Question about Toshiba Satellite P305D-S8834 17 in Laptop PC Notebook
My drivers don t launch evry restart - Toshiba Satellite P305D-S8834 17 in Laptop PC Notebook
    Sniper:
  • 50 Answers
Kindli go on This link
toshiba driver site
https://www.toshiba-india.com/DriversDetails.aspx
Give your notebook modul No And download your driver (its free)
Posted on Nov 20, 2009
My sound on my computer don't work
What kind of computer are we dealing here?
Is it a laptop or a desktop? Here are the things that you need to check:
1. Make sure that the volume control is all the way up and it's not muted.
2. Check if the drivers are working.
3. If it used to work, then you can do a system restore .. Click on Start > Programs > Accessories > System Tools > System Restore
Select a restoration point > Launch it. Let it restart by itself.
You can also use RadarSync to scan your computer for outdated driver. The good thing about this software is that it won't only fix the outdated sound drivers but it will fix all outdated drivers which might be affecting the sound of your computer.
I hope this helps!
David
Feb 03, 2013 | Audio Players & Recorders
Monitor only works on safe mode,why?
Vga drivers might have been corrupted and need to be updated.
Video drivers are applications that enhance your on-screen display. The drivers make your text and images sharper and clearer. Some devices and applications may corrupt display drivers. You can, however, repair the drivers in Safe Mode. Safe Mode is an area of Windows that only allows a limited number of applications to run, thereby making it ideal for repairing and restoring your display driver. Click the Windows "Start" menu and click the "Control Panel." Double-click "System and Maintenance" and click "Device Manager" to launch the hardware management console if you are using Windows Vista or 7. For Windows XP users, right-click "My Computer" on the desktop and click "Manage." Click "Device Manager" to launch the hardware management console. Click the "Display Adapter" to expand it. Make a note of the video driver that contains a question or exclamation mark. A question or exclamation mark means the video driver is either damaged or missing. Close the Device Manager. Write down your computer's model and serial number. The location of the serial number varies with different computer models but can generally be found on the front or back of your computer. Go to your computer manufacturer's website and locate the "Support and Drivers" section. Locate "Driver Downloads." When prompted, type your serial or model number to locate the drivers compatible with your computer. Click "Download" next to the video driver compatible with your computer. Select "Save" and download the video driver installation file on your desktop. Restart your computer and press "F8" repeatedly before Windows reloads to launch the Advanced Options Menu. Select "Safe Mode" and press "Enter" to launch Windows Safe Mode. Double-click the video driver you installed and click "Run" to install the driver on your computer. When the installation completes, go back to the Device Manager and click "Display Adapters." Make sure that your video driver no longer contains a question or exclamation mark. If the driver still contains a question or exclamation mark, right-click it and click "Update driver." This launches the launch the driver installation wizard. Insert your Windows installation CD and click "Install software automatically (Recommended)" and then click "Next." The install wizard installs the video driver automatically. Restart your computer normally when the installation completes. Hope this helps.
Dec 28, 2012 | Gateway GT5224 PC Desktop
Windows 7 won't bootup, has error recovery. it loads files then nothing. screen is black.
Had that problem a few times myself.
Only way I could fix was to restore back to factory condition.
As you boot, watch bottom of screen closely.
depending on system, Should need to press F2, F10, possibly F12, might even be Del.
Most likely you didn't get restore disk, or have made one.
If you do, insert disk before boot up. System should boot to DvD.
Don't forget once restored to update.
Hope this helps
Don
Jun 22, 2011 | Computers & Internet
A4 tech 635e - skype closes when i turn on my camera
Please uninstall any driver for the camera that you have already installed.
Restart the PC
Go to this link to download the new driver
Unzip and install the driver
Restart the PC
Launch Skype again
Regards,
katharsys_i
Mar 03, 2011 | A4tech PK-635 Webcam
The full stop button second function which is < is constantly on and the same is for evry other key for example the munber two button when pressed shows the @ symbol>>>how can i fix this
try to go to the device anager and uninstall the keyboard driver. Restart your computer and windows will automatically reinstall the keyboard driver. You might be prompted to restart your computer again after windows successfully installed your keyboard driver.
Jun 19, 2010 | Dell Inspiron Mini 9 Notebook
Require sound software of c707tu laptop
For Audio and Modem, download the following driver packs (install will fail, read below):
Conexant HDA Soft Modem with SmartCP
DriverVer=02/14/2007, 7.62.00.52
http://ftp.hp.com/pub/softpaq/sp36001-36500/sp36089.exe (11MB)
Conexant High Definition Audio Device
DriverVer = 02/14/2007, 3.34.0.50
http://ftp.hp.com/pub/softpaq/sp36001-36500/sp36090.exe (4.1MB)
After running the two Conexant packages above, the driver files will be extracted to C:\SWSetup\SPxxxxx. The automatic install program will fail but that is expected. Go to Control Panel > Device Manager. Single right-click on the ‘unknown’ audio device and select “Update Driver”. From the Hardware Update wizard:
Select ‘no, not this time’ when asked to connect to the internet, click next.
Select ‘install from a specific location’ (advanced), click next.
Select ‘Don’t search, I will choose the driver to install’, click next.
In the list of common hardware types, scroll down and select Sound, Video, and Game controllers, click next.
In the resulting dialogue box, click Have Disk.
Browse to the folder where SP36090 was extracted (e.g. C:\SWSetup\SP36090) and select CpV30D5a.inf, click OK
In the next dialogue, select Conexant High Definition Audio-Venice 5045. If you receive a warning that Windows cannot verify compatibility with this drive, select ‘Proceed’ or ‘Ignore’ (or whatever option that allows you to continue installing the driver).
When the driver is finished installing, restart your PC. Do the same thing for the modem, except the extraction folder will be C:\SWSetup\SP36089 and the INF is SprtHD5m.inf.
Restart and you should be good.
If you still have an ‘unknown’ PCI device, it is your touchpad and Quick Launch buttons. If you install the software for Quick Launch Buttons, the ‘unknown’ PCI device will go away, as well.
HP Quick Launch Buttons
VERSION: 6.30 REV: A
http://ftp.hp.com/pub/softpaq/sp35001-35500/sp35353.exe (18MB)
Apr 28, 2009 | Compaq Presario 700 470024-192 Notebook
Error during audio driver installation
Hi Friends,
Try this out..
Easy launch button not work
ola...
http://support.acer-euro.com/drivers/notebook/as_5050.html
launch manager 2.0.0.4 ( use this )
Mar 12, 2009 | Computers & Internet
Toshiba Satellite P305D-S8834 17 in Laptop  PC Notebook Logo
52 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
