.
1 Press the bottom release tab on the top cover of the mouse. Insert the batteries included in the package and replace the cover.
2 Turn on your computer. Plug the Belkin USB receiver into a USB port on your computer. The drivers will install automatically.
3 Press the sync button on top of the USB receiver and then press the sync button on the bottom of the mouse to connect the two devices.
Warning
  • close Before you can install the Belkin mouse, remove drivers for other wireless mouse types on your computer.
Jul 17, 2017 | Belkin Mini Wireless Optical Mouse...
How do i get my wireless technika mouse wm110pk to connect to my laptop?
Insert the USB dongle that came with your technika wireless mouse into a USB computer port on your machine.
This dongle, which resembles a regular flash drive in appearance, can be plugged into any available USB port.
Once inserted, it immediately turns on.
Insert the required amount of batteries (typically two AA batteries, though it changes depending on the model) into the compartment on the bottom of your HP wireless mouse.
Flip the "ON" switch on the bottom of your technika wireless mouse.
Press the "Sync" button on the bottom of your technika wireless mouse.
The mouse will now sync with your computer and will be immediately usable.
hope this helps
i have read some good and bad reviews on this mouse one stated the wireles stopped working several times and it had to be replaced
Oct 12, 2012 | Computers & Internet
I have a F5L075 wireless Belkin mouse that I need instructions on how to sync it to the ubs device.
when you turn on the mouse and if you have the USB transmitter in your USB port, the computer should automatically detect the mouse and the keyboard, (make sure both the keyboard and the mouse are switched on otherwise the computer will not see it. also be sure that your batteries are new (or check them with a volt meter). you don't actually do anything called "sync" with the mouse or keyboard.
Mar 23, 2011 | Belkin Wireless Keyboard/Optical Mouse...
How can I re-sync the mouse to the computer?
Just press the sync button on the mouse and also the usb reciever, usually it works best if you press the reciever first then the mouse.
Oct 23, 2010 | Belkin DBF8E825USB Mouse
My mouse does not want to work , theres power but doesnt work
This is kind of hard to diagnose without more information but i can try to help you out. Has the mouse ever worked? If the mouse was working fine and just quit working then you most likly will need to change the batteries. Once you change the batteries you will have to then re-sync the mouse with the usb device the plugs into the computer. Its usually just as simply as hitting the button the the usb device (adapter that connects to the computer) and then hitting the button on the bottom of the mouse (usually on the bottom) if this is the first time you are installing the device usually u put batteries in the mouse. Then you do the same sync process above. I hope this helps
Thanks
Steven.
Apr 21, 2010 | Targus Wireless Optical Notebook Mouse...
I want to install a Microsoft wireless optical mouse but not sure how to do it.
With the wireless mouse you also have a wireless adapter that is connected via usb to your computer. Insert the usb adapter in an available usb port on your computer. Wait for a few seconds until windows verfies and installs the new device. Then press the sync button located under the wireless adapter and at the same time press the sync button under your mouse.
The mouse will be ready to use.
Regards,
nicolasiac
Feb 09, 2010 | Microsoft Basic Optical Mouse PS 2/USB...
I need to know how to sync the mouse to the usb..????
1. Insert the batteries into the mouse.
2. Plug the USB stick into the port in your computer.
3. Turn the mouse on (switch is on the bottom).
4. To sync the mouse with your computer, press and hold the button on the bottom left-hand side of the mouse. Then, press and hold the button on the USB stick immediately after.
Note: The button on the mouse is very hard to find. Look at the sticker that is on the bottom, and to the left of it is a very tiny button.
5. Once you press the button on the USB stick, the red light will begin blinking. Hold both buttons simultaneously until the red light begins to blink noticeably faster, then let go.
Note: This is hard to do so be patient with yourself if you can't do it on the first try.
Dec 14, 2009 | Belkin Mini Wireless Optical Mouse...
Mouse does not work I have installed new batteris
Try hitting the SYNC button on the bottom of the mouse at the same time as hitting the SYNC button on the USB receiver (assuming this is a USB wireless mouse). Also try removing the USB receiver and plugging it back in.
Jul 07, 2009 | Logitech 9311570403 Mouse
I need to connect my mouse
There should be a tiny sync button on the mouse and the USB receiver that connects to your computer. Make sure your computer is on and loaded, then connect the USB receiver, and make sure the batteries are functional in the mouse. Once it's set up, simply press the sync button on the receiver, then press the sync button on the mouse and wait for it to sync up.
If your wireless adapter is bluetooth, you'll have to install the software that came with your mouse, and use the software to synch the mouse.
May 05, 2009 | Dynex Wireless Optical Mouse
Mouse not functioning
You should have a USB adapter that goes from the Charging base to your computer to make the connection. the wireless is from the base (charging unit) to the mouse.  once you connect your USB it should find the mouse and work. you may need to sync the base unit and mouse to complete the process, by first click the sync button on the base unit then the small sync button found on the bottom of the mouse
Oct 12, 2007 | Logitech MX700 CORDLESS OPTICAL MOUSE...
Belkin F5L017 Mouse  Logo
553 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
